Mask RCNN on NVIDA AGX Orin
I currently have an AGX Orin Developer Kit and am trying to evaluate my options and figure out what’s best for my situation. I apologize in advance for any misunderstanding I may have. I am new to deep learning and trying to learn as I go.
My current plan is to train a Mask RCNN model, and use that to run inference for a specific case. I don’t want to dive into any specifics, but the model will run inference on a new image every 5 seconds (for example), then the output of the inference of each image will be used for another task.
To train this model, I plan to use a could service such as Google Cloud to run the TAO Toolkit. I’ve created a VM and been able to successfully train a model (just by running through the Jupyter notebooks provided). But I was also wondering, can I train a Mask RCNN model on my AGX Orin without the use of TAO. From what I understand, TAO cannot be run on the AGX Orin Developer Kit. So am I able to use the developer kit and run python code to train a Mask RCNN model? I’d prefer TAO, but I have been running into availability issues with the Google Cloud GPUs recently… I may try another VM service.
I am going to write this next question assuming I have trained the model with the TAO toolkit. I now believe I can deploy the model. Do I have to use DeepStream to deploy the model? I used the SDKManager to flash my development kit with the latestest version of JetPack and DeepStream. Aside from DeepStream, are there other ways to deploy the model and use it for inference in the method described above?
I once again apologize as these may be basic questions. I am just trying to get my footing with training and deploying models.
Thanks,
Andrew
About how to train your own model, you can file a topic on our TAO forum. You can also ask questions about deployment on that forum.
After you get your model and encountered any problems with the deployment with DeepStream, you can report them to our DeepStream forum and we will analyze that. Thanks
