Massflash preferred usb hub
I’m planning on setting up a massflash station for our Orinx NXs. Ideally I need a usb hub that allows the flashing of 5 devices in parallel.
Can I get a hub recommendation + cables that works for you?
Many thanks.
Hi rono2,
We do not qualify or recommend specific third-party USB hubs or cables for massflash. Our internal validation connects each Jetson directly to a host USB port, so I can’t point you to a tested hub model.
One thing is to make sure the cable supporting data transfer.
