We are trying to achieve massfusing in OFFLINE mode on Xavier NX boards. We ran following commands:
sudo BOARDID=3668 BOARDSKU=0001 FAB=100 BOARDREV=H.0 FUSELEVEL=fuselevel_production ./nvmassfusegen.sh -p -i 0x19 --auth SBKPKC -k $XKEYS/rsa_priv.pem --KEK2 $XKEYS/KEK2 -S $XKEYS/SBK jetson-xavier-nx-devkit-emmc
But got error Error: Signing binaries failed.
in 2nd step Step 2: Sign Binaries
. Full logs are below:
|| Generate Massfuse Image without Jetson device connected:
| Step 1: Generate Command File
CHIPREV is missing, will use the default value(2).
Board ID(3668) version(100) sku(0001) revision(H.0)
copying sdram_config(/home/akter/nvidia/4.6.1/Linux_for_Tegra_massfuse/bootloader/t186ref/BCT/tegra194-mb1-bct-memcfg-p3668-0001-a00.cfg)... done.
copying sdram_config1(/home/akter/nvidia/4.6.1/Linux_for_Tegra_massfuse/bootloader/t186ref/BCT/tegra194-memcfg-sw-override.cfg)... done.
copying misc_config(/home/akter/nvidia/4.6.1/Linux_for_Tegra_massfuse/bootloader/t186ref/BCT/tegra194-mb1-bct-misc-flash.cfg)... done.
copying pinmux_config(/home/akter/nvidia/4.6.1/Linux_for_Tegra_massfuse/bootloader/t186ref/BCT/tegra19x-mb1-pinmux-p3668-a01.cfg)... done.
copying scr_config(/home/akter/nvidia/4.6.1/Linux_for_Tegra_massfuse/bootloader/t186ref/BCT/tegra194-mb1-bct-scr-cbb-mini-p3668.cfg)... done.
copying scr_cold_boot_config(/home/akter/nvidia/4.6.1/Linux_for_Tegra_massfuse/bootloader/t186ref/BCT/tegra194-mb1-bct-scr-cbb-mini-p3668.cfg)... done.
copying pmc_config(/home/akter/nvidia/4.6.1/Linux_for_Tegra_massfuse/bootloader/t186ref/BCT/tegra19x-mb1-padvoltage-p3668-a01.cfg)... done.
copying pmic_config(/home/akter/nvidia/4.6.1/Linux_for_Tegra_massfuse/bootloader/t186ref/BCT/tegra194-mb1-bct-pmic-p3668-0001-a00.cfg)... done.
copying br_cmd_config(/home/akter/nvidia/4.6.1/Linux_for_Tegra_massfuse/bootloader/t186ref/BCT/tegra194-mb1-bct-reset-p3668-0001-a00.cfg)... done.
copying prod_config(/home/akter/nvidia/4.6.1/Linux_for_Tegra_massfuse/bootloader/t186ref/BCT/tegra19x-mb1-prod-p3668-0001-a00.cfg)... done.
copying dev_params(/home/akter/nvidia/4.6.1/Linux_for_Tegra_massfuse/bootloader/t186ref/BCT/tegra194-br-bct-qspi.cfg)... done.
copying misc_cold_boot_config(/home/akter/nvidia/4.6.1/Linux_for_Tegra_massfuse/bootloader/t186ref/BCT/tegra194-mb1-bct-misc-l4t.cfg)... done.
copying device_config(/home/akter/nvidia/4.6.1/Linux_for_Tegra_massfuse/bootloader/t186ref/BCT/tegra19x-mb1-bct-device-qspi-p3668.cfg)... done.
copying minratchet_config(/home/akter/nvidia/4.6.1/Linux_for_Tegra_massfuse/bootloader/t186ref/BCT/tegra194-mb1-bct-ratchet-p3668.cfg)... done.
copying gpioint_config(/home/akter/nvidia/4.6.1/Linux_for_Tegra_massfuse/bootloader/t186ref/BCT/tegra194-mb1-bct-gpioint-p3668-0001-a00.cfg)... done.
copying soft_fuses(/home/akter/nvidia/4.6.1/Linux_for_Tegra_massfuse/bootloader/t186ref/BCT/tegra194-mb1-soft-fuses-l4t.cfg)... done.
Existing mb2_bootloader(/home/akter/nvidia/4.6.1/Linux_for_Tegra_massfuse/bootloader/nvtboot_recovery_t194.bin) reused.
Existing mts_preboot(/home/akter/nvidia/4.6.1/Linux_for_Tegra_massfuse/bootloader/preboot_c10_prod_cr.bin) reused.
Existing mts_mce(/home/akter/nvidia/4.6.1/Linux_for_Tegra_massfuse/bootloader/mce_c10_prod_cr.bin) reused.
Existing mts_proper(/home/akter/nvidia/4.6.1/Linux_for_Tegra_massfuse/bootloader/mts_c10_prod_cr.bin) reused.
copying bootloader_dtb(/home/akter/nvidia/4.6.1/Linux_for_Tegra_massfuse/kernel/dtb/tegra194-p3668-all-p3509-0000.dtb)... done.
Existing bpmp_fw(/home/akter/nvidia/4.6.1/Linux_for_Tegra_massfuse/bootloader/bpmp_t194.bin) reused.
copying bpmp_fw_dtb(/home/akter/nvidia/4.6.1/Linux_for_Tegra_massfuse/bootloader/t186ref/tegra194-a02-bpmp-p3668-a00.dtb)... done.
Existing tlk(/home/akter/nvidia/4.6.1/Linux_for_Tegra_massfuse/bootloader/tos-trusty_t194.img) reused.
Existing eks(/home/akter/nvidia/4.6.1/Linux_for_Tegra_massfuse/bootloader/eks.img) reused.
Existing spe_fw(/home/akter/nvidia/4.6.1/Linux_for_Tegra_massfuse/bootloader/spe_t194.bin) reused.
Existing mb1file(/home/akter/nvidia/4.6.1/Linux_for_Tegra_massfuse/bootloader/mb1_t194_prod.bin) reused.
Existing spefile(/home/akter/nvidia/4.6.1/Linux_for_Tegra_massfuse/bootloader/spe_t194.bin) reused.
Existing tegraboot(/home/akter/nvidia/4.6.1/Linux_for_Tegra_massfuse/bootloader/nvtboot_t194.bin) reused.
Existing tbcfile(/home/akter/nvidia/4.6.1/Linux_for_Tegra_massfuse/bootloader/cboot_t194.bin) reused.
Existing scefile(/home/akter/nvidia/4.6.1/Linux_for_Tegra_massfuse/bootloader/camera-rtcpu-sce.img) reused.
Existing camerafw(/home/akter/nvidia/4.6.1/Linux_for_Tegra_massfuse/bootloader/camera-rtcpu-rce.img) reused.
Existing wb0boot(/home/akter/nvidia/4.6.1/Linux_for_Tegra_massfuse/bootloader/warmboot_t194_prod.bin) reused.
done.
Existing cfg(/home/akter/nvidia/4.6.1/Linux_for_Tegra_massfuse/bootloader/flash.xml) reused.
Existing bl(/home/akter/nvidia/4.6.1/Linux_for_Tegra_massfuse/bootloader/nvtboot_recovery_cpu_t194.bin) reused.
Existing applet(/home/akter/nvidia/4.6.1/Linux_for_Tegra_massfuse/bootloader/mb1_t194_prod.bin) reused.
./tegraflash.py --sdram_config tegra194-mb1-bct-memcfg-p3668-0001-a00.cfg,tegra194-memcfg-sw-override.cfg --misc_config tegra194-mb1-bct-misc-flash.cfg --pinmux_config tegra19x-mb1-pinmux-p3668-a01.cfg --scr_config tegra194-mb1-bct-scr-cbb-mini-p3668.cfg --scr_cold_boot_config tegra194-mb1-bct-scr-cbb-mini-p3668.cfg --pmc_config tegra19x-mb1-padvoltage-p3668-a01.cfg --pmic_config tegra194-mb1-bct-pmic-p3668-0001-a00.cfg --br_cmd_config tegra194-mb1-bct-reset-p3668-0001-a00.cfg --prod_config tegra19x-mb1-prod-p3668-0001-a00.cfg --dev_params tegra194-br-bct-qspi.cfg --misc_cold_boot_config tegra194-mb1-bct-misc-l4t.cfg --device_config tegra19x-mb1-bct-device-qspi-p3668.cfg --minratchet_config tegra194-mb1-bct-ratchet-p3668.cfg --gpioint_config tegra194-mb1-bct-gpioint-p3668-0001-a00.cfg --soft_fuses tegra194-mb1-soft-fuses-l4t.cfg --bins "mb2_bootloader nvtboot_recovery_t194.bin; mts_preboot preboot_c10_prod_cr.bin; mts_mce mce_c10_prod_cr.bin; mts_proper mts_c10_prod_cr.bin; bootloader_dtb tegra194-p3668-all-p3509-0000.dtb; bpmp_fw bpmp_t194.bin; bpmp_fw_dtb tegra194-a02-bpmp-p3668-a00.dtb; tlk tos-trusty_t194.img; eks eks.img; kernel boot.img; kernel_dtb tegra194-p3668-all-p3509-0000.dtb; spe_fw spe_t194.bin" --cfg flash.xml --bl nvtboot_recovery_cpu_t194.bin --odmdata 0xB8190000 --chip 0x19 --applet mb1_t194_prod.bin --key "/home/akter/.xkeys/rsa_priv.pem" --encrypt_key "/home/akter/.xkeys/SBK" --cmd "sign"
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[ 0.0055 ] Using default ramcode: 0
[ 0.0055 ] Disable BPMP dtb trim, using default dtb
[ 0.0055 ]
[ 0.0080 ] tegrasign_v3.py --getmode mode.txt --key /home/akter/.xkeys/rsa_priv.pem
[ 0.0096 ] K[ 0.0098 ] ey size is 384 bytes
[ 0.0101 ] Generating RCM messages
[ 0.0122 ] tegrasign_v3.py --key /home/akter/.xkeys/SBK --file mb1_t194_prod.bin --offset 4096
[ 0.0129 ] Key is a SBK key
[ 0.0359 ] Key Size is 16 bytes
[ 0.0360 ] 246336
[ 0.0443 ]
[ 0.0467 ] tegrahost_v2 --chip 0x19 0 --magicid MB1B --appendsigheader mb1_t194_prod_encrypt.bin zerosbk
[ 0.0475 ] Header already present for mb1_t194_prod_encrypt.bin
[ 0.0507 ]
[ 0.0530 ] tegrasign_v3.py --getmode mode.txt --key /home/akter/.xkeys/rsa_priv.pem
[ 0.0547 ] K[ 0.0550 ] ey size is 384 bytes
[ 0.0574 ] tegrasign_v3.py --file mb1_t194_prod_encrypt_sigheader.bin --getmontgomeryvalues montgomery.bin --key /home/akter/.xkeys/rsa_priv.pem --length 1136 --offset 2960 --pubkeyhash pub_key.key
[ 0.0590 ] K[ 0.0606 ] ey size is 384 bytes
[ 0.1060 ] Saving pkc public key in pub_key.key
[ 0.1060 ] Saving Montgomery values in montgomery.bin
[ 0.1079 ] tegrahost_v2 --chip 0x19 0 --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin --updatesigheader mb1_t194_prod_encrypt_sigheader.bin mb1_t194_prod_encrypt_sigheader.sig oem-rsa
[ 0.1113 ]
[ 0.1132 ] tegrabct_v2 --chip 0x19 0 --sfuse tegra194-mb1-soft-fuses-l4t.cfg sfuse.bin
[ 0.1140 ]
[ 0.1161 ] tegrabct_v2 --chip 0x19 0 --ratchet_blob ratchet_blob.bin --minratchet tegra194-mb1-bct-ratchet-p3668.cfg
[ 0.1167 ] FwIndex: 1, MinRatchetLevel: 0
[ 0.1169 ] FwIndex: 2, MinRatchetLevel: 0
[ 0.1169 ] FwIndex: 3, MinRatchetLevel: 0
[ 0.1169 ] FwIndex: 4, MinRatchetLevel: 0
[ 0.1169 ] FwIndex: 5, MinRatchetLevel: 0
[ 0.1169 ] FwIndex: 6, MinRatchetLevel: 0
[ 0.1169 ] FwIndex: 7, MinRatchetLevel: 0
[ 0.1169 ] FwIndex: 11, MinRatchetLevel: 0
[ 0.1170 ] FwIndex: 12, MinRatchetLevel: 0
[ 0.1170 ] FwIndex: 13, MinRatchetLevel: 0
[ 0.1170 ] FwIndex: 14, MinRatchetLevel: 0
[ 0.1170 ] FwIndex: 15, MinRatchetLevel: 0
[ 0.1170 ] FwIndex: 16, MinRatchetLevel: 0
[ 0.1170 ] FwIndex: 17, MinRatchetLevel: 0
[ 0.1170 ] FwIndex: 18, MinRatchetLevel: 0
[ 0.1170 ] FwIndex: 19, MinRatchetLevel: 0
[ 0.1170 ] FwIndex: 30, MinRatchetLevel: 0
[ 0.1170 ] FwIndex: 31, MinRatchetLevel: 0
[ 0.1170 ] FwIndex: 32, MinRatchetLevel: 0
[ 0.1170 ]
[ 0.1191 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x19 0 --sfuses sfuse.bin --download rcm mb1_t194_prod_encrypt_sigheader.bin 0 0
[ 0.1197 ] RCM 0 is saved as rcm_0.rcm
[ 0.1225 ] RCM 1 is saved as rcm_1.rcm
[ 0.1225 ] RCM 2 is saved as rcm_2.rcm
[ 0.1225 ] List of rcm files are saved in rcm_list.xml
[ 0.1225 ]
[ 0.1225 ] Signing RCM messages
[ 0.1247 ] tegrasign_v3.py --getmontgomeryvalues montgomery.bin --key /home/akter/.xkeys/rsa_priv.pem --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.1262 ] K[ 0.1275 ] ey size is 384 bytes
[ 0.2535 ] Saving pkc public key in pub_key.key
[ 0.2535 ] Saving Montgomery values in montgomery.bin
[ 0.2533 ] Copying signature to RCM mesages
[ 0.2551 ] tegrarcm_v2 --chip 0x19 0 --updatesig rcm_list_signed.xml --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 0.2563 ]
[ 0.2564 ] Parsing partition layout
[ 0.2582 ] tegraparser_v2 --pt flash.xml.tmp
[ 0.2594 ]
[ 0.2594 ] Creating list of images to be signed
[ 0.2612 ] tegrahost_v2 --chip 0x19 --partitionlayout flash.xml.bin --list images_list.xml --ratchet_blob ratchet_blob.bin
[ 0.2618 ] MB1: Nvheader already present is mb1_t194_prod.bin
[ 0.2622 ] Header already present for mb1_t194_prod_sigheader.bin
[ 0.2626 ] MB1: Nvheader already present is mb1_t194_prod.bin
[ 0.2652 ] Header already present for mb1_t194_prod_sigheader.bin
[ 0.2656 ] adding BCH for spe_t194.bin
[ 0.2681 ] adding BCH for spe_t194.bin
[ 0.2699 ] adding BCH for nvtboot_t194.bin
[ 0.2717 ] adding BCH for nvtboot_t194.bin
[ 0.2751 ] Header already present for preboot_c10_prod_cr.bin
[ 0.2786 ] Header already present for preboot_c10_prod_cr.bin
[ 0.2789 ] Header already present for mce_c10_prod_cr.bin
[ 0.2792 ] Header already present for mce_c10_prod_cr.bin
[ 0.2808 ] adding BCH for mts_c10_prod_cr.bin
[ 0.2840 ] adding BCH for mts_c10_prod_cr.bin
[ 0.3516 ] Header already present for warmboot_t194_prod.bin
[ 0.4172 ] Header already present for warmboot_t194_prod.bin
[ 0.4179 ] adding BCH for xusb_sil_rel_fw
[ 0.4186 ] adding BCH for xusb_sil_rel_fw
[ 0.4212 ] adding BCH for cboot_t194.bin
[ 0.4238 ] adding BCH for cboot_t194.bin
[ 0.4327 ] adding BCH for tegra194-p3668-all-p3509-0000.dtb
[ 0.4417 ] adding BCH for tegra194-p3668-all-p3509-0000.dtb
[ 0.4457 ] adding BCH for tos-trusty_t194.img
[ 0.4496 ] adding BCH for tos-trusty_t194.img
[ 0.4573 ] adding BCH for eks.img
[ 0.4649 ] adding BCH for eks.img
[ 0.4650 ] adding BCH for adsp-fw.bin
[ 0.4652 ] adding BCH for adsp-fw.bin
[ 0.4668 ] adding BCH for camera-rtcpu-rce.img
[ 0.4684 ] adding BCH for camera-rtcpu-rce.img
[ 0.4735 ] adding BCH for bpmp_t194.bin
[ 0.4790 ] adding BCH for bpmp_t194.bin
[ 0.4954 ] adding BCH for tegra194-a02-bpmp-p3668-a00.dtb
[ 0.5118 ] adding BCH for tegra194-a02-bpmp-p3668-a00.dtb
[ 0.5191 ] adding BCH for boot.img
[ 0.5263 ] adding BCH for boot.img
[ 0.5264 ] adding BCH for tegra194-p3668-all-p3509-0000.dtb
[ 0.5266 ] adding BCH for tegra194-p3668-all-p3509-0000.dtb
[ 0.5345 ]
[ 0.5366 ] tegrasign_v3.py --key /home/akter/.xkeys/rsa_priv.pem --list images_list.xml --pubkeyhash pub_key.key
[ 0.5373 ] Key size is 384 bytes
[ 0.5975 ] Saving pkc public key in pub_key.key
[ 2.0501 ]
[ 2.0501 ] Generating br-bct
[ 2.0524 ] Performing cfg overlay
[ 2.0525 ] ['tegra194-mb1-bct-memcfg-p3668-0001-a00.cfg', 'tegra194-memcfg-sw-override.cfg']
[ 2.0529 ] sw_memcfg_overlay.pl -c tegra194-mb1-bct-memcfg-p3668-0001-a00.cfg -s tegra194-memcfg-sw-override.cfg -o /home/akter/nvidia/4.6.1/Linux_for_Tegra_massfuse/bootloader/11869/tmp4x_6gf_l1.cfg
[ 2.0860 ]
[ 2.0861 ] Updating dev and MSS params in BR BCT
[ 2.0862 ] tegrabct_v2 --dev_param tegra194-br-bct-qspi.cfg --sdram /home/akter/nvidia/4.6.1/Linux_for_Tegra_massfuse/bootloader/11869/tmp4x_6gf_l1.cfg --brbct br_bct.cfg --sfuse tegra194-mb1-soft-fuses-l4t.cfg --chip 0x19 0
[ 2.1422 ]
[ 2.1423 ] Updating bl info
[ 2.1442 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updateblinfo flash.xml.bin
[ 2.1458 ]
[ 2.1484 ] tegrahost_v2 --chip 0x19 --align mb1_t194_prod_sigheader.bin
[ 2.1491 ]
[ 2.1492 ] header_magic: 4e564441
[ 2.1515 ] tegrasign_v3.py --key /home/akter/.xkeys/SBK --list mb1_t194_prod_sigheader.bin_list.xml
[ 2.1516 ] Key is a SBK key
[ 2.1516 ] Key Size is 16 bytes
[ 2.1523 ] 246336
[ 2.1640 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_t194_prod_sigheader.bin.encrypt mb1_t194_prod_sigheader.bin.hash zerosbk
[ 2.1674 ]
[ 2.1694 ] tegrahost_v2 --chip 0x19 --align mb1_t194_prod_sigheader.bin.encrypt
[ 2.1701 ]
[ 2.1702 ] header_magic: 4e564441
[ 2.1727 ] tegrasign_v3.py --key /home/akter/.xkeys/rsa_priv.pem --list mb1_t194_prod_sigheader.bin.encrypt_list.xml --pubkeyhash pub_key.key
[ 2.1743 ] K[ 2.1746 ] ey size is 384 bytes
[ 2.2169 ] Saving pkc public key in pub_key.key
[ 2.2187 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_t194_prod_sigheader.bin.encrypt.signed mb1_t194_prod_sigheader.bin.encrypt.sig oem-rsa --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 2.2220 ]
[ 2.2244 ] tegrahost_v2 --chip 0x19 --align mb1_t194_prod_sigheader.bin
[ 2.2252 ]
[ 2.2253 ] header_magic: 4e564441
[ 2.2276 ] tegrasign_v3.py --key /home/akter/.xkeys/SBK --list mb1_t194_prod_sigheader.bin_list.xml
[ 2.2277 ] Key is a SBK key
[ 2.2277 ] Key Size is 16 bytes
[ 2.2283 ] 246336
[ 2.2404 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_t194_prod_sigheader.bin.encrypt mb1_t194_prod_sigheader.bin.hash zerosbk
[ 2.2438 ]
[ 2.2458 ] tegrahost_v2 --chip 0x19 --align mb1_t194_prod_sigheader.bin.encrypt
[ 2.2466 ]
[ 2.2467 ] header_magic: 4e564441
[ 2.2493 ] tegrasign_v3.py --key /home/akter/.xkeys/rsa_priv.pem --list mb1_t194_prod_sigheader.bin.encrypt_list.xml --pubkeyhash pub_key.key
[ 2.2508 ] Ke[ 2.2511 ] y size is 384 bytes
[ 2.2938 ] Saving pkc public key in pub_key.key
[ 2.2956 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_t194_prod_sigheader.bin.encrypt.signed mb1_t194_prod_sigheader.bin.encrypt.sig oem-rsa --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 2.2989 ]
[ 2.3011 ] tegrahost_v2 --chip 0x19 --align spe_t194_sigheader.bin
[ 2.3019 ]
[ 2.3020 ] header_magic: 4e564441
[ 2.3042 ] tegrasign_v3.py --key /home/akter/.xkeys/SBK --list spe_t194_sigheader.bin_list.xml
[ 2.3044 ] Key is a SBK key
[ 2.3044 ] Key Size is 16 bytes
[ 2.3048 ] 90864
[ 2.3121 ] tegrahost_v2 --chip 0x19 0 --updatesigheader spe_t194_sigheader.bin.encrypt spe_t194_sigheader.bin.hash zerosbk
[ 2.3139 ]
[ 2.3158 ] tegrahost_v2 --chip 0x19 --align spe_t194_sigheader.bin.encrypt
[ 2.3166 ]
[ 2.3167 ] header_magic: 4e564441
[ 2.3190 ] tegrasign_v3.py --key /home/akter/.xkeys/rsa_priv.pem --list spe_t194_sigheader.bin.encrypt_list.xml --pubkeyhash pub_key.key
[ 2.3205 ] K[ 2.3208 ] ey size is 384 bytes
[ 2.3630 ] Saving pkc public key in pub_key.key
[ 2.3648 ] tegrahost_v2 --chip 0x19 0 --updatesigheader spe_t194_sigheader.bin.encrypt.signed spe_t194_sigheader.bin.encrypt.sig oem-rsa --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 2.3666 ]
[ 2.3687 ] tegrahost_v2 --chip 0x19 --align spe_t194_sigheader.bin
[ 2.3694 ]
[ 2.3695 ] header_magic: 4e564441
[ 2.3718 ] tegrasign_v3.py --key /home/akter/.xkeys/SBK --list spe_t194_sigheader.bin_list.xml
[ 2.3719 ] Key is a SBK key
[ 2.3719 ] Key Size is 16 bytes
[ 2.3723 ] 90864
[ 2.3800 ] tegrahost_v2 --chip 0x19 0 --updatesigheader spe_t194_sigheader.bin.encrypt spe_t194_sigheader.bin.hash zerosbk
[ 2.3817 ]
[ 2.3836 ] tegrahost_v2 --chip 0x19 --align spe_t194_sigheader.bin.encrypt
[ 2.3844 ]
[ 2.3845 ] header_magic: 4e564441
[ 2.3869 ] tegrasign_v3.py --key /home/akter/.xkeys/rsa_priv.pem --list spe_t194_sigheader.bin.encrypt_list.xml --pubkeyhash pub_key.key
[ 2.3885 ] K[ 2.3888 ] ey size is 384 bytes
[ 2.4305 ] Saving pkc public key in pub_key.key
[ 2.4323 ] tegrahost_v2 --chip 0x19 0 --updatesigheader spe_t194_sigheader.bin.encrypt.signed spe_t194_sigheader.bin.encrypt.sig oem-rsa --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 2.4340 ]
[ 2.4362 ] tegrahost_v2 --chip 0x19 --align nvtboot_t194_sigheader.bin
[ 2.4369 ]
[ 2.4371 ] header_magic: 4e564441
[ 2.4395 ] tegrasign_v3.py --key /home/akter/.xkeys/SBK --list nvtboot_t194_sigheader.bin_list.xml
[ 2.4396 ] Key is a SBK key
[ 2.4396 ] Key Size is 16 bytes
[ 2.4402 ] 177232
[ 2.4500 ] tegrahost_v2 --chip 0x19 0 --updatesigheader nvtboot_t194_sigheader.bin.encrypt nvtboot_t194_sigheader.bin.hash zerosbk
[ 2.4525 ]
[ 2.4545 ] tegrahost_v2 --chip 0x19 --align nvtboot_t194_sigheader.bin.encrypt
[ 2.4552 ]
[ 2.4553 ] header_magic: 4e564441
[ 2.4577 ] tegrasign_v3.py --key /home/akter/.xkeys/rsa_priv.pem --list nvtboot_t194_sigheader.bin.encrypt_list.xml --pubkeyhash pub_key.key
[ 2.4592 ] K[ 2.4595 ] ey size is 384 bytes
[ 2.5017 ] Saving pkc public key in pub_key.key
[ 2.5035 ] tegrahost_v2 --chip 0x19 0 --updatesigheader nvtboot_t194_sigheader.bin.encrypt.signed nvtboot_t194_sigheader.bin.encrypt.sig oem-rsa --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 2.5061 ]
[ 2.5083 ] tegrahost_v2 --chip 0x19 --align nvtboot_t194_sigheader.bin
[ 2.5091 ]
[ 2.5092 ] header_magic: 4e564441
[ 2.5117 ] tegrasign_v3.py --key /home/akter/.xkeys/SBK --list nvtboot_t194_sigheader.bin_list.xml
[ 2.5118 ] Key is a SBK key
[ 2.5118 ] Key Size is 16 bytes
[ 2.5123 ] 177232
[ 2.5222 ] tegrahost_v2 --chip 0x19 0 --updatesigheader nvtboot_t194_sigheader.bin.encrypt nvtboot_t194_sigheader.bin.hash zerosbk
[ 2.5248 ]
[ 2.5268 ] tegrahost_v2 --chip 0x19 --align nvtboot_t194_sigheader.bin.encrypt
[ 2.5275 ]
[ 2.5276 ] header_magic: 4e564441
[ 2.5301 ] tegrasign_v3.py --key /home/akter/.xkeys/rsa_priv.pem --list nvtboot_t194_sigheader.bin.encrypt_list.xml --pubkeyhash pub_key.key
[ 2.5317 ] K[ 2.5319 ] ey size is 384 bytes
[ 2.5739 ] Saving pkc public key in pub_key.key
[ 2.5760 ] tegrahost_v2 --chip 0x19 0 --updatesigheader nvtboot_t194_sigheader.bin.encrypt.signed nvtboot_t194_sigheader.bin.encrypt.sig oem-rsa --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 2.5786 ]
[ 2.5809 ] tegrahost_v2 --chip 0x19 --align preboot_c10_prod_cr_sigheader.bin
[ 2.5817 ]
[ 2.5818 ] header_magic: 4e564441
[ 2.5840 ] tegrasign_v3.py --key /home/akter/.xkeys/SBK --list preboot_c10_prod_cr_sigheader.bin_list.xml
[ 2.5841 ] Key is a SBK key
[ 2.5841 ] Key Size is 16 bytes
[ 2.5845 ] 19920
[ 2.5904 ] tegrahost_v2 --chip 0x19 0 --updatesigheader preboot_c10_prod_cr_sigheader.bin.encrypt preboot_c10_prod_cr_sigheader.bin.hash zerosbk
[ 2.5915 ]
[ 2.5936 ] tegrahost_v2 --chip 0x19 --align preboot_c10_prod_cr_sigheader.bin.encrypt
[ 2.5944 ]
[ 2.5945 ] header_magic: 4e564441
[ 2.5970 ] tegrasign_v3.py --key /home/akter/.xkeys/rsa_priv.pem --list preboot_c10_prod_cr_sigheader.bin.encrypt_list.xml --pubkeyhash pub_key.key
[ 2.5985 ] K[ 2.5988 ] ey size is 384 bytes
[ 2.6411 ] Saving pkc public key in pub_key.key
[ 2.6429 ] tegrahost_v2 --chip 0x19 0 --updatesigheader preboot_c10_prod_cr_sigheader.bin.encrypt.signed preboot_c10_prod_cr_sigheader.bin.encrypt.sig oem-rsa --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 2.6440 ]
[ 2.6463 ] tegrahost_v2 --chip 0x19 --align preboot_c10_prod_cr_sigheader.bin
[ 2.6470 ]
[ 2.6471 ] header_magic: 4e564441
[ 2.6497 ] tegrasign_v3.py --key /home/akter/.xkeys/SBK --list preboot_c10_prod_cr_sigheader.bin_list.xml
[ 2.6498 ] Key is a SBK key
[ 2.6498 ] Key Size is 16 bytes
[ 2.6501 ] 19920
[ 2.6559 ] tegrahost_v2 --chip 0x19 0 --updatesigheader preboot_c10_prod_cr_sigheader.bin.encrypt preboot_c10_prod_cr_sigheader.bin.hash zerosbk
[ 2.6569 ]
[ 2.6591 ] tegrahost_v2 --chip 0x19 --align preboot_c10_prod_cr_sigheader.bin.encrypt
[ 2.6599 ]
[ 2.6600 ] header_magic: 4e564441
[ 2.6625 ] tegrasign_v3.py --key /home/akter/.xkeys/rsa_priv.pem --list preboot_c10_prod_cr_sigheader.bin.encrypt_list.xml --pubkeyhash pub_key.key
[ 2.6641 ] K[ 2.6644 ] ey size is 384 bytes
[ 2.7069 ] Saving pkc public key in pub_key.key
[ 2.7087 ] tegrahost_v2 --chip 0x19 0 --updatesigheader preboot_c10_prod_cr_sigheader.bin.encrypt.signed preboot_c10_prod_cr_sigheader.bin.encrypt.sig oem-rsa --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 2.7097 ]
[ 2.7120 ] tegrahost_v2 --chip 0x19 --align mce_c10_prod_cr_sigheader.bin
[ 2.7127 ]
[ 2.7128 ] header_magic: 4e564441
[ 2.7152 ] tegrasign_v3.py --key /home/akter/.xkeys/SBK --list mce_c10_prod_cr_sigheader.bin_list.xml
[ 2.7153 ] Key is a SBK key
[ 2.7153 ] Key Size is 16 bytes
[ 2.7158 ] 139104
[ 2.7248 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mce_c10_prod_cr_sigheader.bin.encrypt mce_c10_prod_cr_sigheader.bin.hash zerosbk
[ 2.7271 ]
[ 2.7290 ] tegrahost_v2 --chip 0x19 --align mce_c10_prod_cr_sigheader.bin.encrypt
[ 2.7298 ]
[ 2.7299 ] header_magic: 4e564441
[ 2.7312 ] tegrasign_v3.py --key /home/akter/.xkeys/rsa_priv.pem --list mce_c10_prod_cr_sigheader.bin.encrypt_list.xml --pubkeyhash pub_key.key
[ 2.7327 ] K[ 2.7330 ] ey size is 384 bytes
[ 2.7762 ] Saving pkc public key in pub_key.key
[ 2.7780 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mce_c10_prod_cr_sigheader.bin.encrypt.signed mce_c10_prod_cr_sigheader.bin.encrypt.sig oem-rsa --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 2.7802 ]
[ 2.7825 ] tegrahost_v2 --chip 0x19 --align mce_c10_prod_cr_sigheader.bin
[ 2.7832 ]
[ 2.7833 ] header_magic: 4e564441
[ 2.7859 ] tegrasign_v3.py --key /home/akter/.xkeys/SBK --list mce_c10_prod_cr_sigheader.bin_list.xml
[ 2.7863 ] Key is a SBK key
[ 2.7864 ] Key Size is 16 bytes
[ 2.7882 ] 139104
[ 2.8111 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mce_c10_prod_cr_sigheader.bin.encrypt mce_c10_prod_cr_sigheader.bin.hash zerosbk
[ 2.8155 ]
[ 2.8181 ] tegrahost_v2 --chip 0x19 --align mce_c10_prod_cr_sigheader.bin.encrypt
[ 2.8195 ]
[ 2.8196 ] header_magic: 4e564441
[ 2.8229 ] tegrasign_v3.py --key /home/akter/.xkeys/rsa_priv.pem --list mce_c10_prod_cr_sigheader.bin.encrypt_list.xml --pubkeyhash pub_key.key
[ 2.8256 ] K[ 2.8261 ] ey size is 384 bytes
[ 2.8872 ] Saving pkc public key in pub_key.key
[ 2.8893 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mce_c10_prod_cr_sigheader.bin.encrypt.signed mce_c10_prod_cr_sigheader.bin.encrypt.sig oem-rsa --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 2.8914 ]
[ 2.8936 ] tegrahost_v2 --chip 0x19 --align mts_c10_prod_cr_sigheader.bin
[ 2.8943 ]
[ 2.8944 ] header_magic: 4e564441
[ 2.8968 ] tegrasign_v3.py --key /home/akter/.xkeys/SBK --list mts_c10_prod_cr_sigheader.bin_list.xml
[ 2.8969 ] Key is a SBK key
[ 2.8969 ] Key Size is 16 bytes
[ 2.9029 ] 3426320
[ 3.0077 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mts_c10_prod_cr_sigheader.bin.encrypt mts_c10_prod_cr_sigheader.bin.hash zerosbk
[ 3.0475 ]
[ 3.0500 ] tegrahost_v2 --chip 0x19 --align mts_c10_prod_cr_sigheader.bin.encrypt
[ 3.0509 ]
[ 3.0510 ] header_magic: 4e564441
[ 3.0536 ] tegrasign_v3.py --key /home/akter/.xkeys/rsa_priv.pem --list mts_c10_prod_cr_sigheader.bin.encrypt_list.xml --pubkeyhash pub_key.key
[ 3.0552 ] K[ 3.0555 ] ey size is 384 bytes
[ 3.1028 ] Saving pkc public key in pub_key.key
[ 3.1051 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mts_c10_prod_cr_sigheader.bin.encrypt.signed mts_c10_prod_cr_sigheader.bin.encrypt.sig oem-rsa --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 3.1434 ]
[ 3.1490 ] tegrahost_v2 --chip 0x19 --align mts_c10_prod_cr_sigheader.bin
[ 3.1499 ]
[ 3.1500 ] header_magic: 4e564441
[ 3.1525 ] tegrasign_v3.py --key /home/akter/.xkeys/SBK --list mts_c10_prod_cr_sigheader.bin_list.xml
[ 3.1526 ] Key is a SBK key
[ 3.1526 ] Key Size is 16 bytes
[ 3.1584 ] 3426320
[ 3.2677 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mts_c10_prod_cr_sigheader.bin.encrypt mts_c10_prod_cr_sigheader.bin.hash zerosbk
[ 3.3092 ]
[ 3.3115 ] tegrahost_v2 --chip 0x19 --align mts_c10_prod_cr_sigheader.bin.encrypt
[ 3.3123 ]
[ 3.3124 ] header_magic: 4e564441
[ 3.3150 ] tegrasign_v3.py --key /home/akter/.xkeys/rsa_priv.pem --list mts_c10_prod_cr_sigheader.bin.encrypt_list.xml --pubkeyhash pub_key.key
[ 3.3167 ] K[ 3.3170 ] ey size is 384 bytes
[ 3.3671 ] Saving pkc public key in pub_key.key
[ 3.3693 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mts_c10_prod_cr_sigheader.bin.encrypt.signed mts_c10_prod_cr_sigheader.bin.encrypt.sig oem-rsa --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 3.4083 ]
[ 3.4139 ] tegrahost_v2 --chip 0x19 --align warmboot_t194_prod_sigheader.bin
[ 3.4148 ]
[ 3.4149 ] header_magic: 4e564441
[ 3.4175 ] tegrasign_v3.py --key /home/akter/.xkeys/SBK --list warmboot_t194_prod_sigheader.bin_list.xml
[ 3.4176 ] Key is a SBK key
[ 3.4176 ] Key Size is 16 bytes
[ 3.4180 ] 61408
[ 3.4259 ] tegrahost_v2 --chip 0x19 0 --updatesigheader warmboot_t194_prod_sigheader.bin.encrypt warmboot_t194_prod_sigheader.bin.hash zerosbk
[ 3.4276 ]
[ 3.4298 ] tegrahost_v2 --chip 0x19 --align warmboot_t194_prod_sigheader.bin.encrypt
[ 3.4306 ]
[ 3.4307 ] header_magic: 4e564441
[ 3.4332 ] tegrasign_v3.py --key /home/akter/.xkeys/rsa_priv.pem --list warmboot_t194_prod_sigheader.bin.encrypt_list.xml --pubkeyhash pub_key.key
[ 3.4349 ] K[ 3.4352 ] ey size is 384 bytes
[ 3.4801 ] Saving pkc public key in pub_key.key
[ 3.4819 ] tegrahost_v2 --chip 0x19 0 --updatesigheader warmboot_t194_prod_sigheader.bin.encrypt.signed warmboot_t194_prod_sigheader.bin.encrypt.sig oem-rsa --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 3.4835 ]
[ 3.4856 ] tegrahost_v2 --chip 0x19 --align warmboot_t194_prod_sigheader.bin
[ 3.4864 ]
[ 3.4865 ] header_magic: 4e564441
[ 3.4890 ] tegrasign_v3.py --key /home/akter/.xkeys/SBK --list warmboot_t194_prod_sigheader.bin_list.xml
[ 3.4891 ] Key is a SBK key
[ 3.4891 ] Key Size is 16 bytes
[ 3.4895 ] 61408
[ 3.4968 ] tegrahost_v2 --chip 0x19 0 --updatesigheader warmboot_t194_prod_sigheader.bin.encrypt warmboot_t194_prod_sigheader.bin.hash zerosbk
[ 3.4983 ]
[ 3.5004 ] tegrahost_v2 --chip 0x19 --align warmboot_t194_prod_sigheader.bin.encrypt
[ 3.5011 ]
[ 3.5013 ] header_magic: 4e564441
[ 3.5038 ] tegrasign_v3.py --key /home/akter/.xkeys/rsa_priv.pem --list warmboot_t194_prod_sigheader.bin.encrypt_list.xml --pubkeyhash pub_key.key
[ 3.5054 ] K[ 3.5057 ] ey size is 384 bytes
[ 3.5492 ] Saving pkc public key in pub_key.key
[ 3.5510 ] tegrahost_v2 --chip 0x19 0 --updatesigheader warmboot_t194_prod_sigheader.bin.encrypt.signed warmboot_t194_prod_sigheader.bin.encrypt.sig oem-rsa --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 3.5525 ]
[ 3.5548 ] tegrahost_v2 --chip 0x19 --align xusb_sil_rel_fw_sigheader
[ 3.5556 ]
[ 3.5557 ] header_magic: 4e564441
[ 3.5582 ] tegrasign_v3.py --key /home/akter/.xkeys/SBK --list xusb_sil_rel_fw_sigheader_list.xml
[ 3.5583 ] Key is a SBK key
[ 3.5583 ] Key Size is 16 bytes
[ 3.5587 ] 129024
[ 3.5677 ] tegrahost_v2 --chip 0x19 0 --updatesigheader xusb_sil_rel_fw_sigheader.encrypt xusb_sil_rel_fw_sigheader.hash zerosbk
[ 3.5699 ]
[ 3.5721 ] tegrahost_v2 --chip 0x19 --align xusb_sil_rel_fw_sigheader.encrypt
[ 3.5729 ]
[ 3.5730 ] header_magic: 4e564441
[ 3.5755 ] tegrasign_v3.py --key /home/akter/.xkeys/rsa_priv.pem --list xusb_sil_rel_fw_sigheader.encrypt_list.xml --pubkeyhash pub_key.key
[ 3.5771 ] K[ 3.5774 ] ey size is 384 bytes
[ 3.6213 ] Saving pkc public key in pub_key.key
[ 3.6231 ] tegrahost_v2 --chip 0x19 0 --updatesigheader xusb_sil_rel_fw_sigheader.encrypt.signed xusb_sil_rel_fw_sigheader.encrypt.sig oem-rsa --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 3.6252 ]
[ 3.6277 ] tegrahost_v2 --chip 0x19 --align xusb_sil_rel_fw_sigheader
[ 3.6284 ]
[ 3.6286 ] header_magic: 4e564441
[ 3.6311 ] tegrasign_v3.py --key /home/akter/.xkeys/SBK --list xusb_sil_rel_fw_sigheader_list.xml
[ 3.6312 ] Key is a SBK key
[ 3.6312 ] Key Size is 16 bytes
[ 3.6316 ] 129024
[ 3.6408 ] tegrahost_v2 --chip 0x19 0 --updatesigheader xusb_sil_rel_fw_sigheader.encrypt xusb_sil_rel_fw_sigheader.hash zerosbk
[ 3.6431 ]
[ 3.6451 ] tegrahost_v2 --chip 0x19 --align xusb_sil_rel_fw_sigheader.encrypt
[ 3.6459 ]
[ 3.6460 ] header_magic: 4e564441
[ 3.6485 ] tegrasign_v3.py --key /home/akter/.xkeys/rsa_priv.pem --list xusb_sil_rel_fw_sigheader.encrypt_list.xml --pubkeyhash pub_key.key
[ 3.6502 ] K[ 3.6505 ] ey size is 384 bytes
[ 3.6958 ] Saving pkc public key in pub_key.key
[ 3.6978 ] tegrahost_v2 --chip 0x19 0 --updatesigheader xusb_sil_rel_fw_sigheader.encrypt.signed xusb_sil_rel_fw_sigheader.encrypt.sig oem-rsa --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 3.7000 ]
[ 3.7023 ] tegrahost_v2 --chip 0x19 --align cboot_t194_sigheader.bin
[ 3.7031 ]
[ 3.7032 ] header_magic: 4e564441
[ 3.7058 ] tegrasign_v3.py --key /home/akter/.xkeys/SBK --list cboot_t194_sigheader.bin_list.xml
[ 3.7059 ] Key is a SBK key
[ 3.7059 ] Key Size is 16 bytes
[ 3.7068 ] 466912
[ 3.7258 ] tegrahost_v2 --chip 0x19 0 --updatesigheader cboot_t194_sigheader.bin.encrypt cboot_t194_sigheader.bin.hash zerosbk
[ 3.7322 ]
[ 3.7344 ] tegrahost_v2 --chip 0x19 --align cboot_t194_sigheader.bin.encrypt
[ 3.7353 ]
[ 3.7354 ] header_magic: 4e564441
[ 3.7380 ] tegrasign_v3.py --key /home/akter/.xkeys/rsa_priv.pem --list cboot_t194_sigheader.bin.encrypt_list.xml --pubkeyhash pub_key.key
[ 3.7398 ] K[ 3.7401 ] ey size is 384 bytes
[ 3.7862 ] Saving pkc public key in pub_key.key
[ 3.7883 ] tegrahost_v2 --chip 0x19 0 --updatesigheader cboot_t194_sigheader.bin.encrypt.signed cboot_t194_sigheader.bin.encrypt.sig oem-rsa --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 3.7944 ]
[ 3.7971 ] tegrahost_v2 --chip 0x19 --align cboot_t194_sigheader.bin
[ 3.7979 ]
[ 3.7980 ] header_magic: 4e564441
[ 3.8005 ] tegrasign_v3.py --key /home/akter/.xkeys/SBK --list cboot_t194_sigheader.bin_list.xml
[ 3.8006 ] Key is a SBK key
[ 3.8006 ] Key Size is 16 bytes
[ 3.8015 ] 466912
[ 3.8210 ] tegrahost_v2 --chip 0x19 0 --updatesigheader cboot_t194_sigheader.bin.encrypt cboot_t194_sigheader.bin.hash zerosbk
[ 3.8274 ]
[ 3.8297 ] tegrahost_v2 --chip 0x19 --align cboot_t194_sigheader.bin.encrypt
[ 3.8305 ]
[ 3.8306 ] header_magic: 4e564441
[ 3.8332 ] tegrasign_v3.py --key /home/akter/.xkeys/rsa_priv.pem --list cboot_t194_sigheader.bin.encrypt_list.xml --pubkeyhash pub_key.key
[ 3.8349 ] K[ 3.8352 ] ey size is 384 bytes
[ 3.8817 ] Saving pkc public key in pub_key.key
[ 3.8838 ] tegrahost_v2 --chip 0x19 0 --updatesigheader cboot_t194_sigheader.bin.encrypt.signed cboot_t194_sigheader.bin.encrypt.sig oem-rsa --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 3.8898 ]
[ 3.8925 ] tegrahost_v2 --chip 0x19 --align tegra194-p3668-all-p3509-0000_sigheader.dtb
[ 3.8933 ]
[ 3.8935 ] header_magic: 4e564441
[ 3.8958 ] tegrasign_v3.py --key /home/akter/.xkeys/SBK --list tegra194-p3668-all-p3509-0000_sigheader.dtb_list.xml
[ 3.8959 ] Key is a SBK key
[ 3.8960 ] Key Size is 16 bytes
[ 3.8965 ] 204640
[ 3.9081 ] tegrahost_v2 --chip 0x19 0 --updatesigheader tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt tegra194-p3668-all-p3509-0000_sigheader.dtb.hash zerosbk
[ 3.9113 ]
[ 3.9135 ] tegrahost_v2 --chip 0x19 --align tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt
[ 3.9143 ]
[ 3.9144 ] header_magic: 4e564441
[ 3.9169 ] tegrasign_v3.py --key /home/akter/.xkeys/rsa_priv.pem --list tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt_list.xml --pubkeyhash pub_key.key
[ 3.9185 ] K[ 3.9188 ] ey size is 384 bytes
[ 3.9636 ] Saving pkc public key in pub_key.key
[ 3.9657 ] tegrahost_v2 --chip 0x19 0 --updatesigheader tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt.signed tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt.sig oem-rsa --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 3.9687 ]
[ 3.9711 ] tegrahost_v2 --chip 0x19 --align tegra194-p3668-all-p3509-0000_sigheader.dtb
[ 3.9719 ]
[ 3.9720 ] header_magic: 4e564441
[ 3.9746 ] tegrasign_v3.py --key /home/akter/.xkeys/SBK --list tegra194-p3668-all-p3509-0000_sigheader.dtb_list.xml
[ 3.9747 ] Key is a SBK key
[ 3.9747 ] Key Size is 16 bytes
[ 3.9753 ] 204640
[ 3.9869 ] tegrahost_v2 --chip 0x19 0 --updatesigheader tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt tegra194-p3668-all-p3509-0000_sigheader.dtb.hash zerosbk
[ 3.9901 ]
[ 3.9923 ] tegrahost_v2 --chip 0x19 --align tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt
[ 3.9931 ]
[ 3.9932 ] header_magic: 4e564441
[ 3.9957 ] tegrasign_v3.py --key /home/akter/.xkeys/rsa_priv.pem --list tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt_list.xml --pubkeyhash pub_key.key
[ 3.9974 ] K[ 3.9977 ] ey size is 384 bytes
[ 4.0433 ] Saving pkc public key in pub_key.key
[ 4.0455 ] tegrahost_v2 --chip 0x19 0 --updatesigheader tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt.signed tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt.sig oem-rsa --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 4.0486 ]
[ 4.0511 ] tegrahost_v2 --chip 0x19 --align tos-trusty_t194_sigheader.img
[ 4.0519 ]
[ 4.0520 ] header_magic: 4e564441
[ 4.0545 ] tegrasign_v3.py --key /home/akter/.xkeys/SBK --list tos-trusty_t194_sigheader.img_list.xml
[ 4.0546 ] Key is a SBK key
[ 4.0546 ] Key Size is 16 bytes
[ 4.0554 ] 406464
[ 4.0726 ] tegrahost_v2 --chip 0x19 0 --updatesigheader tos-trusty_t194_sigheader.img.encrypt tos-trusty_t194_sigheader.img.hash zerosbk
[ 4.0784 ]
[ 4.0809 ] tegrahost_v2 --chip 0x19 --align tos-trusty_t194_sigheader.img.encrypt
[ 4.0817 ]
[ 4.0818 ] header_magic: 4e564441
[ 4.0844 ] tegrasign_v3.py --key /home/akter/.xkeys/rsa_priv.pem --list tos-trusty_t194_sigheader.img.encrypt_list.xml --pubkeyhash pub_key.key
[ 4.0862 ] K[ 4.0865 ] ey size is 384 bytes
[ 4.1323 ] Saving pkc public key in pub_key.key
[ 4.1344 ] tegrahost_v2 --chip 0x19 0 --updatesigheader tos-trusty_t194_sigheader.img.encrypt.signed tos-trusty_t194_sigheader.img.encrypt.sig oem-rsa --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 4.1396 ]
[ 4.1423 ] tegrahost_v2 --chip 0x19 --align tos-trusty_t194_sigheader.img
[ 4.1431 ]
[ 4.1433 ] header_magic: 4e564441
[ 4.1458 ] tegrasign_v3.py --key /home/akter/.xkeys/SBK --list tos-trusty_t194_sigheader.img_list.xml
[ 4.1459 ] Key is a SBK key
[ 4.1459 ] Key Size is 16 bytes
[ 4.1467 ] 406464
[ 4.1646 ] tegrahost_v2 --chip 0x19 0 --updatesigheader tos-trusty_t194_sigheader.img.encrypt tos-trusty_t194_sigheader.img.hash zerosbk
[ 4.1703 ]
[ 4.1725 ] tegrahost_v2 --chip 0x19 --align tos-trusty_t194_sigheader.img.encrypt
[ 4.1734 ]
[ 4.1735 ] header_magic: 4e564441
[ 4.1761 ] tegrasign_v3.py --key /home/akter/.xkeys/rsa_priv.pem --list tos-trusty_t194_sigheader.img.encrypt_list.xml --pubkeyhash pub_key.key
[ 4.1778 ] K[ 4.1781 ] ey size is 384 bytes
[ 4.2237 ] Saving pkc public key in pub_key.key
[ 4.2258 ] tegrahost_v2 --chip 0x19 0 --updatesigheader tos-trusty_t194_sigheader.img.encrypt.signed tos-trusty_t194_sigheader.img.encrypt.sig oem-rsa --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 4.2311 ]
[ 4.2337 ] tegrahost_v2 --chip 0x19 --align eks_sigheader.img
[ 4.2345 ]
[ 4.2346 ] header_magic: 4e564441
[ 4.2371 ] tegrasign_v3.py --key /home/akter/.xkeys/SBK --list eks_sigheader.img_list.xml
[ 4.2373 ] Key is a SBK key
[ 4.2373 ] Key Size is 16 bytes
[ 4.2375 ] 1040
[ 4.2434 ] tegrahost_v2 --chip 0x19 0 --updatesigheader eks_sigheader.img.encrypt eks_sigheader.img.hash zerosbk
[ 4.2444 ]
[ 4.2467 ] tegrahost_v2 --chip 0x19 --align eks_sigheader.img.encrypt
[ 4.2475 ]
[ 4.2477 ] header_magic: 4e564441
[ 4.2503 ] tegrasign_v3.py --key /home/akter/.xkeys/rsa_priv.pem --list eks_sigheader.img.encrypt_list.xml --pubkeyhash pub_key.key
[ 4.2520 ] K[ 4.2523 ] ey size is 384 bytes
[ 4.2983 ] Saving pkc public key in pub_key.key
[ 4.3003 ] tegrahost_v2 --chip 0x19 0 --updatesigheader eks_sigheader.img.encrypt.signed eks_sigheader.img.encrypt.sig oem-rsa --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 4.3012 ]
[ 4.3035 ] tegrahost_v2 --chip 0x19 --align eks_sigheader.img
[ 4.3043 ]
[ 4.3044 ] header_magic: 4e564441
[ 4.3069 ] tegrasign_v3.py --key /home/akter/.xkeys/SBK --list eks_sigheader.img_list.xml
[ 4.3071 ] Key is a SBK key
[ 4.3071 ] Key Size is 16 bytes
[ 4.3073 ] 1040
[ 4.3133 ] tegrahost_v2 --chip 0x19 0 --updatesigheader eks_sigheader.img.encrypt eks_sigheader.img.hash zerosbk
[ 4.3142 ]
[ 4.3164 ] tegrahost_v2 --chip 0x19 --align eks_sigheader.img.encrypt
[ 4.3173 ]
[ 4.3174 ] header_magic: 4e564441
[ 4.3200 ] tegrasign_v3.py --key /home/akter/.xkeys/rsa_priv.pem --list eks_sigheader.img.encrypt_list.xml --pubkeyhash pub_key.key
[ 4.3217 ] K[ 4.3220 ] ey size is 384 bytes
[ 4.3671 ] Saving pkc public key in pub_key.key
[ 4.3689 ] tegrahost_v2 --chip 0x19 0 --updatesigheader eks_sigheader.img.encrypt.signed eks_sigheader.img.encrypt.sig oem-rsa --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 4.3698 ]
[ 4.3720 ] tegrahost_v2 --chip 0x19 --align adsp-fw_sigheader.bin
[ 4.3728 ]
[ 4.3729 ] header_magic: 4e564441
[ 4.3752 ] tegrasign_v3.py --key /home/akter/.xkeys/SBK --list adsp-fw_sigheader.bin_list.xml
[ 4.3753 ] Key is a SBK key
[ 4.3753 ] Key Size is 16 bytes
[ 4.3757 ] 77216
[ 4.3833 ] tegrahost_v2 --chip 0x19 0 --updatesigheader adsp-fw_sigheader.bin.encrypt adsp-fw_sigheader.bin.hash zerosbk
[ 4.3852 ]
[ 4.3873 ] tegrahost_v2 --chip 0x19 --align adsp-fw_sigheader.bin.encrypt
[ 4.3882 ]
[ 4.3883 ] header_magic: 4e564441
[ 4.3908 ] tegrasign_v3.py --key /home/akter/.xkeys/rsa_priv.pem --list adsp-fw_sigheader.bin.encrypt_list.xml --pubkeyhash pub_key.key
[ 4.3925 ] K[ 4.3928 ] ey size is 384 bytes
[ 4.4380 ] Saving pkc public key in pub_key.key
[ 4.4401 ] tegrahost_v2 --chip 0x19 0 --updatesigheader adsp-fw_sigheader.bin.encrypt.signed adsp-fw_sigheader.bin.encrypt.sig oem-rsa --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 4.4417 ]
[ 4.4441 ] tegrahost_v2 --chip 0x19 --align adsp-fw_sigheader.bin
[ 4.4449 ]
[ 4.4450 ] header_magic: 4e564441
[ 4.4473 ] tegrasign_v3.py --key /home/akter/.xkeys/SBK --list adsp-fw_sigheader.bin_list.xml
[ 4.4475 ] Key is a SBK key
[ 4.4475 ] Key Size is 16 bytes
[ 4.4478 ] 77216
[ 4.4557 ] tegrahost_v2 --chip 0x19 0 --updatesigheader adsp-fw_sigheader.bin.encrypt adsp-fw_sigheader.bin.hash zerosbk
[ 4.4575 ]
[ 4.4597 ] tegrahost_v2 --chip 0x19 --align adsp-fw_sigheader.bin.encrypt
[ 4.4605 ]
[ 4.4606 ] header_magic: 4e564441
[ 4.4632 ] tegrasign_v3.py --key /home/akter/.xkeys/rsa_priv.pem --list adsp-fw_sigheader.bin.encrypt_list.xml --pubkeyhash pub_key.key
[ 4.4650 ] K[ 4.4653 ] ey size is 384 bytes
[ 4.5101 ] Saving pkc public key in pub_key.key
[ 4.5122 ] tegrahost_v2 --chip 0x19 0 --updatesigheader adsp-fw_sigheader.bin.encrypt.signed adsp-fw_sigheader.bin.encrypt.sig oem-rsa --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 4.5139 ]
[ 4.5162 ] tegrahost_v2 --chip 0x19 --align camera-rtcpu-rce_sigheader.img
[ 4.5170 ]
[ 4.5171 ] header_magic: 4e564441
[ 4.5195 ] tegrasign_v3.py --key /home/akter/.xkeys/SBK --list camera-rtcpu-rce_sigheader.img_list.xml
[ 4.5196 ] Key is a SBK key
[ 4.5196 ] Key Size is 16 bytes
[ 4.5203 ] 267808
[ 4.5332 ] tegrahost_v2 --chip 0x19 0 --updatesigheader camera-rtcpu-rce_sigheader.img.encrypt camera-rtcpu-rce_sigheader.img.hash zerosbk
[ 4.5372 ]
[ 4.5393 ] tegrahost_v2 --chip 0x19 --align camera-rtcpu-rce_sigheader.img.encrypt
[ 4.5402 ]
[ 4.5403 ] header_magic: 4e564441
[ 4.5429 ] tegrasign_v3.py --key /home/akter/.xkeys/rsa_priv.pem --list camera-rtcpu-rce_sigheader.img.encrypt_list.xml --pubkeyhash pub_key.key
[ 4.5448 ] K[ 4.5451 ] ey size is 384 bytes
[ 4.5903 ] Saving pkc public key in pub_key.key
[ 4.5924 ] tegrahost_v2 --chip 0x19 0 --updatesigheader camera-rtcpu-rce_sigheader.img.encrypt.signed camera-rtcpu-rce_sigheader.img.encrypt.sig oem-rsa --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 4.5960 ]
[ 4.5986 ] tegrahost_v2 --chip 0x19 --align camera-rtcpu-rce_sigheader.img
[ 4.5994 ]
[ 4.5995 ] header_magic: 4e564441
[ 4.6020 ] tegrasign_v3.py --key /home/akter/.xkeys/SBK --list camera-rtcpu-rce_sigheader.img_list.xml
[ 4.6022 ] Key is a SBK key
[ 4.6022 ] Key Size is 16 bytes
[ 4.6028 ] 267808
[ 4.6166 ] tegrahost_v2 --chip 0x19 0 --updatesigheader camera-rtcpu-rce_sigheader.img.encrypt camera-rtcpu-rce_sigheader.img.hash zerosbk
[ 4.6206 ]
[ 4.6227 ] tegrahost_v2 --chip 0x19 --align camera-rtcpu-rce_sigheader.img.encrypt
[ 4.6236 ]
[ 4.6237 ] header_magic: 4e564441
[ 4.6263 ] tegrasign_v3.py --key /home/akter/.xkeys/rsa_priv.pem --list camera-rtcpu-rce_sigheader.img.encrypt_list.xml --pubkeyhash pub_key.key
[ 4.6281 ] K[ 4.6284 ] ey size is 384 bytes
[ 4.6747 ] Saving pkc public key in pub_key.key
[ 4.6768 ] tegrahost_v2 --chip 0x19 0 --updatesigheader camera-rtcpu-rce_sigheader.img.encrypt.signed camera-rtcpu-rce_sigheader.img.encrypt.sig oem-rsa --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 4.6806 ]
[ 4.6831 ] tegrahost_v2 --chip 0x19 --align bpmp_t194_sigheader.bin
[ 4.6840 ]
[ 4.6841 ] header_magic: 4e564441
[ 4.6865 ] tegrasign_v3.py --key /home/akter/.xkeys/SBK --list bpmp_t194_sigheader.bin_list.xml
[ 4.6866 ] Key is a SBK key
[ 4.6866 ] Key Size is 16 bytes
[ 4.6881 ] 852256
[ 4.7200 ] tegrahost_v2 --chip 0x19 0 --updatesigheader bpmp_t194_sigheader.bin.encrypt bpmp_t194_sigheader.bin.hash zerosbk
[ 4.7312 ]
[ 4.7336 ] tegrahost_v2 --chip 0x19 --align bpmp_t194_sigheader.bin.encrypt
[ 4.7345 ]
[ 4.7346 ] header_magic: 4e564441
[ 4.7372 ] tegrasign_v3.py --key /home/akter/.xkeys/rsa_priv.pem --list bpmp_t194_sigheader.bin.encrypt_list.xml --pubkeyhash pub_key.key
[ 4.7391 ] K[ 4.7394 ] ey size is 384 bytes
[ 4.7877 ] Saving pkc public key in pub_key.key
[ 4.7898 ] tegrahost_v2 --chip 0x19 0 --updatesigheader bpmp_t194_sigheader.bin.encrypt.signed bpmp_t194_sigheader.bin.encrypt.sig oem-rsa --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 4.8002 ]
[ 4.8032 ] tegrahost_v2 --chip 0x19 --align bpmp_t194_sigheader.bin
[ 4.8041 ]
[ 4.8042 ] header_magic: 4e564441
[ 4.8068 ] tegrasign_v3.py --key /home/akter/.xkeys/SBK --list bpmp_t194_sigheader.bin_list.xml
[ 4.8070 ] Key is a SBK key
[ 4.8070 ] Key Size is 16 bytes
[ 4.8086 ] 852256
[ 4.8410 ] tegrahost_v2 --chip 0x19 0 --updatesigheader bpmp_t194_sigheader.bin.encrypt bpmp_t194_sigheader.bin.hash zerosbk
[ 4.8524 ]
[ 4.8547 ] tegrahost_v2 --chip 0x19 --align bpmp_t194_sigheader.bin.encrypt
[ 4.8556 ]
[ 4.8557 ] header_magic: 4e564441
[ 4.8583 ] tegrasign_v3.py --key /home/akter/.xkeys/rsa_priv.pem --list bpmp_t194_sigheader.bin.encrypt_list.xml --pubkeyhash pub_key.key
[ 4.8602 ] K[ 4.8605 ] ey size is 384 bytes
[ 4.9079 ] Saving pkc public key in pub_key.key
[ 4.9100 ] tegrahost_v2 --chip 0x19 0 --updatesigheader bpmp_t194_sigheader.bin.encrypt.signed bpmp_t194_sigheader.bin.encrypt.sig oem-rsa --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 4.9205 ]
[ 4.9237 ] tegrahost_v2 --chip 0x19 --align tegra194-a02-bpmp-p3668-a00_sigheader.dtb
[ 4.9246 ]
[ 4.9247 ] header_magic: 4e564441
[ 4.9273 ] tegrasign_v3.py --key /home/akter/.xkeys/SBK --list tegra194-a02-bpmp-p3668-a00_sigheader.dtb_list.xml
[ 4.9274 ] Key is a SBK key
[ 4.9274 ] Key Size is 16 bytes
[ 4.9283 ] 387312
[ 4.9464 ] tegrahost_v2 --chip 0x19 0 --updatesigheader tegra194-a02-bpmp-p3668-a00_sigheader.dtb.encrypt tegra194-a02-bpmp-p3668-a00_sigheader.dtb.hash zerosbk
[ 4.9522 ]
[ 4.9543 ] tegrahost_v2 --chip 0x19 --align tegra194-a02-bpmp-p3668-a00_sigheader.dtb.encrypt
[ 4.9553 ]
[ 4.9554 ] header_magic: 4e564441
[ 4.9580 ] tegrasign_v3.py --key /home/akter/.xkeys/rsa_priv.pem --list tegra194-a02-bpmp-p3668-a00_sigheader.dtb.encrypt_list.xml --pubkeyhash pub_key.key
[ 4.9598 ] K[ 4.9601 ] ey size is 384 bytes
[ 5.0070 ] Saving pkc public key in pub_key.key
[ 5.0091 ] tegrahost_v2 --chip 0x19 0 --updatesigheader tegra194-a02-bpmp-p3668-a00_sigheader.dtb.encrypt.signed tegra194-a02-bpmp-p3668-a00_sigheader.dtb.encrypt.sig oem-rsa --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 5.0143 ]
[ 5.0169 ] tegrahost_v2 --chip 0x19 --align tegra194-a02-bpmp-p3668-a00_sigheader.dtb
[ 5.0177 ]
[ 5.0178 ] header_magic: 4e564441
[ 5.0203 ] tegrasign_v3.py --key /home/akter/.xkeys/SBK --list tegra194-a02-bpmp-p3668-a00_sigheader.dtb_list.xml
[ 5.0205 ] Key is a SBK key
[ 5.0205 ] Key Size is 16 bytes
[ 5.0213 ] 387312
[ 5.0389 ] tegrahost_v2 --chip 0x19 0 --updatesigheader tegra194-a02-bpmp-p3668-a00_sigheader.dtb.encrypt tegra194-a02-bpmp-p3668-a00_sigheader.dtb.hash zerosbk
[ 5.0445 ]
[ 5.0466 ] tegrahost_v2 --chip 0x19 --align tegra194-a02-bpmp-p3668-a00_sigheader.dtb.encrypt
[ 5.0475 ]
[ 5.0476 ] header_magic: 4e564441
[ 5.0502 ] tegrasign_v3.py --key /home/akter/.xkeys/rsa_priv.pem --list tegra194-a02-bpmp-p3668-a00_sigheader.dtb.encrypt_list.xml --pubkeyhash pub_key.key
[ 5.0520 ] K[ 5.0523 ] ey size is 384 bytes
[ 5.0985 ] Saving pkc public key in pub_key.key
[ 5.1007 ] tegrahost_v2 --chip 0x19 0 --updatesigheader tegra194-a02-bpmp-p3668-a00_sigheader.dtb.encrypt.signed tegra194-a02-bpmp-p3668-a00_sigheader.dtb.encrypt.sig oem-rsa --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 5.1059 ]
[ 5.1086 ] tegrahost_v2 --chip 0x19 --align boot_sigheader.img
[ 5.1094 ]
[ 5.1095 ] header_magic: 4e564441
[ 5.1121 ] tegrasign_v3.py --key /home/akter/.xkeys/SBK --list boot_sigheader.img_list.xml
[ 5.1122 ] Key is a SBK key
[ 5.1122 ] Key Size is 16 bytes
[ 5.1125 ] 32
[ 5.1188 ] tegrahost_v2 --chip 0x19 0 --updatesigheader boot_sigheader.img.encrypt boot_sigheader.img.hash zerosbk
[ 5.1198 ]
[ 5.1220 ] tegrahost_v2 --chip 0x19 --align boot_sigheader.img.encrypt
[ 5.1229 ]
[ 5.1230 ] header_magic: 4e564441
[ 5.1256 ] tegrasign_v3.py --key /home/akter/.xkeys/rsa_priv.pem --list boot_sigheader.img.encrypt_list.xml --pubkeyhash pub_key.key
[ 5.1274 ] K[ 5.1277 ] ey size is 384 bytes
[ 5.1734 ] Saving pkc public key in pub_key.key
[ 5.1755 ] tegrahost_v2 --chip 0x19 0 --updatesigheader boot_sigheader.img.encrypt.signed boot_sigheader.img.encrypt.sig oem-rsa --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 5.1764 ]
[ 5.1787 ] tegrahost_v2 --chip 0x19 --align boot_sigheader.img
[ 5.1795 ]
[ 5.1796 ] header_magic: 4e564441
[ 5.1820 ] tegrasign_v3.py --key /home/akter/.xkeys/SBK --list boot_sigheader.img_list.xml
[ 5.1822 ] Key is a SBK key
[ 5.1822 ] Key Size is 16 bytes
[ 5.1824 ] 32
[ 5.1885 ] tegrahost_v2 --chip 0x19 0 --updatesigheader boot_sigheader.img.encrypt boot_sigheader.img.hash zerosbk
[ 5.1895 ]
[ 5.1918 ] tegrahost_v2 --chip 0x19 --align boot_sigheader.img.encrypt
[ 5.1926 ]
[ 5.1927 ] header_magic: 4e564441
[ 5.1954 ] tegrasign_v3.py --key /home/akter/.xkeys/rsa_priv.pem --list boot_sigheader.img.encrypt_list.xml --pubkeyhash pub_key.key
[ 5.1972 ] K[ 5.1975 ] ey size is 384 bytes
[ 5.2439 ] Saving pkc public key in pub_key.key
[ 5.2460 ] tegrahost_v2 --chip 0x19 0 --updatesigheader boot_sigheader.img.encrypt.signed boot_sigheader.img.encrypt.sig oem-rsa --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 5.2468 ]
[ 5.2490 ] tegrahost_v2 --chip 0x19 --align tegra194-p3668-all-p3509-0000_sigheader.dtb
[ 5.2498 ]
[ 5.2499 ] header_magic: 4e564441
[ 5.2525 ] tegrasign_v3.py --key /home/akter/.xkeys/SBK --list tegra194-p3668-all-p3509-0000_sigheader.dtb_list.xml
[ 5.2526 ] Key is a SBK key
[ 5.2526 ] Key Size is 16 bytes
[ 5.2532 ] 204640
[ 5.2655 ] tegrahost_v2 --chip 0x19 0 --updatesigheader tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt tegra194-p3668-all-p3509-0000_sigheader.dtb.hash zerosbk
[ 5.2689 ]
[ 5.2710 ] tegrahost_v2 --chip 0x19 --align tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt
[ 5.2719 ]
[ 5.2720 ] header_magic: 4e564441
[ 5.2746 ] tegrasign_v3.py --key /home/akter/.xkeys/rsa_priv.pem --list tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt_list.xml --pubkeyhash pub_key.key
[ 5.2765 ] K[ 5.2768 ] ey size is 384 bytes
[ 5.3235 ] Saving pkc public key in pub_key.key
[ 5.3256 ] tegrahost_v2 --chip 0x19 0 --updatesigheader tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt.signed tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt.sig oem-rsa --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 5.3287 ]
[ 5.3311 ] tegrahost_v2 --chip 0x19 --align tegra194-p3668-all-p3509-0000_sigheader.dtb
[ 5.3319 ]
[ 5.3320 ] header_magic: 4e564441
[ 5.3345 ] tegrasign_v3.py --key /home/akter/.xkeys/SBK --list tegra194-p3668-all-p3509-0000_sigheader.dtb_list.xml
[ 5.3346 ] Key is a SBK key
[ 5.3346 ] Key Size is 16 bytes
[ 5.3352 ] 204640
[ 5.3472 ] tegrahost_v2 --chip 0x19 0 --updatesigheader tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt tegra194-p3668-all-p3509-0000_sigheader.dtb.hash zerosbk
[ 5.3506 ]
[ 5.3528 ] tegrahost_v2 --chip 0x19 --align tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt
[ 5.3537 ]
[ 5.3538 ] header_magic: 4e564441
[ 5.3565 ] tegrasign_v3.py --key /home/akter/.xkeys/rsa_priv.pem --list tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt_list.xml --pubkeyhash pub_key.key
[ 5.3583 ] K[ 5.3585 ] ey size is 384 bytes
[ 5.4047 ] Saving pkc public key in pub_key.key
[ 5.4068 ] tegrahost_v2 --chip 0x19 0 --updatesigheader tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt.signed tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt.sig oem-rsa --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 5.4098 ]
[ 5.4151 ] tegrahost_v2 --chip 0x19 --align nvtboot_recovery_t194.bin
[ 5.4160 ]
[ 5.4161 ] header_magic: 50000ea
[ 5.4185 ] tegrasign_v3.py --key /home/akter/.xkeys/SBK --list nvtboot_recovery_t194.bin_list.xml
[ 5.4186 ] Key is a SBK key
[ 5.4187 ] Key Size is 16 bytes
[ 5.4191 ] 177056
[ 5.4304 ] tegrahost_v2 --chip 0x19 0 --updatesigheader nvtboot_recovery_t194.bin.encrypt nvtboot_recovery_t194.bin.hash zerosbk
[ 5.4316 ]
[ 5.4338 ] tegrahost_v2 --chip 0x19 --align nvtboot_recovery_t194.bin.encrypt
[ 5.4347 ]
[ 5.4348 ] header_magic: a3ed885d
[ 5.4369 ] tegrahost_v2 --appendsigheader nvtboot_recovery_t194.bin.encrypt oem-rsa-sbk --chip 0x19 0 --magicid MB2B --ratchet_blob ratchet_blob.bin
[ 5.4378 ] adding BCH for nvtboot_recovery_t194.bin.encrypt
[ 5.4422 ]
[ 5.4449 ] tegrasign_v3.py --key /home/akter/.xkeys/rsa_priv.pem --list nvtboot_recovery_t194.bin_sigheader.encrypt_list.xml --pubkeyhash pub_key.key
[ 5.4468 ] K[ 5.4471 ] ey size is 384 bytes
[ 5.4944 ] Saving pkc public key in pub_key.key
[ 5.4965 ] tegrahost_v2 --chip 0x19 0 --updatesigheader nvtboot_recovery_t194.bin_sigheader.encrypt.signed nvtboot_recovery_t194.bin_sigheader.encrypt.sig oem-rsa --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 5.4993 ]
[ 5.5014 ] tegrahost_v2 --chip 0x19 --align nvtboot_recovery_cpu_t194.bin
[ 5.5022 ]
[ 5.5024 ] header_magic: 9000014
[ 5.5049 ] tegrasign_v3.py --key /home/akter/.xkeys/SBK --list nvtboot_recovery_cpu_t194.bin_list.xml
[ 5.5050 ] Key is a SBK key
[ 5.5050 ] Key Size is 16 bytes
[ 5.5055 ] 259968
[ 5.5189 ] tegrahost_v2 --chip 0x19 0 --updatesigheader nvtboot_recovery_cpu_t194.bin.encrypt nvtboot_recovery_cpu_t194.bin.hash zerosbk
[ 5.5201 ]
[ 5.5224 ] tegrahost_v2 --chip 0x19 --align nvtboot_recovery_cpu_t194.bin.encrypt
[ 5.5232 ]
[ 5.5234 ] header_magic: f40572f3
[ 5.5255 ] tegrahost_v2 --appendsigheader nvtboot_recovery_cpu_t194.bin.encrypt oem-rsa-sbk --chip 0x19 0 --magicid CPBL --ratchet_blob ratchet_blob.bin
[ 5.5263 ] adding BCH for nvtboot_recovery_cpu_t194.bin.encrypt
[ 5.5324 ]
[ 5.5351 ] tegrasign_v3.py --key /home/akter/.xkeys/rsa_priv.pem --list nvtboot_recovery_cpu_t194.bin_sigheader.encrypt_list.xml --pubkeyhash pub_key.key
[ 5.5369 ] K[ 5.5372 ] ey size is 384 bytes
[ 5.5851 ] Saving pkc public key in pub_key.key
[ 5.5870 ] tegrahost_v2 --chip 0x19 0 --updatesigheader nvtboot_recovery_cpu_t194.bin_sigheader.encrypt.signed nvtboot_recovery_cpu_t194.bin_sigheader.encrypt.sig oem-rsa --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 5.5907 ]
[ 5.5908 ] Copying signed file in /home/akter/nvidia/4.6.1/Linux_for_Tegra_massfuse/bootloader/encrypted_signed_t19x
[ 5.5915 ] Generating br-bct
[ 5.5937 ] Performing cfg overlay
[ 5.5937 ] ['/home/akter/nvidia/4.6.1/Linux_for_Tegra_massfuse/bootloader/11869/tmp4x_6gf_l1.cfg']
[ 5.5937 ] Updating dev and MSS params in BR BCT
[ 5.5937 ] tegrabct_v2 --dev_param tegra194-br-bct-qspi.cfg --sdram /home/akter/nvidia/4.6.1/Linux_for_Tegra_massfuse/bootloader/11869/tmp4x_6gf_l1.cfg --brbct br_bct.cfg --sfuse tegra194-mb1-soft-fuses-l4t.cfg --chip 0x19 0
[ 5.6515 ]
[ 5.6516 ] Updating bl info
[ 5.6537 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updateblinfo flash.xml.bin
[ 5.6554 ]
[ 5.6555 ] Generating br-bct
[ 5.6575 ] Performing cfg overlay
[ 5.6575 ] ['/home/akter/nvidia/4.6.1/Linux_for_Tegra_massfuse/bootloader/11869/tmp4x_6gf_l1.cfg']
[ 5.6575 ] Updating dev and MSS params in BR BCT
[ 5.6576 ] tegrabct_v2 --dev_param tegra194-br-bct-qspi.cfg --sdram /home/akter/nvidia/4.6.1/Linux_for_Tegra_massfuse/bootloader/11869/tmp4x_6gf_l1.cfg --brbct br_bct.cfg --sfuse tegra194-mb1-soft-fuses-l4t.cfg --chip 0x19 0
[ 5.7145 ]
[ 5.7146 ] Updating bl info
[ 5.7167 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[ 5.7189 ]
[ 5.7189 ] Updating smd info
[ 5.7210 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 --updatesmdinfo flash.xml.bin
[ 5.7219 ]
[ 5.7220 ] Updating Odmdata
[ 5.7241 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updatefields Odmdata =0xB8190000
[ 5.7251 ]
[ 5.7251 ] Get encrypted section of bct
[ 5.7272 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --listencbct bct_list.xml
[ 5.7281 ]
[ 5.7281 ] Signing BCT
[ 5.7303 ] Generating signatures with encryption
[ 5.7325 ] tegrasign_v3.py --key /home/akter/.xkeys/SBK --offset 2328 --file br_bct_BR.bct
[ 5.7333 ] Key is a SBK key
[ 5.7528 ] Key Size is 16 bytes
[ 5.7530 ] 560
[ 5.7593 ]
[ 5.7594 ] Updating BCT with signature
[ 5.7598 ] Get Signed section of bct
[ 5.7622 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --listbct bct_list.xml
[ 5.7636 ]
[ 5.7659 ] tegrasign_v3.py --key /home/akter/.xkeys/rsa_priv.pem --list bct_list.xml --pubkeyhash pub_key.key --getmontgomeryvalues montgomery.bin
[ 5.7669 ] Key size is 384 bytes
[ 5.8438 ] Saving pkc public key in pub_key.key
[ 5.8473 ] Saving Montgomery values in montgomery.bin
[ 5.8475 ]
[ 5.8476 ] Updating BCT with signature
[ 5.8498 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updatesig bct_list_signed.xml --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 5.8510 ]
[ 5.8511 ] Generating coldboot mb1-bct
[ 5.8536 ] tegrabct_v2 --chip 0x19 0 --mb1bct mb1_cold_boot_bct.cfg --sdram /home/akter/nvidia/4.6.1/Linux_for_Tegra_massfuse/bootloader/11869/tmp4x_6gf_l1.cfg --misc tegra194-mb1-bct-misc-l4t.cfg --scr tegra194-mb1-bct-scr-cbb-mini-p3668.cfg --pinmux tegra19x-mb1-pinmux-p3668-a01.cfg --pmc tegra19x-mb1-padvoltage-p3668-a01.cfg --pmic tegra194-mb1-bct-pmic-p3668-0001-a00.cfg --brcommand tegra194-mb1-bct-reset-p3668-0001-a00.cfg --prod tegra19x-mb1-prod-p3668-0001-a00.cfg --gpioint tegra194-mb1-bct-gpioint-p3668-0001-a00.cfg --device tegra19x-mb1-bct-device-qspi-p3668.cfg
[ 5.8545 ] MB1-BCT version: 0x1
[ 5.8548 ] Parsing config file :tegra19x-mb1-pinmux-p3668-a01.cfg
[ 5.8551 ] Added Platform Config 0 data with size :- 2496
[ 5.8568 ] Parsing config file :tegra194-mb1-bct-scr-cbb-mini-p3668.cfg
[ 5.8571 ] Added Platform Config 1 data with size :- 19640
[ 5.8734 ] Parsing config file :tegra19x-mb1-padvoltage-p3668-a01.cfg
[ 5.8737 ] Added Platform Config 2 data with size :- 24
[ 5.8740 ] Parsing config file :tegra194-mb1-bct-pmic-p3668-0001-a00.cfg
[ 5.8744 ] Added Platform Config 4 data with size :- 348
[ 5.8746 ] Parsing config file :tegra194-mb1-bct-reset-p3668-0001-a00.cfg
[ 5.8749 ] Added Platform Config 3 data with size :- 92
[ 5.8751 ] Parsing config file :tegra19x-mb1-prod-p3668-0001-a00.cfg
[ 5.8755 ] Added Platform Config 5 data with size :- 128
[ 5.8757 ]
[ 5.8757 ] Parsing config file :tegra194-mb1-bct-gpioint-p3668-0001-a00.cfg
[ 5.8757 ] Added Platform Config 7 data with size :- 392
[ 5.8757 ]
[ 5.8757 ] Parsing config file :tegra19x-mb1-bct-device-qspi-p3668.cfg
[ 5.8757 ] Added Platform Config 9 data with size :- 40
[ 5.8757 ]
[ 5.8758 ] Updating mb1-bct with firmware information
[ 5.8782 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo flash.xml.bin
[ 5.8791 ] MB1-BCT version: 0x1
[ 5.8794 ]
[ 5.8794 ] Updating mb1-bct with storage information
[ 5.8817 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_cold_boot_bct_MB1.bct --updatestorageinfo flash.xml.bin
[ 5.8825 ] MB1-BCT version: 0x1
[ 5.8828 ]
[ 5.8828 ] Updating mb1-bct with ratchet information
[ 5.8850 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_cold_boot_bct_MB1.bct --minratchet tegra194-mb1-bct-ratchet-p3668.cfg
[ 5.8859 ] MB1-BCT version: 0x1
[ 5.8861 ] FwIndex: 1, MinRatchetLevel: 0
[ 5.8862 ] FwIndex: 2, MinRatchetLevel: 0
[ 5.8862 ] FwIndex: 3, MinRatchetLevel: 0
[ 5.8862 ] FwIndex: 4, MinRatchetLevel: 0
[ 5.8862 ] FwIndex: 5, MinRatchetLevel: 0
[ 5.8862 ] FwIndex: 6, MinRatchetLevel: 0
[ 5.8862 ] FwIndex: 7, MinRatchetLevel: 0
[ 5.8862 ] FwIndex: 11, MinRatchetLevel: 0
[ 5.8862 ] FwIndex: 12, MinRatchetLevel: 0
[ 5.8862 ] FwIndex: 13, MinRatchetLevel: 0
[ 5.8862 ] FwIndex: 14, MinRatchetLevel: 0
[ 5.8862 ] FwIndex: 15, MinRatchetLevel: 0
[ 5.8862 ] FwIndex: 16, MinRatchetLevel: 0
[ 5.8863 ] FwIndex: 17, MinRatchetLevel: 0
[ 5.8863 ] FwIndex: 18, MinRatchetLevel: 0
[ 5.8863 ] FwIndex: 19, MinRatchetLevel: 0
[ 5.8863 ] FwIndex: 30, MinRatchetLevel: 0
[ 5.8863 ] FwIndex: 31, MinRatchetLevel: 0
[ 5.8863 ] FwIndex: 32, MinRatchetLevel: 0
[ 5.8863 ]
[ 5.8885 ] tegrahost_v2 --chip 0x19 --align mb1_cold_boot_bct_MB1.bct
[ 5.8894 ]
[ 5.8896 ] header_magic: c0660000
[ 5.8922 ] tegrasign_v3.py --key /home/akter/.xkeys/SBK --list mb1_cold_boot_bct_MB1.bct_list.xml
[ 5.8923 ] Key is a SBK key
[ 5.8923 ] Key Size is 16 bytes
[ 5.8927 ] 26304
[ 5.8999 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_cold_boot_bct_MB1.bct.encrypt mb1_cold_boot_bct_MB1.bct.hash zerosbk
[ 5.9009 ]
[ 5.9030 ] tegrahost_v2 --chip 0x19 --align mb1_cold_boot_bct_MB1.bct.encrypt
[ 5.9039 ]
[ 5.9040 ] header_magic: 1fada471
[ 5.9062 ] tegrahost_v2 --appendsigheader mb1_cold_boot_bct_MB1.bct.encrypt oem-rsa-sbk --chip 0x19 0 --magicid MBCT --ratchet_blob ratchet_blob.bin
[ 5.9071 ] adding BCH for mb1_cold_boot_bct_MB1.bct.encrypt
[ 5.9080 ]
[ 5.9106 ] tegrasign_v3.py --key /home/akter/.xkeys/rsa_priv.pem --list mb1_cold_boot_bct_MB1.bct_sigheader.encrypt_list.xml --pubkeyhash pub_key.key
[ 5.9124 ] K[ 5.9128 ] ey size is 384 bytes
[ 5.9605 ] Saving pkc public key in pub_key.key
[ 5.9626 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_cold_boot_bct_MB1.bct_sigheader.encrypt.signed mb1_cold_boot_bct_MB1.bct_sigheader.encrypt.sig oem-rsa --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 5.9638 ]
[ 5.9639 ] Generating recovery mb1-bct
[ 5.9662 ] tegrabct_v2 --chip 0x19 0 --mb1bct mb1_bct.cfg --sdram /home/akter/nvidia/4.6.1/Linux_for_Tegra_massfuse/bootloader/11869/tmp4x_6gf_l1.cfg --misc tegra194-mb1-bct-misc-flash.cfg --scr tegra194-mb1-bct-scr-cbb-mini-p3668.cfg --pinmux tegra19x-mb1-pinmux-p3668-a01.cfg --pmc tegra19x-mb1-padvoltage-p3668-a01.cfg --pmic tegra194-mb1-bct-pmic-p3668-0001-a00.cfg --brcommand tegra194-mb1-bct-reset-p3668-0001-a00.cfg --prod tegra19x-mb1-prod-p3668-0001-a00.cfg --gpioint tegra194-mb1-bct-gpioint-p3668-0001-a00.cfg --device tegra19x-mb1-bct-device-qspi-p3668.cfg
[ 5.9670 ] MB1-BCT version: 0x1
[ 5.9673 ] Parsing config file :tegra19x-mb1-pinmux-p3668-a01.cfg
[ 5.9678 ] Added Platform Config 0 data with size :- 2496
[ 5.9692 ] Parsing config file :tegra194-mb1-bct-scr-cbb-mini-p3668.cfg
[ 5.9696 ] Added Platform Config 1 data with size :- 19640
[ 5.9841 ] Parsing config file :tegra19x-mb1-padvoltage-p3668-a01.cfg
[ 5.9845 ] Added Platform Config 2 data with size :- 24
[ 5.9849 ] Parsing config file :tegra194-mb1-bct-pmic-p3668-0001-a00.cfg
[ 5.9853 ] Added Platform Config 4 data with size :- 348
[ 5.9857 ] Parsing config file :tegra194-mb1-bct-reset-p3668-0001-a00.cfg
[ 5.9858 ] Added Platform Config 3 data with size :- 92
[ 5.9858 ]
[ 5.9858 ] Parsing config file :tegra19x-mb1-prod-p3668-0001-a00.cfg
[ 5.9858 ] Added Platform Config 5 data with size :- 128
[ 5.9858 ]
[ 5.9858 ] Parsing config file :tegra194-mb1-bct-gpioint-p3668-0001-a00.cfg
[ 5.9858 ] Added Platform Config 7 data with size :- 392
[ 5.9858 ]
[ 5.9858 ] Parsing config file :tegra19x-mb1-bct-device-qspi-p3668.cfg
[ 5.9858 ] Added Platform Config 9 data with size :- 40
[ 5.9859 ]
[ 5.9859 ] Updating mb1-bct with firmware information
[ 5.9883 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_bct_MB1.bct --updatefwinfo flash.xml.bin
[ 5.9891 ] MB1-BCT version: 0x1
[ 5.9895 ]
[ 5.9895 ] Updating mb1-bct with storage information
[ 5.9917 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_bct_MB1.bct --updatestorageinfo flash.xml.bin
[ 5.9925 ] MB1-BCT version: 0x1
[ 5.9928 ]
[ 5.9928 ] Updating mb1-bct with ratchet information
[ 5.9951 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_bct_MB1.bct --minratchet tegra194-mb1-bct-ratchet-p3668.cfg
[ 5.9959 ] MB1-BCT version: 0x1
[ 5.9961 ] FwIndex: 1, MinRatchetLevel: 0
[ 5.9962 ] FwIndex: 2, MinRatchetLevel: 0
[ 5.9962 ] FwIndex: 3, MinRatchetLevel: 0
[ 5.9962 ] FwIndex: 4, MinRatchetLevel: 0
[ 5.9962 ] FwIndex: 5, MinRatchetLevel: 0
[ 5.9962 ] FwIndex: 6, MinRatchetLevel: 0
[ 5.9963 ] FwIndex: 7, MinRatchetLevel: 0
[ 5.9963 ] FwIndex: 11, MinRatchetLevel: 0
[ 5.9963 ] FwIndex: 12, MinRatchetLevel: 0
[ 5.9963 ] FwIndex: 13, MinRatchetLevel: 0
[ 5.9963 ] FwIndex: 14, MinRatchetLevel: 0
[ 5.9963 ] FwIndex: 15, MinRatchetLevel: 0
[ 5.9963 ] FwIndex: 16, MinRatchetLevel: 0
[ 5.9963 ] FwIndex: 17, MinRatchetLevel: 0
[ 5.9963 ] FwIndex: 18, MinRatchetLevel: 0
[ 5.9963 ] FwIndex: 19, MinRatchetLevel: 0
[ 5.9963 ] FwIndex: 30, MinRatchetLevel: 0
[ 5.9964 ] FwIndex: 31, MinRatchetLevel: 0
[ 5.9964 ] FwIndex: 32, MinRatchetLevel: 0
[ 5.9964 ]
[ 5.9985 ] tegrahost_v2 --chip 0x19 --align mb1_bct_MB1.bct
[ 5.9994 ]
[ 5.9996 ] header_magic: c0660000
[ 6.0021 ] tegrasign_v3.py --key /home/akter/.xkeys/SBK --list mb1_bct_MB1.bct_list.xml
[ 6.0023 ] Key is a SBK key
[ 6.0023 ] Key Size is 16 bytes
[ 6.0026 ] 26304
[ 6.0098 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_bct_MB1.bct.encrypt mb1_bct_MB1.bct.hash zerosbk
[ 6.0108 ]
[ 6.0131 ] tegrahost_v2 --chip 0x19 --align mb1_bct_MB1.bct.encrypt
[ 6.0140 ]
[ 6.0142 ] header_magic: 1fada471
[ 6.0163 ] tegrahost_v2 --appendsigheader mb1_bct_MB1.bct.encrypt oem-rsa-sbk --chip 0x19 0 --magicid MBCT --ratchet_blob ratchet_blob.bin
[ 6.0172 ] adding BCH for mb1_bct_MB1.bct.encrypt
[ 6.0180 ]
[ 6.0207 ] tegrasign_v3.py --key /home/akter/.xkeys/rsa_priv.pem --list mb1_bct_MB1.bct_sigheader.encrypt_list.xml --pubkeyhash pub_key.key
[ 6.0227 ] K[ 6.0230 ] ey size is 384 bytes
[ 6.0721 ] Saving pkc public key in pub_key.key
[ 6.0750 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_bct_MB1.bct_sigheader.encrypt.signed mb1_bct_MB1.bct_sigheader.encrypt.sig oem-rsa --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 6.0766 ]
[ 6.0767 ] Generating coldboot mem-bct
[ 6.0789 ] tegrabct_v2 --chip 0x19 0 --sdram /home/akter/nvidia/4.6.1/Linux_for_Tegra_massfuse/bootloader/11869/tmp4x_6gf_l1.cfg --membct /home/akter/nvidia/4.6.1/Linux_for_Tegra_massfuse/bootloader/11869/tmp4x_6gf_l1_1.bct /home/akter/nvidia/4.6.1/Linux_for_Tegra_massfuse/bootloader/11869/tmp4x_6gf_l1_2.bct /home/akter/nvidia/4.6.1/Linux_for_Tegra_massfuse/bootloader/11869/tmp4x_6gf_l1_3.bct /home/akter/nvidia/4.6.1/Linux_for_Tegra_massfuse/bootloader/11869/tmp4x_6gf_l1_4.bct
[ 6.0799 ] Packing sdram param for instance[0]
[ 6.1431 ] Packing sdram param for instance[1]
[ 6.1435 ] Packing sdram param for instance[2]
[ 6.1435 ] Packing sdram param for instance[3]
[ 6.1435 ] Packing sdram param for instance[4]
[ 6.1435 ] Packing sdram param for instance[5]
[ 6.1435 ] Packing sdram param for instance[6]
[ 6.1435 ] Packing sdram param for instance[7]
[ 6.1435 ] Packing sdram param for instance[8]
[ 6.1436 ] Packing sdram param for instance[9]
[ 6.1436 ] Packing sdram param for instance[10]
[ 6.1436 ] Packing sdram param for instance[11]
[ 6.1436 ] Packing sdram param for instance[12]
[ 6.1436 ] Packing sdram param for instance[13]
[ 6.1436 ] Packing sdram param for instance[14]
[ 6.1436 ] Packing sdram param for instance[15]
[ 6.1436 ]
[ 6.1436 ] Getting sector size from pt
[ 6.1458 ] tegraparser_v2 --getsectorsize flash.xml.bin sector_info.bin
[ 6.1466 ]
[ 6.1467 ] BlockSize read from layout is 200
[ 6.1490 ] tegrasign_v3.py --key /home/akter/.xkeys/SBK --file /home/akter/nvidia/4.6.1/Linux_for_Tegra_massfuse/bootloader/11869/tmp4x_6gf_l1_1.bct
[ 6.1498 ] Key is a SBK key
[ 6.1702 ] Key Size is 16 bytes
[ 6.1704 ] 48352
[ 6.1764 ]
[ 6.1789 ] tegrasign_v3.py --key /home/akter/.xkeys/SBK --file /home/akter/nvidia/4.6.1/Linux_for_Tegra_massfuse/bootloader/11869/tmp4x_6gf_l1_2.bct
[ 6.1798 ] Key is a SBK key
[ 6.2022 ] Key Size is 16 bytes
[ 6.2024 ] 48352
[ 6.2086 ]
[ 6.2111 ] tegrasign_v3.py --key /home/akter/.xkeys/SBK --file /home/akter/nvidia/4.6.1/Linux_for_Tegra_massfuse/bootloader/11869/tmp4x_6gf_l1_3.bct
[ 6.2121 ] Key is a SBK key
[ 6.2356 ] Key Size is 16 bytes
[ 6.2358 ] 48352
[ 6.2425 ]
[ 6.2452 ] tegrasign_v3.py --key /home/akter/.xkeys/SBK --file /home/akter/nvidia/4.6.1/Linux_for_Tegra_massfuse/bootloader/11869/tmp4x_6gf_l1_4.bct
[ 6.2461 ] Key is a SBK key
[ 6.2695 ] Key Size is 16 bytes
[ 6.2697 ] 48352
[ 6.2762 ]
[ 6.2788 ] tegrahost_v2 --chip 0x19 0 --blocksize 512 --magicid MEMB --addsigheader_multi /home/akter/nvidia/4.6.1/Linux_for_Tegra_massfuse/bootloader/11869/tmp4x_6gf_l1_1_encrypt.bct /home/akter/nvidia/4.6.1/Linux_for_Tegra_massfuse/bootloader/11869/tmp4x_6gf_l1_2_encrypt.bct /home/akter/nvidia/4.6.1/Linux_for_Tegra_massfuse/bootloader/11869/tmp4x_6gf_l1_3_encrypt.bct /home/akter/nvidia/4.6.1/Linux_for_Tegra_massfuse/bootloader/11869/tmp4x_6gf_l1_4_encrypt.bct
[ 6.2798 ] adding BCH for /home/akter/nvidia/4.6.1/Linux_for_Tegra_massfuse/bootloader/11869/tmp4x_6gf_l1_1_encrypt.bct
[ 6.2828 ]
[ 6.2852 ] tegrahost_v2 --chip 0x19 --align mem_coldboot.bct
[ 6.2862 ]
[ 6.2864 ] header_magic: 4e564441
[ 6.2891 ] tegrasign_v3.py --key /home/akter/.xkeys/rsa_priv.pem --list mem_coldboot.bct_list.xml --pubkeyhash pub_key.key
[ 6.2912 ] K[ 6.2916 ] ey size is 384 bytes
[ 6.3433 ] Saving pkc public key in pub_key.key
[ 6.3454 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mem_coldboot.bct.signed mem_coldboot.bct.sig oem-rsa --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 6.3466 ]
[ 6.3488 ] tegrahost_v2 --chip 0x19 --align mem_coldboot.bct
[ 6.3497 ]
[ 6.3518 ] tegrahost_v2 --chip 0x19 0 --magicid MEMB --ratchet_blob ratchet_blob.bin --appendsigheader mem_coldboot.bct oem-rsa
[ 6.3527 ] Header already present for mem_coldboot.bct
[ 6.3530 ]
[ 6.3557 ] tegrasign_v3.py --getmontgomeryvalues montgomery.bin --key /home/akter/.xkeys/rsa_priv.pem --list mem_coldboot_sigheader.bct_list.xml --pubkeyhash pub_key.key
[ 6.3574 ] K[ 6.3590 ] ey size is 384 bytes
[ 6.4069 ] Saving pkc public key in pub_key.key
[ 6.4069 ] Saving Montgomery values in montgomery.bin
[ 6.4090 ] tegrahost_v2 --chip 0x19 0 --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin --updatesigheader mem_coldboot_sigheader.bct.signed mem_coldboot_sigheader.bct.sig oem-rsa
[ 6.4102 ]
[ 6.4102 ] Generating recovery mem-bct
[ 6.4124 ] tegrabct_v2 --chip 0x19 0 --sdram /home/akter/nvidia/4.6.1/Linux_for_Tegra_massfuse/bootloader/11869/tmp4x_6gf_l1.cfg --membct /home/akter/nvidia/4.6.1/Linux_for_Tegra_massfuse/bootloader/11869/tmp4x_6gf_l1_1.bct /home/akter/nvidia/4.6.1/Linux_for_Tegra_massfuse/bootloader/11869/tmp4x_6gf_l1_2.bct /home/akter/nvidia/4.6.1/Linux_for_Tegra_massfuse/bootloader/11869/tmp4x_6gf_l1_3.bct /home/akter/nvidia/4.6.1/Linux_for_Tegra_massfuse/bootloader/11869/tmp4x_6gf_l1_4.bct
[ 6.4132 ] Packing sdram param for instance[0]
[ 6.4706 ] Packing sdram param for instance[1]
[ 6.4710 ] Packing sdram param for instance[2]
[ 6.4710 ] Packing sdram param for instance[3]
[ 6.4710 ] Packing sdram param for instance[4]
[ 6.4710 ] Packing sdram param for instance[5]
[ 6.4710 ] Packing sdram param for instance[6]
[ 6.4710 ] Packing sdram param for instance[7]
[ 6.4710 ] Packing sdram param for instance[8]
[ 6.4710 ] Packing sdram param for instance[9]
[ 6.4710 ] Packing sdram param for instance[10]
[ 6.4710 ] Packing sdram param for instance[11]
[ 6.4710 ] Packing sdram param for instance[12]
[ 6.4710 ] Packing sdram param for instance[13]
[ 6.4711 ] Packing sdram param for instance[14]
[ 6.4711 ] Packing sdram param for instance[15]
[ 6.4711 ]
[ 6.4735 ] tegrahost_v2 --chip 0x19 --align mem_rcm.bct
[ 6.4743 ]
[ 6.4744 ] header_magic: 3000000
[ 6.4768 ] tegrasign_v3.py --key /home/akter/.xkeys/SBK --list mem_rcm.bct_list.xml
[ 6.4769 ] Key is a SBK key
[ 6.4769 ] Key Size is 16 bytes
[ 6.4773 ] 48352
[ 6.4847 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mem_rcm.bct.encrypt mem_rcm.bct.hash zerosbk
[ 6.4857 ]
[ 6.4880 ] tegrahost_v2 --chip 0x19 --align mem_rcm.bct.encrypt
[ 6.4889 ]
[ 6.4890 ] header_magic: fd11a4e3
[ 6.4911 ] tegrahost_v2 --appendsigheader mem_rcm.bct.encrypt oem-rsa-sbk --chip 0x19 0 --magicid MEMB --ratchet_blob ratchet_blob.bin
[ 6.4919 ] adding BCH for mem_rcm.bct.encrypt
[ 6.4932 ]
[ 6.4959 ] tegrasign_v3.py --key /home/akter/.xkeys/rsa_priv.pem --list mem_rcm.bct_sigheader.encrypt_list.xml --pubkeyhash pub_key.key
[ 6.4978 ] K[ 6.4981 ] ey size is 384 bytes
[ 6.5446 ] Saving pkc public key in pub_key.key
[ 6.5467 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mem_rcm.bct_sigheader.encrypt.signed mem_rcm.bct_sigheader.encrypt.sig oem-rsa --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 6.5482 ]
[ 6.5490 ] nvtboot_recovery_t194.bin_sigheader.encrypt.signed
[ 6.5493 ] preboot_c10_prod_cr.bin
[ 6.5494 ] mce_c10_prod_cr.bin
[ 6.5496 ] mts_c10_prod_cr.bin
[ 6.5530 ] tegra194-p3668-all-p3509-0000.dtb
[ 6.5534 ] bpmp_t194.bin
[ 6.5543 ] tegra194-a02-bpmp-p3668-a00.dtb
[ 6.5549 ] tos-trusty_t194.img
[ 6.5555 ] eks.img
[ 6.5556 ] boot.img
[ 6.5557 ] tegra194-p3668-all-p3509-0000.dtb
[ 6.5601 ] spe_t194.bin
[ 6.5603 ] nvtboot_recovery_cpu_t194.bin_sigheader.encrypt.signed
[ 6.5630 ] tegrahost_v2 --chip 0x19 --align mb1_t194_prod_sigheader.bin.encrypt
[ 6.5640 ]
[ 6.5641 ] header_magic: 4e564441
[ 6.5667 ] tegrasign_v3.py --key /home/akter/.xkeys/rsa_priv.pem --list mb1_t194_prod_sigheader.bin.encrypt_list.xml --pubkeyhash pub_key.key
[ 6.5689 ] K[ 6.5692 ] ey size is 384 bytes
[ 6.6192 ] Saving pkc public key in pub_key.key
[ 6.6213 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_t194_prod_sigheader.bin.encrypt.signed mb1_t194_prod_sigheader.bin.encrypt.sig oem-rsa --pubkeyhash pub_key.key --setmontgomeryvalues montgomery.bin
[ 6.6252 ]
[ 6.6278 ] tegraparser_v2 --generategpt --pt flash.xml.bin
[ 6.6290 ]
[ 6.6357 ] tegraparser_v2 --pt flash.xml.bin --generateflashindex /home/akter/nvidia/4.6.1/Linux_for_Tegra_massfuse/bootloader/encrypted_signed_t19x/flash.xml.tmp flash.idx
[ 6.7686 ]
*** Calculating HASH from keyfile /home/akter/.xkeys/rsa_priv.pem ... done
PKC HASH: 0x13863ae9b79932d873d389ad13b2a11d2e48f8576d4369f1b8042d64b22d5fb3
*** Generating fuse configuration ... done.
*** Start preparing fuse configuration ...
*** done.
| Step 2: Sign Binaries
./tegraflash.py --securedev --bins "mb2_bootloader encrypted_signed_t19x/nvtboot_recovery_t194.bin_sigheader.encrypt.signed; mts_preboot encrypted_signed_t19x/preboot_c10_prod_cr_sigheader.bin.encrypt.signed; mts_mce encrypted_signed_t19x/mce_c10_prod_cr_sigheader.bin.encrypt.signed; mts_proper encrypted_signed_t19x/mts_c10_prod_cr_sigheader.bin.encrypt.signed; bootloader_dtb encrypted_signed_t19x/tegra194-p3668-all-p3509-0000_sigheader.dtb.encrypt.signed; bpmp_fw encrypted_signed_t19x/bpmp_t194_sigheader.bin.encrypt.signed; bpmp_fw_dtb encrypted_signed_t19x/tegra194-a02-bpmp-p3668-a00_sigheader.dtb.encrypt.signed; tlk encrypted_signed_t19x/tos-trusty_t194_sigheader.img.encrypt.signed; eks encrypted_signed_t19x/eks_sigheader.img.encrypt.signed; spe_fw encrypted_signed_t19x/spe_t194_sigheader.bin.encrypt.signed" --bl encrypted_signed_t19x/nvtboot_recovery_cpu_t194.bin_sigheader.encrypt.signed --bct encrypted_signed_t19x/br_bct_BR.bct --mb1_bct encrypted_signed_t19x/mb1_bct_MB1.bct_sigheader.encrypt.signed --mem_bct encrypted_signed_t19x/mem_rcm.bct_sigheader.encrypt.signed --mb1_cold_boot_bct encrypted_signed_t19x/mb1_cold_boot_bct_MB1.bct_sigheader.encrypt.signed --mem_bct_cold_boot encrypted_signed_t19x/mem_coldboot_sigheader.bct.signed --applet encrypted_signed_t19x/rcm_2_signed.rcm --applet_softfuse encrypted_signed_t19x/rcm_1_signed.rcm --odmdata 0xB8190000 --chip 0x19 --cmd "sign " --keep --skipuid
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[ 0.0032 ] Using default ramcode: 0
[ 0.0032 ] Disable BPMP dtb trim, using default dtb
[ 0.0032 ]
[ 0.0056 ] tegrasign_v3.py --getmode mode.txt --key None
[ 0.0057 ] Assuming zero filled SBK key
[ 0.0057 ] Generating RCM messages
[ 0.0077 ] tegrahost_v2 --chip 0x19 0 --magicid MB1B --appendsigheader /home/akter/nvidia/4.6.1/Linux_for_Tegra_massfuse/bootloader/encrypted_signed_t19x/rcm_2_signed.rcm zerosbk
[ 0.0084 ] adding BCH for /home/akter/nvidia/4.6.1/Linux_for_Tegra_massfuse/bootloader/encrypted_signed_t19x/rcm_2_signed.rcm
[ 0.0137 ]
[ 0.0159 ] tegrasign_v3.py --getmode mode.txt --key None
[ 0.0159 ] Assuming zero filled SBK key
[ 0.0181 ] tegrasign_v3.py --file /home/akter/nvidia/4.6.1/Linux_for_Tegra_massfuse/bootloader/encrypted_signed_t19x/rcm_2_signed_sigheader.rcm --key None --length 1136 --offset 2960 --pubkeyhash pub_key.key
[ 0.0181 ] Assuming zero filled SBK key
[ 0.0223 ] tegrahost_v2 --chip 0x19 0 --updatesigheader /home/akter/nvidia/4.6.1/Linux_for_Tegra_massfuse/bootloader/encrypted_signed_t19x/rcm_2_signed_sigheader.rcm /home/akter/nvidia/4.6.1/Linux_for_Tegra_massfuse/bootloader/encrypted_signed_t19x/rcm_2_signed_sigheader.hash zerosbk
[ 0.0260 ]
[ 0.0279 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x19 0 --download rcm /home/akter/nvidia/4.6.1/Linux_for_Tegra_massfuse/bootloader/encrypted_signed_t19x/rcm_2_signed_sigheader.rcm 0 0
[ 0.0285 ] RCM 0 is saved as rcm_0.rcm
[ 0.0314 ] RCM 1 is saved as rcm_1.rcm
[ 0.0315 ] List of rcm files are saved in rcm_list.xml
[ 0.0315 ]
[ 0.0315 ] Signing RCM messages
[ 0.0336 ] tegrasign_v3.py --getmontgomeryvalues montgomery.bin --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.0337 ] Assuming zero filled SBK key
[ 0.0381 ] Copying signature to RCM mesages
[ 0.0400 ] tegrarcm_v2 --chip 0x19 0 --updatesig rcm_list_signed.xml
[ 0.0411 ]
[ 0.0432 ] tegrahost_v2 --chip 0x19 --align encrypted_signed_t19x/nvtboot_recovery_t194.bin_sigheader.encrypt.signed
[ 0.0439 ] Stat for encrypted_signed_t19x/nvtboot_recovery_t194.bin_sigheader.encrypt.signed failed
[ 0.0439 ]
Error: Return value 4
Command tegrahost_v2 --chip 0x19 --align encrypted_signed_t19x/nvtboot_recovery_t194.bin_sigheader.encrypt.signed
Keep temporary directory /home/akter/nvidia/4.6.1/Linux_for_Tegra_massfuse/bootloader/13200
Error: Signing binaries failed.
