I attempted to use the mass flash tool in the L4T but I get the following while generation the signed binary:
copying tegrarcm_v2 … cp: cannot stat ‘…/tegrarcm_v2’: No such file or directory
failed.
@linuxdev @JerryChang
see attached log.
How can I solve this
nvmassflass_log (13.4 KB)
I don’t have any experience with mass flash. One thing I do see though, is that the file it cannot find is part of the host PC flash software. If you cd
to:
~/nvidia/nvidia_sdk/JetPack_...version.../Linux_for_Tegra/bootloader/
…what do you then see for:
ls -l ./tegrarcm_v2
Hi @ridwanriley,
Hope you are doing well. I saw that you are using a Jetson Nano board with emmc. Maybe you can try follow the instructions in How to fast flash jetson nano module - #2 by andres.campos, from step 3.1.
I hope this information is of value to you. Please, let us know how it goes!
Eduardo Salazar
Embedded SW Engineer at RidgeRun
Contact us: support@ridgerun.com
Developers wiki: https://developer.ridgerun.com/
Website: www.ridgerun.com
Thanks @linuxdev .
I have been able to resolve this issue and generated the image but it can’t get flashed to the device.
See attached the log of the mass imageblob generation
mass_flash_log (17.3 KB)
However, it fails whenever I try to flash the board with the Image using:
sudo ./nvmflash.sh --showlogs
See attached flash_log_mass
flash_log_mass (1.6 KB)
and mfi_log.
I also noticed that if I use -y PKC flag with my nvmassflashgen script like so:
sudo ./nvmassflashgen.sh -x 0x21 -u rsa_priv.pem jetson-nano-emmc mmcblk0p1
it fails; from the errors, it shows that the -y flag is not available for the command but this command is stated in the Linux_for_Tegra/README_Massflash.txt
mfi_log (2.7 KB)
Thanks for your response @EduardoSalazar96.
I will try the guide and revert.
@EduardoSalazar96
Thanks for sharing the link, it would improve my development cycle.
However, I already enabled secure boot on this device; so I have to provide keys when flashing the Image to the board, which I already did.
From the mfi_log (attached above), I can see that ebt verification failed, I don’t know why this is happening despite providing private key while generating the flash blob.
Maybe I am missing something here.
@JerryChang @linuxdev @EduardoSalazar96
hello ridwanriley,
it looks you got failure when creating a massflash image tarball.
this tegrarcm_v2
is included in the default Jetpack release image.
what’s your environment setup for running the process?
you may using SDK Manager - NVIDIA Developer to setup the development environment.
@JerryChang
Yes, I was getting this error Initially but the error went away after signing the images using the --no-flash flag.
Now, I can generate mass flash blobs but it does not get flashed to the board successfully. Please take a look at the attached logs.
There is no log at your post, please check again. Thanks
I mean the logs attached to my first post, see the attachment named flash_log_mass.
@kayccc
Hi @ridwanriley
Sorry for the late response. I do not really sure why …/tegrarcm_v2
, in order to do that I need to replicate the issue on my side, and at this moment I do not have a Jetson Nano with emmc on my side. Sorry about that.
I hope you can solve this issue.
Best regards,
Eduardo.
@EduardoSalazar96 ,
Thanks for your response.
The task has been deprioritized for now, will pick it up sometimes later.
Appreciate your contribution.
