Mask Rcnn evaluation on trt engine fails
Running evaluate task on mask rcnn trt engine gives the following error:
File "/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/mask_rcnn/scripts/evaluate.py", line 194, in <module>
File "/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/mask_rcnn/scripts/evaluate.py", line 126, in main
AssertionError: The pruned model must be retrained first.
Refer to Mask Rcnn Inference Error
my last model name is model.step-35.tlt and I rename the trt.engine to model.step-35.engine refer to Mask Rcnn Inference Error
but I get the following error:
[MaskRCNN] INFO    : Loading weights from /workspace/results/MASK_trt3/unpruned_model/export/model.step-35.engine
File "/root/.cache/bazel/_bazel_root/ed34e6d125608f91724fda23656f1726/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/mask_rcnn/executer/distributed_executer.py", line 347, in extract_ckpt
File "/usr/lib/python3.6/zipfile.py", line 1131, in __init__
self._RealGetContents()
File "/usr/lib/python3.6/zipfile.py", line 1198, in _RealGetContents
raise BadZipFile("File is not a zip file")
zipfile.BadZipFile: File is not a zip file
Refer to Mask Rcnn Inference Error - #13 by Morganh , please do not rename the model. And also because the code checks the step number of the tlt model and matches the number to the unzipped checkpoint.
