Hi @JerryChang,
Now I got Error: Return value 19
when running following command:
sudo ROOTFS_ENC=1 BOARDID=3668 BOARDSKU=0001 FAB=300 BOARDREV=B.0 ./tools/kernel_flash/l4t_initrd_flash.sh --no-flash --external-device nvme0n1p1 -S 200GiB -c ./tools/kernel_flash/flash_l4t_nvme_rootfs_enc.xml --external-only --massflash 5 --append jetson-xavier-nx-devkit-emmc external
Full log:
external.log (158.0 KB)
The full procedure I followed as below:
- Reset
Linux_for_Tegra
cd ~/nvidia/4.6.1
sudo rm -rf ./Linux_for_Tegra ./trusty
tar xf ./jetson_linux_r32.7.1_aarch64.tbz2
tar xvjf ./secureboot_r32.7.1_aarch64.tbz2
cd ./Linux_for_Tegra/rootfs
sudo tar xpf ../../tegra_linux_sample-root-filesystem_r32.7.1_aarch64.tbz2
cd ..
sudo ./apply_binaries.sh
# create a defult user
sudo ./tools/l4t_create_default_user.sh -u nvidia -p nvidia -n nvidia --accept-license
cd ..
tar xvf ./public_sources.tbz2
tar xvf ./Linux_for_Tegra/source/public/trusty_src.tbz2
- Update sector size in partition layout
. For 232GiB NVMe storage, use 488397168
as num_sectors
<?xml version="1.0"?>
<!-- Nvidia Tegra Partition Layout Version 1.0.0 -->
<partition_layout version="01.00.0000">
<device type="nvme" instance="0" sector_size="512" num_sectors="488397168">
<partition name="master_boot_record" type="protective_master_boot_record">
- Modified
disk_encryption_helper.func
bootpartuuid="";
bootpartuuid_ext=""
bootpartuuid_b_ext=""
bootpartuuidfile="${BL_DIR}/l4t-bootpart-uuid.txt";
uuidfile="${BL_DIR}/l4t-uuid.txt"
enc_user_disk_list=();
if [ ${rootfs_ab} -eq 1 ]; then
bootpartuuid_b="";
fi;
# Generate the partition UUID of the boot partition
function bootpartuuid_gen() {
local __boot_id="${1}";
local __uuid="";
local __uuidgen_installed="$(which uuidgen || true)";
if [ "${__uuidgen_installed}" == "" ]; then
echo "Error: uuidgen not installed! Please provide the UUID or install"
echo "uuidgen. For example, to install uuidgen for Ubuntu distributions,"
echo "execute the command 'sudo apt install uuid-runtime'. Otherwise a"
echo "UUID can be provided by storing a UUID to the file"
echo "${bootpartuuidfile}."
usage allunknown 1;
fi;
__uuid="$(uuidgen)";
setval "bootpartuuid${__boot_id}" __uuid;
echo "${__uuid}" > "${bootpartuuidfile}${__boot_id}"
echo "Generated UUID ${__uuid} for mounting boot APP${__boot_id} partition."
# Check the partition UUID of the boot partition
function bootpartuuid_chk_and_gen() {
local __uuid="";
local __uuid_regex="([0-9a-f]{8}-[0-9a-f]{4}-[0-9a-f]{4}-[0-9a-f]{4}-[0-9a-f]{12})";
# read UUID which stored in the file ${bootpartuuidfile} if the file exist
if [ -f "${bootpartuuidfile}${__boot_id}" ]; then
__uuid="$(sed -nr "s/^${__uuid_regex}$/\1/p" "${bootpartuuidfile}${__boot_id}")";
if [ "${#__uuid}" != "36" ]; then
echo "File ${bootpartuuidfile}${__boot_id} contains invalid UUID!"
usage allunknown 1;
fi;
echo "Using UUID ${__uuid} for mounting boot APP${__boot_id} partition."
fi;
# generate UUID if ${bootpartuuidfile} isn't present
eval __uuid='$'{"bootpartuuid${__boot_id}"};
if [ "${__uuid}" == "" ]; then
bootpartuuid_gen "${__boot_id}";
fi;
# Restore the partition UUID of the boot partition
function bootpartuuid_restore() {
local ext="${1}"
local _bootpartuuid="bootpartuuid${ext}"
local _bootpartuuid_b
bootpartuuid_chk_and_gen "${ext}";
if [[ "${rootfs_ab}" == 1 ]]; then
# get UUID for APP_b
_bootpartuuid_b="bootpartuuid_b${ext}"
bootpartuuid_chk_and_gen "_b${ext}";
fi
if [[ "${!_bootpartuuid}" == "" ]] || \
[[ "${rootfs_ab}" == 1 && "${!_bootpartuuid_b}" == "" ]]; then
echo "No UUID found for boot partition! If the boot partition"
echo "is not currently being mounted using a partition UUID,"
echo "then flash the device by specifying the boot device that"
echo "was specified when previously flashing the entire system"
echo "(eg. /dev/mmcblk0p1). Otherwise, to mount the boot"
echo "partition using a partition UUID please either:"
echo "1. If you know the UUID for the root partition save it"
echo " to the file ${bootpartuuidfile},"
echo " or for boot B partition save it"
echo " to the file ${bootpartuuidfile}_b"
echo "2. Re-flash entire system to generate a new UUID."
usage allunknown 1;
fi;
# Common UUID gen function
function uuid_gen() {
local __name="${1}";
local __ret_uuid="${2}";
local __uuid="";
local uuidgen_installed="$(which uuidgen || true)";
if [ "${uuidgen_installed}" == "" ]; then
echo "${uuidfile}."
usage allunknown 1;
fi
setval "${__ret_uuid}" __uuid;
echo "${__uuid}" > "${uuidfile}_${__name}";
echo "Generated UUID ${__uuid} for mounting ${__name} partition.";
# Common UUID chk and gen function
function uuid_chk_and_gen() {
local __uuid="";
# Read UUID which stored in the file ${uuidfile} if the file exist.
if [ -f "${uuidfile}_${__name}" ]; then
__uuid="$(sed -nr "s/^${__uuid_regex}$/\1/p" "${uuidfile}_${__name}")";
echo "File ${uuidfile}_${__name} contains invalid UUID!";
usage allunknown 1;
fi
echo "Using UUID ${__uuid} for mounting ${__name} partition."
else
# Generate UUID if ${uuidfile} isn't present.
uuid_gen "${__name}" "${__ret_uuid}";
fi;
# Common UUID restore function
function uuid_restore {
uuid_chk_and_gen "${__name}" "${__ret_uuid}";
# Prepare dependent binary list for LUKS disk encrytption suport
function prepare_luks_bin_list() {
# Usage:
# prepare_luks_bin_list {__ldk_path} \
# {__rootfs_path} \
# {__bin_list}
# This will set up the dependent binaries into {__bin_list}.
local __ldk_path="${1}";
local __rootfs_path="${2}";
local __bin_list="${3}";
local __QEMU_BIN="";
local __libs_str="";
local __libs_list=();
# Check qemu
if [ -f "${__ldk_path}/../qemu-aarch64-static" ]; then
__QEMU_BIN="${__ldk_path}/../qemu-aarch64-static";
elif [ -f "/usr/bin/qemu-aarch64-static" ]; then
__QEMU_BIN="/usr/bin/qemu-aarch64-static";
else
if [ -z "${__QEMU_BIN}" ]; then
echo "ERROR qemu not found! To install - please run: " \
"\"sudo apt-get install qemu-user-static\""
exit 1
fi;
fi;
# Check rootfs
if [ ! -e "${__rootfs_path}/etc/lsb-release" ]; then
echo "rootfs has not been extracted."
exit 1
fi;
# Install QEMU to rootfs
install --owner=root --group=root "${__QEMU_BIN}" "${__rootfs_path}/usr/bin/"
# Get the dependent binary list
pushd "${__rootfs_path}" > /dev/null 2>&1;
__libs_str="$(LC_ALL=C chroot . ldd /sbin/cryptsetup)";
popd > /dev/null 2>&1;
__libs_str="$(echo "${__libs_str}" | awk '{print $(NF-1)}')";
__libs_list=(${__libs_str// /});
eval "${__bin_list}=("${__libs_list[@]}")";
# Clean up
rm -f "${__rootfs_path}/usr/bin/qemu-aarch64-static";
# Update the initrd for LUKS support
function prepare_luks_initrd() {
# Usage:
# prepare_luks_initrd {__kernelinitrd} \
# {__rootfs_path} \
# {__rootfsuuid} \
# {__bin_list}
# This script assume that it is in the folder where the initrd is extracted.
# This script modify the content of initrd.
local __params=("${@}");
local __kernelinitrd="${__params[0]}";
local __rootfs_path="${__params[1]}";
local __rootfsuuid="${__params[2]}";
local __params_len=${#__params[@]};
local __bin_list=();
local script_name=prepare_luks_initrd;
echo "${script_name}: Begin to copy binaries into initrd"
for ((i=3; i<${__params_len}; i++)); do
__bin_list+=("${__params[${i}]}")
done
if [ ! -e "${__kernelinitrd}" ]; then
echo "${script_name}: initrd doesn't exist? "
return 1
fi
echo "${script_name}: rootfs has not been extracted"
return 1
fi
# Extract the initrd
gunzip -c "${__kernelinitrd}" | cpio -i
if [ $? -ne 0 ]; then return 1; fi
local src;
local dst;
# Copy all the binaries
install -o 0 -g 0 -m 0755 -d "lib/cryptsetup"
for bin in "${__bin_list[@]}"
do
src="${__rootfs_path}${bin}"
if [[ ${bin} == *"lib"* ]]; then
dst="lib/cryptsetup/";
elif [[ ${bin} == *"sbin"* ]]; then
dst="sbin/";
fi;
install -o 0 -g 0 -D "${src}" "${dst}"
done
# Add /etc/crypttab
echo "crypt_root UUID=${__rootfsuuid}" > etc/crypttab
for enc_usr_disk in "${enc_user_disk_list[@]}"
do
local __dm_name;
local __fsuuid;
__dm_name="$(echo "${enc_usr_disk}" | awk -F " " '{print $1}')";
__fsuuid="$(echo "${enc_usr_disk}" | awk -F " " '{print $2}')";
echo "${__dm_name} UUID=${__fsuuid}" >> etc/crypttab;
done
# Add locking path /run/cryptsetup
install -o 0 -g 0 -m 0755 -d "run/cryptsetup"
# Package the initrd
find . | cpio -H newc -o | gzip -9 -n > "${__kernelinitrd}"
echo "${script_name}: Finish copying binaries into initrd"
# Validate FS size
function validate_fs_size () {
local __fssize="${1}";
local __bcnt=$(( ${__fssize} / 512 ));
local __bcntdiv=$(( ${__fssize} % 512 ));
if [ ${__bcnt} -eq 0 ] || [ ${__bcntdiv} -ne 0 ]; then
echo "Error: file system size has to be 512 bytes allign.";
exit 1;
fi;
# Create disk image with specific pattern
function create_disk_image_with_pattern () {
local __pattern="${1}";
local __imgfile="${2}";
local __fssize="${3}";
if [ -f "${__imgfile}" ]; then
rm -f "${__imgfile}";
fi;
if [ "${__pattern}" != "" ] && [ "${__pattern}" != "0" ]; then
local __fc=$(printf '%d' ${__pattern});
local __fillc=$(printf \\\\$(printf '%02o' ${__fc}));
< /dev/zero head -c ${__fssize} | tr '\000' ${__fillc} > ${__imgfile};
chkerr "making ${__imgfile} with fillpattern($__fillc}) failed.";
else
truncate --size ${__fssize} ${__imgfile};
chkerr "making ${__imgfile} with zero fillpattern failed.";
fi;
# Convert to sparse image
function convert_to_sparse_image () {
if [ "${__pattern}" != "" ] && [ -x mksparse ]; then
echo -e -n "\tConverting RAW image to Sparse image... ";
mv -f "${__imgfile}" "${__imgfile}.raw";
if [ "${BLBlockSize}" != "" ]; then
blblksizeoption="-b $BLBlockSize";
fi;
./mksparse ${blblksizeoption} --fillpattern=${__pattern} ${__imgfile}.raw ${__imgfile}; chkerr;
fi;
# Building the boot file system image for boot partition (APP)
function build_boot_fsimg () {
local __localsysfile="${1}";
local __fillpat="${2}";
local __bootfssize="${3}";
local __bootfs_type="${4}";
local __bootfs_dir="${5}";
local __cmdline="${6}";
local __do_sign="${7}";
local _extlinux_conf="extlinux/extlinux.conf"
echo "Making ${__localsysfile}... ";
validate_fs_size "${__bootfssize}";
if [ ! -f "${__bootfs_dir}/${_extlinux_conf}" ]; then
echo "${__bootfs_dir}/${_extlinux_conf} is not found, exiting...";
exit 1
fi;
create_disk_image_with_pattern "${__fillpat}" "${__localsysfile}" "${__bootfssize}";
loop_dev="$(losetup --show -f "${__localsysfile}")";
chkerr "mapping ${__localsysfile} to loop device failed.";
mkfs -t ${__bootfs_type} "${loop_dev}" > /dev/null 2>&1;
chkerr "formating ${__bootfs_type} filesystem on ${__localsysfile} failed.";
mkdir -p mnt;
chkerr "make ${__localsysfile} mount point failed.";
mount "${loop_dev}" mnt;
chkerr "mount ${__localsysfile} failed.";
# Processing partition data.
mkdir -p "mnt/dtb"; chkerr "make ${__localsysfile}/dtb failed.";
cp -f "${kernel_fs}" "mnt";
chkerr "Copying ${kernel_fs} failed.";
if [ -f "${dtbfilename}" ]; then
cp -f "${dtbfilename}" "mnt/dtb/${dtbfilename}";
chkerr "populating ${dtbfilename} to ${__localsysfile}/dtb failed.";
fi;
pushd mnt > /dev/null 2>&1;
echo -n -e "\tpopulating bootfs from ${__bootfs_dir} ... ";
(cd ${__bootfs_dir}; tar cf - *) | tar xf - ; chkerr;
# Populate extlinux.conf if "${__cmdline}" exists
if [ "${__cmdline}" != "" ]; then
# Add the "${__cmdline}" at the APPEND line if it does not exist.
echo -n -e "\tpopulating ${_extlinux_conf} ... ";
rootfs_found=$(grep -cE "${__cmdline}" "./${_extlinux_conf}");
if [ "${rootfs_found}" == "0" ];then
sed -i "/^[ \t]*APPEND/s|\$| ${__cmdline}|" "./${_extlinux_conf}";
chkerr;
fi;
fi;
if [ "${__do_sign}" = "True" ]; then
local kernel_fs_basename;
kernel_fs_basename=$(basename "${kernel_fs}");
echo -n -e "\tgenerating sig file of ${kernel_fs_basename} ... ";
signimage "./${kernel_fs_basename}" "True" "kernel" "${minratchet_configname}"; chkerr;
echo -n -e "\tgenerating sig file of ${dtbfilename} ... ";
signimage "./dtb/${dtbfilename}" "True" "kernel_dtb" "${minratchet_configname}"; chkerr;
echo -n -e "\tgenerating sig file of initrd ... ";
signimage "./initrd" "True" "data"; chkerr;
echo -n -e "\tgenerating sig file of ${_extlinux_conf} ... ";
# Signing tool will pad extlinux.conf with 0x80 to be 16-byte aligned.
# This pad byte of 0x80 may cause some utilities fail to read the entire
# extlinux.conf.
# So, pad extlinux.conf to 16-byte aligned with linefeed.
pad_file_aligned "${_extlinux_conf}" 16 "\x0a";
signimage "${_extlinux_conf}" "True" "data"; chkerr;
fi
# Create a symbolic link of boot dir, so bootloader can find binaries
# in /boot under boot partition
ln -s ./ ./boot;
echo -e -n "\tSync'ing ${__localsysfile} ... ";
sync; sync; sleep 5; # Give FileBrowser time to terminate gracefully.
echo "done.";
umount mnt > /dev/null 2>&1;
losetup -d "${loop_dev}" > /dev/null 2>&1;
rmdir mnt > /dev/null 2>&1;
convert_to_sparse_image "${__fillpat}" "${__localsysfile}";
echo "${__localsysfile} built successfully. ";
# Building the encrypted root file system image for APP_ENC partition
function build_enc_root_fsimg () {
local __rootfssize="${3}";
local __rootfs_type="${4}";
local __rootfs_dir="${5}";
local __rootfsuuid="${6}";
local __bootpartuuid="${7}";
local __ecid="${8}";
local CRYPTSETUP_BIN="";
local GEN_LUKS_PASS_CMD="";
# Check cryptsetup
if [ -f "/sbin/cryptsetup" ]; then
CRYPTSETUP_BIN="/sbin/cryptsetup";
else
if [ -z "${CRYPTSETUP_BIN}" ]; then
echo "ERROR cryptsetup not found! To install - please run: " \
"\"sudo apt-get install cryptsetup\""
exit 1
fi;
fi;
# Check ECID
#if [ "${__ecid}" == "" ]; then
# echo "ERROR: build_enc_root_fsimg: ECID is null ."
# exit 1
#fi;
# Check gen_luks_passphrase.py
local genpass_dir="${LDK_DIR}/tools/disk_encryption";
local genpass_opt="";
GEN_LUKS_PASS_CMD="${genpass_dir}/gen_luks_passphrase.py";
if [ ! -f "${GEN_LUKS_PASS_CMD}" ]; then
echo "ERROR ${GEN_LUKS_PASS_CMD} is not found."
exit 1
fi;
if [ "${enc_rfs_keyfile}" != "" ]; then
genpass_opt+="-k \"${enc_rfs_keyfile}\" ";
fi;
#genpass_opt+="-u -e '${__ecid}' "
#genpass_opt+="-c '${__rootfsuuid}'";
genpass_opt+="-g -c 'generic-key' "
GEN_LUKS_PASS_CMD+=" ${genpass_opt}";
validate_fs_size "${__rootfssize}";
create_disk_image_with_pattern "${__fillpat}" "${__localsysfile}" "${__rootfssize}";
local __l4t_enc_root_dm="l4t_enc_root";
local __l4t_enc_root_dm_dev="/dev/mapper/${__l4t_enc_root_dm}"
# Add the LUKS header
eval ${GEN_LUKS_PASS_CMD} | ${CRYPTSETUP_BIN} \
--type luks1 \
-c aes-cbc-essiv:sha256 \
-s 128 \
--uuid "${__rootfsuuid}" \
luksFormat \
${loop_dev};
chkerr "Add LUKS header on ${__localsysfile} failed.";
# Unlock the encrypted root image
if [ -e "${__l4t_enc_root_dm_dev}" ]; then
umount "${__l4t_enc_root_dm_dev}"
${CRYPTSETUP_BIN} luksClose ${__l4t_enc_root_dm}
fi
luksOpen ${loop_dev} ${__l4t_enc_root_dm};
chkerr "Unlock ${__localsysfile} failed.";
mkfs -t ${__rootfs_type} ${__l4t_enc_root_dm_dev} > /dev/null 2>&1;
chkerr "formating ${__rootfs_type} filesystem on ${__localsysfile} failed.";
mkdir -p mnt;
mount ${__l4t_enc_root_dm_dev} mnt;
echo -n -e "\tpopulating rootfs from ${__rootfs_dir} ... ";
(cd ${__rootfs_dir}; tar --exclude=boot -cf - *) | tar xf - ; chkerr;
# Update root in /etc/fstab
cp etc/fstab etc/fstab.tmp;
head -n -1 etc/fstab.tmp > etc/fstab;
echo "/dev/mapper/crypt_root / ext4 defaults 0 1" >> etc/fstab;
rm etc/fstab.tmp;
# Update /etc/fstab if "${__bootpartuuid}" exists
if [ "${__bootpartuuid}" != "" ]; then
echo "PARTUUID=${__bootpartuuid} /boot ext4 defaults 0 1" >> etc/fstab;
fi;
# Update /etc/fstab and add mount point if ${enc_user_disk_list} is not empty
do
local __dm_name;
mkdir -p "mnt/${__dm_name}";
echo "/dev/mapper/${__dm_name} /mnt/${__dm_name} ext4 defaults 0 2" >> etc/fstab;
done
echo "done.";
${CRYPTSETUP_BIN} luksClose ${__l4t_enc_root_dm};
# Building a common encrypted file system image
function build_enc_fsimg () {
local __fs_type="${4}";
local __fsuuid="${5}";
local __ecid="${6}";
local __src_dir="${7}";
# Check cryptsetup
else
"\"sudo apt-get install cryptsetup\"";
exit 1;
fi;
fi;
# Check ECID
# echo "ERROR: build_enc_fsimg: ECID is null .";
# exit 1;
#fi;
echo "ERROR ${GEN_LUKS_PASS_CMD} is not found.";
exit 1;
fi;
fi;
validate_fs_size "${__fssize}";
create_disk_image_with_pattern "${__fillpat}" "${__localsysfile}" "${__fssize}";
local __l4t_enc_disk_dm="l4t_enc_disk";
local __l4t_enc_disk_dm_dev="/dev/mapper/${__l4t_enc_disk_dm}"
# Add the LUKS header.
--type luks1 \
-s 128 \
--uuid "${__fsuuid}" \
luksFormat \
${loop_dev};
# Unlock the encrypted filesystem image.
if [ -e "${__l4t_enc_disk_dm_dev}" ]; then
umount ${__l4t_enc_disk_dm_dev}
${CRYPTSETUP_BIN} luksClose ${__l4t_enc_disk_dm}
fi
luksOpen ${loop_dev} ${__l4t_enc_disk_dm};
mkfs -t ${__fs_type} ${__l4t_enc_disk_dm_dev} > /dev/null 2>&1;
chkerr "formating ${__fs_type} filesystem on ${__localsysfile} failed.";
mkdir -p mnt;
mount ${__l4t_enc_disk_dm_dev} mnt;
if [ "${__src_dir}" != "" ]; then
echo -n -e "\tpopulating fs from ${__src_dir} ... ";
(cd ${__src_dir}; tar -cf - *) | tar xf - ; chkerr;
fi;
echo "done.";
${CRYPTSETUP_BIN} luksClose ${__l4t_enc_disk_dm};
# Create a encrypted user disk image if the attribuate "encrypted" is true.
function create_enc_user_disk() {
local __disk_name="${1}";
local __cfg_file="${2}";
local __fillpat="${3}";
local __ecid="${5}";
local __src_dir="${6}"
local __disk_ext="${7}"
local __disk_enc_enabled="false";
get_attr_from_PT_table "${__disk_name}" "encrypted" "${__cfg_file}" __disk_enc_enabled;
if [ "${__disk_enc_enabled}" == "true" ]; then
local __disk_size;
local __img_name;
local __fs_uuid;
# Prepare parameters for UDA disk encryption.
uuid_restore "${__disk_name}${__disk_ext}" __fs_uuid;
get_value_from_PT_table "${__disk_name}" "size" "${__cfg_file}" __disk_size;
get_value_from_PT_table "${__disk_name}" "filename" "${__cfg_file}" __img_name;
# Store disk name and UUID in the list.
enc_user_disk_list+=("crypt_${__disk_name} ${__fs_uuid}");
# Build encrypted UDA disk image.
if [ "${target_partname}" = "" ]; then
build_enc_fsimg "${__img_name}" "${__fillpat}" "${__disk_size}" \
"${__fs_type}" "${__fs_uuid}" "${__ecid}" \
"${__src_dir}";
fi;
fi;
- Used common ECID in
flash.sh
# ECID=$(./${rcmcmd} ${inst_args} --uid | grep BR_CID | cut -d' ' -f2);
ECID="0x880219116404c0831800000009038240"
- Updated
initrd
#!/bin/bash
# Copyright (c) 2014-2020, NVIDIA CORPORATION. All rights reserved.
# Redistribution and use in source and binary forms, with or without
# modification, are permitted provided that the following conditions
# are met:
# * Redistributions of source code must retain the above copyright
# notice, this list of conditions and the following disclaimer.
# * Redistributions in binary form must reproduce the above copyright
# notice, this list of conditions and the following disclaimer in the
# documentation and/or other materials provided with the distribution.
# * Neither the name of NVIDIA CORPORATION nor the names of its
# contributors may be used to endorse or promote products derived
# from this software without specific prior written permission.
# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS ``AS IS'' AND ANY
# EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
# PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
# CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
# EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
# PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR
# PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY
# OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
# (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
# OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
initrd_dir=/mnt/initrd;
dhclient_flag="true";
count=0;
echo "Starting L4T initial RAM disk" > /dev/kmsg;
#Mount procfs, devfs, sysfs and debugfs
mount -t proc proc /proc
echo "ERROR: mounting proc fail..." > /dev/kmsg;
exec /bin/bash;
fi;
mount -t devtmpfs none /dev
echo "ERROR: mounting dev fail..." > /dev/kmsg;
exec /bin/bash;
fi;
mount -t sysfs sysfs /sys
echo "ERROR: mounting sys fail..." > /dev/kmsg;
exec /bin/bash;
fi;
mount -t debugfs none /sys/kernel/debug/
echo "ERROR: mounting debugfs fail..." > /dev/kmsg;
exec /bin/bash;
fi;
# create reboot command based on sysrq-trigger
if [ -e "/proc/sysrq-trigger" ]; then
echo -e "#!/bin/bash \necho b > /proc/sysrq-trigger;" > /sbin/reboot;
chmod 755 /sbin/reboot;
fi;
dev_regex='root=\/dev\/[abcdefklmnpsv0-9]*'
uuid_regex='root=PARTUUID=[0-9a-f]{8}-[0-9a-f]{4}-[0-9a-f]{4}-[0-9a-f]{4}-[0-9a-f]{12}'
rootdev="$(cat /proc/cmdline | grep -oE "\<${dev_regex}|${uuid_regex}\>" | tail -1)"
if [ "${rootdev}" != "" ]; then
if [[ "${rootdev}" =~ "PARTUUID" ]]; then
rootdev=$(echo "${rootdev}" | sed -ne "s/root=\(.*\)/\1/p")
else
rootdev=$(echo "${rootdev}" | sed -ne "s/root=\/dev\/\(.*\)/\1/p")
fi
echo "Root device found: ${rootdev}" > /dev/kmsg;
fi
if [ -e "/etc/crypttab" ]; then
ext4uuid_regex='root=UUID=[0-9a-f]{8}-[0-9a-f]{4}-[0-9a-f]{4}-[0-9a-f]{4}-[0-9a-f]{12}';
encrootcmd="$(cat /proc/cmdline | grep -oE "\<${dev_regex}|${ext4uuid_regex}\>" | tail -1)";
rootext4uuid="$(echo ${encrootcmd} | awk -F "=" '{print $3}')";
while read crypttab_line
do
enc_dm_name="$(echo "${crypttab_line}" | awk -F " " '{print $1}')";
crypt_dev="$(echo "${crypttab_line}" | awk -F " " '{print $2}')";
crypt_disk_uuid="$(echo "${crypt_dev}" | awk -F "=" '{print $2}')";
enc_dev_match_root=$(echo "${crypt_dev}" | grep -cE "${rootext4uuid}");
enc_dev=$(blkid | grep -E "${crypt_disk_uuid}" | awk -F ":" '{print $1}');
# isLuks
LD_LIBRARY_PATH="/lib/cryptsetup" \
/lib/cryptsetup/ld-linux-aarch64.so.1 \
/sbin/cryptsetup isLuks "${enc_dev}";
echo "ERROR: encrypted dev ${enc_dev} is not LUKS device.";
exec /bin/bash;
fi;
# Unlock the encrypted dev
nvluks-srv-app -g -c 'generic-key' | LD_LIBRARY_PATH="/lib/cryptsetup" \
/sbin/cryptsetup luksOpen "${enc_dev}" "${enc_dm_name}";
echo "ERROR: fail to unlock the encrypted dev ${enc_dev}.";
exec /bin/bash;
fi;
if [ ${enc_dev_match_root} -eq 1 ]; then
mount "/dev/mapper/${enc_dm_name}" /mnt/;
else
mount "/dev/mapper/${enc_dm_name}" "/mnt/mnt/${enc_dm_name}";
fi;
done < /etc/crypttab;
elif [[ "${rootdev}" == PARTUUID* ]]; then
count=0;
while [ ${count} -lt 50 ]; do
sleep 0.2;
count="$(expr ${count} + 1)"
mount "${rootdev}" /mnt/;
if [ $? -eq 0 ]; then
break;
fi
done
mountpoint /mnt/;
echo "ERROR: ${rootdev} mount fail..." > /dev/kmsg;
exec /bin/bash;
fi;
elif [[ "${rootdev}" == mmcblk* || "${rootdev}" == nvme* ]]; then
if [ ! -e "/dev/${rootdev}" ]; then
count=0;
do
sleep 0.2;
count=`expr $count + 1`;
if [ -e "/dev/${rootdev}" ]; then
break;
fi
done
fi
echo "Found dev node: /dev/${rootdev}" > /dev/kmsg;
else
echo "ERROR: ${rootdev} not found" > /dev/kmsg;
exec /bin/bash;
fi
mount /dev/${rootdev} /mnt/;
exec /bin/bash;
fi;
elif [[ "${rootdev}" == sd* ]]; then
do
sleep 0.2;
break;
fi
done
fi
else
exec /bin/bash;
fi
exec /bin/bash;
fi;
elif [[ "${rootdev}" == "nfs" ]]; then
eth=`cat /proc/cmdline | sed 's/.* ip=\([a-z0-9.:]*\) .*/\1/' | awk -F ":" '{print $6}'`;
echo "Ethernet interface: $eth" > /dev/kmsg;
ipaddr=$(ifconfig "${eth}" | grep -A1 "${eth}" | grep "inet " | sed 's/.*addr:\([0-9\.]*\) .*/\1/;s/.*inet \([0-9\.]*\) .*/\1/');
if [[ "$ipaddr" =~ [0-9]*.[0-9]*.[0-9]*.[0-9]* ]]; then
echo "IP Address: $ipaddr" > /dev/kmsg;
dhclient_flag="false";
else
do
sleep 0.2;
break;
fi
done
fi
if [ "$dhclient_flag" == "true" ]; then
timeout 8s /sbin/dhclient $eth;
echo "ERROR: dhclient fail..." > /dev/kmsg;
exec /bin/bash;
fi;
fi;
nfsroot_path="`cat /proc/cmdline | sed -e 's/.*nfsroot=\([^ ,]*\)[ ,].*/\1 /'`";
nfsroot_opts="`cat /proc/cmdline | sed -ne 's/.*nfsroot=\([^ ,]*\),\([^ ]*\).*/\2 /p'`";
if [[ "${nfsroot_opts}" == "" ]]; then
nfsroot_opts="nolock"
fi
mount -t nfs -o ${nfsroot_opts} ${nfsroot_path} /mnt/ &>/dev/kmsg;
echo "ERROR: NFS mount fail..." > /dev/kmsg;
exec /bin/bash;
fi;
else
echo "No root-device: Mount failed" > /dev/kmsg;
exec /bin/bash;
fi
# Disable luks-srv TA
nvluks-srv-app -n > /dev/null 2>&1;
echo "Rootfs mounted over ${rootdev}" > /dev/kmsg;
mount -o bind /proc /mnt/proc;
mount -o bind /sys /mnt/sys;
mount -o bind /dev/ /mnt/dev;
cd /mnt;
cp /etc/resolv.conf etc/resolv.conf
echo "Switching from initrd to actual rootfs" > /dev/kmsg;
mount --move . /
exec chroot . /sbin/init 2;
- Run qspi flashing without any error
sudo ROOTFS_ENC=1 BOARDID=3668 BOARDSKU=0001 FAB=300 BOARDREV=B.0 ./tools/kernel_flash/l4t_initrd_flash.sh --no-flash jetson-xavier-nx-devkit-qspi internal
- Finally run external flashing script
