Hi all, I’ve configured UMS on a Xavier and provided an ext4 filesystem for it to use in read-only mode. I’ve successfully been able to connect a Macbook and read from the filesystem by using osxfuse and ext4fuse, so that’s great. The problem I’m running into is that MacOS is not able to detect any information about the partitions when using diskutil (type, name, etc.). I’ve added a label to the filesystem partition on the Xavier, but seemingly the information does not get communicated when using mass storage mode.
The filesystem I’m pointing to is an M.2 SSD partitioned as ext4, located at /dev/nvme0n1p1.
Am I missing a step in the labeling of my filesystem, is this a limitation with MacOS, or is there something missing in the Xavier configuration?
On the Xavier:
user@xavier ~ $ df -h
Filesystem Size Used Avail Use% Mounted on
/dev/mmcblk0p1 28G 14G 13G 51% /
none 7.7G 0 7.7G 0% /dev
tmpfs 7.7G 84K 7.7G 1% /dev/shm
tmpfs 7.7G 22M 7.7G 1% /run
tmpfs 5.0M 4.0K 5.0M 1% /run/lock
tmpfs 7.7G 0 7.7G 0% /sys/fs/cgroup
/dev/nvme0n1p1 912G 22G 844G 3% /var
tmpfs 1.6G 0 1.6G 0% /run/user/1000
user@xavier ~ $ sudo lsblk -o NAME,LABEL
NAME LABEL
loop0 data
nvme0n1
|-nvme0n1p1 data
`-nvme0n1p2
Disk /dev/nvme0n1: 931.5 GiB, 1000204886016 bytes, 1953525168 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: dos
Disk identifier: 0x12ca4ad8
Device Boot Start End Sectors Size Id Type
/dev/nvme0n1p1 2048 1945136560 1945134513 927.5G 83 Linux
/dev/nvme0n1p2 1945137152 1953525167 8388016 4G 82 Linux swap / Solaris
MacOS:
❯❯❯ diskutil list
/dev/disk0 (internal, physical):
#: TYPE NAME SIZE IDENTIFIER
0: GUID_partition_scheme *500.3 GB disk0
1: EFI EFI 314.6 MB disk0s1
2: Apple_APFS Container disk1 500.0 GB disk0s2
/dev/disk1 (synthesized):
0: APFS Container Scheme - +500.0 GB disk1
Physical Store disk0s2
1: APFS Volume Macintosh HD - Data 322.7 GB disk1s1
2: APFS Volume Preboot 84.5 MB disk1s2
3: APFS Volume Recovery 528.1 MB disk1s3
4: APFS Volume VM 3.2 GB disk1s4
5: APFS Volume Macintosh HD 11.0 GB disk1s5
/dev/disk2 (external, physical):
0: *995.9 GB disk2
