Massfuse blob not flashed correctly
nvmfuse_log.txt (129 Bytes)
massfuse_log.txt (96.1 KB)
Hi
Following the Secure Boot image creation topic I’m trying to fuse the Nvidia fuses.
The 2 logs attached
  1. The Massfuse log notifies successful blob creation
  2. The nvmfuse notifies the successful flash process
    But the fuses are not burned after reset (it still has no fuse values).
    Are there any additional steps to be performed?
Thank you in advance,
Tanya
hello grs.tanya,
there’s failure reported while creating a fuse blob.
for instance,
*** done.
tar: bootloader/odmfuse_pkc.xml: Not found in archive
tar: Exiting with failure status due to previous errors
Generating blob
may I double confirm the Jetpack release version you’re now using? is it JP-6 DP?
besides, you may refer to below forum topics about massfuse.
such as… Xavier NX remains in recovery after successfull massflash with QSPI+external images & disk encryption - #9 by carolyuu and Massfuse on Xavier NX board - #3 by JerryChang
Hello JerryChang
We do use the JP-6 DP.
hello grs.tanya,
BTW, may I also confirm which Orin platform you’re using, it looks you’re using jetson-agx-orin-devkit in flash command-line, but this topic is filed to Orin NX category.
