Mass production
jetson agx industrial module, when production environment, always prompt to enter the RCM mode, but already entered the RCM mode, still prompt to enter the rcm mode, running the mass production command.
Hi @Olivia798, which Jetson AGX is this, Orin or Xavier? Depending on this I would recommend we move this post to the dedicated category for that device. That way the right people will have visiblity.
I moved this for you.
Hi 77097962,
It seems you are using the custom carrier board for Xavier industrial.
Do you get the custom BSP package from your vendor?
Have you tried to use flash.sh script to flash your board?
Could you help to share the result of the following command on your board?
cat /etc/nv_boot_control.conf
It seems you are using Jetson AGX Xavier Industrial module (P2888-0008).
Please get the custom BSP package with latest R32.7.3 or R35.3.1 for your custom carrier board.
Could you use the flash command to flash your board in RCM state?
If yes, please provide the flash log for further check.
Have you tried the following command to generate the package for Xavier Industrial?
sudo ./nvmassflashgen.sh jetson-agx-xavier-industrial mmcblk0p1
