• Hardware (Jetson AGX – Jetpack 4.6 → Nvidia Volta → Ubuntu 18.04)
• Network Type (MaskRCNN)
• TLT Version: TAO Toolkit 3.0-21.11
• How to reproduce the issue?
I am using Jetpack 4.6 which comes with tensor rt 8.0.1, there is tao-converter binary available for this but it fails when I try to convert MaskRcnn.
I Downloaded the tao-converter binary for Jetpack 4.6 from this link https://developer.nvidia.com/jp46-20210820t231431z-001zip
Ran the binary with parameters as mentioned:
./tao-converter -k nvidia_tlt \
> -d 3,448,832 \
> -i nchw \
> -t fp16 \
> -b 1 \
> -m 1 \
> -o generate_detections, mask_fcn_logits/BiasAdd \
> -e ../trtis_model_repo_sample_1/maskrcnn/1/maskrcnn_model.plan \
> ./models/maskrcnn/model.step-10200.etlt
It crashes with this error:
[INFO] [MemUsageChange] Init CUDA: CPU +353, GPU +0, now: CPU 371, GPU 14886 (MiB)
[ERROR] UffParser: Validator error: pyramid_crop_and_resize_mask: Unsupported operation _MultilevelCropAndResize_TRT
[ERROR] Failed to parse the model, please check the encoding key to make sure it's correct
[ERROR] 4: [network.cpp::validate::2411] Error Code 4: Internal Error (Network must have at least one output)
[ERROR] Unable to create engine
The same model is converted successfully with trt 7. Seems like required plugins for Mask RCNN can be found only with trt 7.
Am I missing some steps to convert maskrcnn tao model in trt 8 in jetson 4.6 ?
Thank you!
