To address the question of generating an encrypted disk image without a Jetson connected, and to understand the expected flow for producing an artifact representing an image version, we need to break down the process and requirements.
Generating Encrypted Disk Image without a Jetson Connected:
The Jetson Linux reference implementation only generates per-device encrypted disk images. This means that the encryption process is tied to the specific device’s ECID (Electronic Chip ID), which is unique to each device. The ECID is used to derive the encryption key, ensuring that the encrypted image can only be decrypted on the specific device it was generated for.
However, as mentioned in the question, this approach has limitations, particularly when it comes to mass production and flashing multiple devices simultaneously. The requirement for an unattended unlock via hardware, such as binding to TPM (Trusted Platform Module) PCR (Platform Configuration Registers) registries, further complicates the process.
To generate an encrypted disk image without a Jetson connected, you would need to modify the encryption process to use a generic passphrase or key, rather than relying on the device’s ECID. This approach would allow you to create a single encrypted image that can be flashed to multiple devices.
Expected Flow for Producing an Artifact Representing an Image Version:
The expected flow for producing an artifact representing an image version would involve the following steps:
- Development Environment: Developers would create and configure the image version in a development environment, using tools such as the Jetson Linux reference implementation.
- Artifact Generation: The developers would generate an artifact representing the image version, which would include the encrypted disk image, as well as any necessary metadata, such as the encryption key or passphrase.
- Artifact Deployment: The artifact would be deployed to the factory flashing computers, where it would be used to flash the devices.
- Device Flashing: The devices would be flashed with the encrypted image, using the artifact as the source.
Comparison of Approaches:
There are two main approaches to consider:
- Per-Device Encryption: This approach uses the device’s ECID to derive the encryption key, ensuring that the encrypted image can only be decrypted on the specific device it was generated for. This approach is secure, but it has limitations when it comes to mass production and flashing multiple devices simultaneously.
- Generic Passphrase or Key: This approach uses a generic passphrase or key to encrypt the disk image, allowing for a single encrypted image to be created that can be flashed to multiple devices. This approach is more flexible, but it may compromise security if the passphrase or key is not properly managed.
Conclusion:
Generating an encrypted disk image without a Jetson connected requires modifying the encryption process to use a generic passphrase or key. The expected flow for producing an artifact representing an image version involves generating an artifact in a development environment, deploying it to the factory flashing computers, and flashing the devices with the encrypted image. The choice of approach depends on the specific requirements and constraints of the production environment.
