Mask Rcnn Inference Error
I trained Mask Rcnn network. but inference task gives the following error: But I am not pruned the model
/workspace/tlt/tlt_experiments/tlt_algorithms/all_segmentation_approaches
inference with best model
WARNING:tensorflow:Deprecation warnings have been disabled. Set TF_ENABLE_DEPRECATION_WARNINGS=1 to re-enable them.
Using TensorFlow backend.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/horovod/tensorflow/__init__.py:117: The name tf.global_variables is deprecated. Please use tf.compat.v1.global_variables instead.
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/horovod/tensorflow/__init__.py:143: The name tf.get_default_graph is deprecated. Please use tf.compat.v1.get_default_graph instead.
File "/opt/tlt/.cache/dazel/_dazel_tlt/2b81a5aac84a1d3b7a324f2a7a6f400b/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/mask_rcnn/scripts/inference.py", line 351, in <module>
File "/opt/tlt/.cache/dazel/_dazel_tlt/2b81a5aac84a1d3b7a324f2a7a6f400b/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/mask_rcnn/scripts/inference.py", line 343, in main
File "/opt/tlt/.cache/dazel/_dazel_tlt/2b81a5aac84a1d3b7a324f2a7a6f400b/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/mask_rcnn/scripts/inference.py", line 183, in infer
**AssertionError: The pruned model must be retrained first.**
write inference results to /workspace/tlt/results/tlt_mask_rcnn_corrosion1000_resnet101/infer/
Please retrained firstly.
But I did not prune the model. I just train it
Can you double check?
Yes, I checked but the result is same
I rename the model to final_model.tlt after train.
But I realized that the model name should be in this format: model.step-10.tlt
But for all TLT models, I always do this renaming.
So, you can run inference against model.step-10.tlt , but failed in running inference against final_model.tlt ?
Yes. But that does not make sense.
I need to save the model with final_model.tlt name
OK, this is a limitation for the renaming.
Currently, there is assertion for the model name.
assert ‘step’ in args.model_path, “The pruned model must be retrained first.”
Thanks for your help
Please note that “saving the model to final_step_model.tlt.” will be incorrect, because the code checks the step number of the tlt model and matches the number to the unzipped checkpoint.
Thus, please do not rename the model. Please create new directory to host the model.
