Marbles rtx loading problem
Hello, I tried launching Marbles RTX but I get this in the crashdump log:
2021-05-10 18:43:04 [597ms] [Info] [carb] Initializing plugin: gpu.foundation.plugin (interfaces: [carb::graphicsmux::GraphicsMux v0.9],[gpu::foundation::GpuFoundation v0.1],[rtx::psodb::PsoDb v0.2],[rtx::rendergraph::RenderGraphBuilder v0.6],[rtx::resourcemanager::ResourceManager v0.13],[rtx::shaderdb::ShaderDb v0.7]) (impl: gpu.foundation.plugin)
2021-05-10 18:43:05 [1,343ms] [Warning] [gpu.foundation.plugin] Skipping GPU NVIDIA GeForce RTX 3080 with 10078 MB of GPU memory. Requested min 11000 of GPU memory
2021-05-10 18:43:05 [1,344ms] [Warning] [gpu.foundation.plugin] Skipping GPU NVIDIA GeForce RTX 3080 with 10078 MB of GPU memory. Requested min 11000 of GPU memory
2021-05-10 18:43:05 [1,344ms] [Info] [gpu.foundation.plugin]
| Driver Version: 466.27 | Graphics API: D3D12
| GPU | Name | Active | LDA | GPU Memory | Vendor-ID | LUID |
| | | | | | Device-ID | UUID |
| 0 | NVIDIA GeForce RTX 3080 | | | 10078 MB | 10de | 17eaa550… |
| | | | | | 2206 | 0 |
| OS: Windows, Version: 10.0 (2004), Build: 19041
| Processor: Intel(R) Core™ i9-10850K CPU @ 3.60GHz | Cores: 10 | Logical: 20
| Total Memory (MB): 65453 | Free Memory: 56746
| Total Page/Swap (MB): 75181 | Free Page/Swap: 63939
2021-05-10 18:43:05 [1,344ms] [Error] [gpu.foundation.plugin] No device could be created.
2021-05-10 18:43:05 [1,428ms] [Warning] [gpu.foundation.plugin] Skipping GPU NVIDIA GeForce RTX 3080 with 10078 MB of GPU memory. Requested min 11000 of GPU memory
2021-05-10 18:43:05 [1,428ms] [Info] [gpu.foundation.plugin]
| | | | | | Device-ID | UUID |
| | | | | | 2206 | 0 |
| Total Memory (MB): 65453 | Free Memory: 56744
2021-05-10 18:43:05 [1,428ms] [Error] [gpu.foundation.plugin] No device could be created.
2021-05-10 18:43:05 [1,428ms] [Warning] [omni.kit.renderer.plugin] RT-capable GPU not found, switching to compatibility mode
2021-05-10 18:43:05 [1,428ms] [Error] [omni.kit.renderer.plugin] Failed to create GPU foundation!
2021-05-10 18:43:05 [1,429ms] [Info] [carb] Initializing plugin: omni.ui.windowmanager.plugin (interfaces: [omni::ui::windowmanager::IWindowCallbackManager v0.3]) (impl: omni.ui.windowmanager.plugin)
2021-05-10 18:43:05 [1,429ms] [Info] [carb] Initializing plugin: carb.imgui.plugin (interfaces: [carb::imgui::ImGui v1.0]) (impl: carb.imgui.plugin)
2021-05-10 18:43:05 [1,429ms] [Info] [carb] Initializing plugin: carb.imguizmo.plugin (interfaces: [carb::imguizmo::ImGuizmo v1.0]) (impl: carb.imguizmo.plugin)
2021-05-10 18:43:07 [3,440ms] [Info] [carb.crashreporter-breakpad.plugin] uploaded minidump: file:‘C:/Users/Timothy/AppData/Local/ov/data/Kit/omni.app.marbles/2021.1\d2b824b7-4d12-44e4-a6ce-84a04ad884b6.dmp’ response:
“8FF575EC-B1BF-11EB-818D-6460C97A47AE”
2021-05-10 18:43:07 [3,586ms] [Fatal] [carb.crashreporter-breakpad.plugin] omni.kit.renderer.plugin.dll!carbOnPluginStartup
2021-05-10 18:43:07 [3,586ms] [Fatal] [carb.crashreporter-breakpad.plugin] omni.kit.imgui_renderer.plugin.dll!+0x4f52
2021-05-10 18:43:07 [3,586ms] [Fatal] [carb.crashreporter-breakpad.plugin] omni.kit.imgui_renderer.plugin.dll!+0x9354
2021-05-10 18:43:07 [3,587ms] [Fatal] [carb.crashreporter-breakpad.plugin] omni.kit.renderer.ext.plugin.dll!+0x19ec
2021-05-10 18:43:07 [3,587ms] [Fatal] [carb.crashreporter-breakpad.plugin] omni.ext.plugin.dll!carbOnPluginRegisterEx
2021-05-10 18:43:07 [3,587ms] [Fatal] [carb.crashreporter-breakpad.plugin] omni.ext.plugin.dll!carbOnPluginStartup
2021-05-10 18:43:07 [3,588ms] [Fatal] [carb.crashreporter-breakpad.plugin] omni.kit.app.plugin.dll!+0xaae1
2021-05-10 18:43:07 [3,588ms] [Fatal] [carb.crashreporter-breakpad.plugin] kit.exe!+0x216f
2021-05-10 18:43:07 [3,588ms] [Fatal] [carb.crashreporter-breakpad.plugin] kit.exe!+0x2bb4
2021-05-10 18:43:07 [3,588ms] [Fatal] [carb.crashreporter-breakpad.plugin] KERNEL32.DLL!BaseThreadInitThunk
2021-05-10 18:43:07 [3,589ms] [Fatal] [carb.crashreporter-breakpad.plugin] ntdll.dll!RtlUserThreadStart
Can anyone assist in me trying to successfully launching MARBLES? It seems it cannot be launched
I also ran into the same issue on Windows, and found that it was happening since Marbles was configured to require a minimum of 11GB of GPU memory. I found the configuration file with the setting to change the minimum GPU memory required in the Marbles installation location.
If you navigate to
<Omniverse Install Location>/omniverse/Library/marbles_rtx-<BUILD>/_build/windows-x86_64/release/apps
you’ll find a file named omni.app.marbles.kit which has a bunch of configuration options. In there you’ll find a line that says renderer.minGpuMemoryMB = 11000. You can change this to something less than this, in the case of the RTX 3080, something less than 10000 should be fine.
Minimum requirements were set knowing the Marbles experience would not be enjoyable if playing with a GPU with less than 11GB. You can certainly try playing Marbles RTX under minimum suggested specs, but frame rates will be less desirable.
I want to point out that the minimum system requirements state “VRAM: 6GB”, and the recommendation is “VRAM. 8GB” - this makes the 11 GB requirement sort of unexpected.
Beyond that, as running with less than 11GB is possible (an RTX 3080 at least somehow manages), it would be nice to have the app crash & necessary digging in log files replaced with an on-screen warning message.
crash_2022-01-08_16-59-51_27176.txt (569 Bytes)
Marbles crashes on the latest studio driver 511.09 Omniverse (non-enterprise), W10, 3070RTX, Ryzen 5950x.
I’m not sure if Marbles is completely stand-alone or not, but everything else around Omniverse seems to work (though I am getting some Amazon S3 timeouts on certain assets).
The team is looking into this and we will get back to you here or drop me a line at rkerris@nvidia.com
Richard
