Materials from 3dsMax
Hi!
I’ve tried making a few objects with different physical(left) and VRAY(right) materials applied to them in 3ds Max. I then exported the scene to USD. When I open the USD the materials are not correct. Is there a way to make them export compatible?
Couple of questions to help us figure it out.
1.What version of the Omniverse 3dsMax plug in are you using?
2. What version of 3dsMax are you using?
3. Did you have include MDL checked on in the 3dsMax export dialog?
4. Which renderer are you using in Create?
5. If you turn on echo feedback in the Omniverse settings panel in 3dsmax, is there any errors after your export?
6. In Create, when you open the file, is there an errors listed in the console?
It is possible that you used a vray parameter we do not support yet. You can see our current support here. 3ds Max — Omniverse Connect documentation
For physical materials, we do a parameter mapping, but we do not translate the material graph. The ones you have here look pretty simple and I would expect them to work however.
If the above all doesn’t help you, can you send me this sample file to test?
Thank you,
Aron
Hi azoellner!
  1. 102.2.2
  2. 2021.3.2
  3. Yes, I have since been able to export using the CSV mapping file. With the CSV the VRAY materials worked in Create but in 3ds Max they look the same as the second image in my first post. Here’s the look in Create with CSV method:
  4. The RTX Real-Time
  5. Yes, apparently i get errors I will attach the file so you can get an idea of what they are.
  6. I also get warnings in the Create console. They are:
 2021-11-15 10:36:19  [Warning] [carb.renderer.plugin] Not starting stream server for live stream, due to conflicts with cloudXR
2021-11-15 12:11:09  [Warning] [omni.hydra.scene_delegate.plugin] Calling setBypassRenderSkelMeshProcessing for prim /World/Sphere002 that is not usdskel mesh type
3dsMaxScene.max (1.2 MB)
Hopefully this helps!
As quick check, are you finding this is an issue for you still?
If so, could you provide a log from your machine when this happens?
Yes, I recreated the scene and got the same issue.
This is my 3ds Max log:
Welcome to MAXScript.
State Sets Error: Anchor couldn't be created!
NVIDIA Omniverse is loaded.
"NVIDIA Omniverse is loaded."
-- MAXScript Scripted Plugin Handler Exception:
-- Syntax error: at ,, expected name
--  In line: depth type:#float default:0,0
Omniverse Error: fail to download /Projects/AxelsLab/MaterialTest/3dsMaxtoCreate/CSVMethod/MaterialMappingFile.csv, size is 0
Omniverse: Failure to open MDL Table
Omniverse Server: 000001F31E687D10 Upgraded to WebSocket
Omniverse Server: >> {"id":1,"status":"OK","token":"2DLR4TZSYRXVLUE1","username":"asanne","connection_id":"XETGGYNT2LDSVO2V","connection_id_signature":"abb71551768f2b3ae0060d8f8ac5b92521790165b4b18f12cd5f42ef55e1d2ed","max_chunk_size":134217728,"lft_address":"http://10.0.1.170:3030","lft_threshold":262144,"super_user":false,"version":"111.2+master.gitlab.2967503.31857538","server_capabilities":{"ping":0,"auth":2,"create_group":0,"authorize_token":1,"subscribe_server_notifications":0,"lock":2,"remove_group":0,"get_groups":0,"delete":0,"read_asset_resolved":0,"get_users":0,"subscribe_read_asset":0,"list2":3,"read_asset_version":0,"read_object_version":0,"read_object_resolved":0,"rename_group":0,"list":4,"read":0,"create_asset":0,"checkpoint_version":1,"get_mount_info":0,"replace_version":0,"set_path_options":1,"copy2":0,"subscribe_read_object":1,"unlock":1,"create":2,"get_branches":0,"stat2":1,"get_transaction_id":0,"update_asset_with_hash":0,"delete2":0,"set_path_options2":0,"update_asset":0,"create_object":0,"copy":1,"set_acl_v2":0,"get_acl_v2":0,"create_asset_with_hash":0,"get_checkpoints":0,"change_acl":0,"get_acl":0,"mount":0,"update":1,"update_object":0,"create_directory":0,"remove_user_from_group":0,"add_user_to_group":0,"get_user_groups":0,"subscribe_list":0,"rename":0,"get_group_users":0,"unmount":0}}
Omniverse Server: << {"command":"ping","id":2,"ts":{"omni_client_out_ts":13271783241745440}}
Omniverse Server: >> {"status":"OK","ts":{"omni_client_out_ts":13271783241745440,"omni_server_in_ts":1638954116676137,"omni_c2s_lat":18435111244584482313,"omni_server_out_ts":1638954116676229},"username":"asanne","token":"2DLR4TZSYRXVLUE1","connection_id":"XETGGYNT2LDSVO2V","max_chunk_size":134217728,"version":"111.2+master.gitlab.2967503.31857538","id":2}
Omniverse Server: Request 6: stat(omniverse://10.0.1.170/Projects/AxelsLab/MaterialTest/3dsMaxtoCreate/CSVMethod/MaterialMappingFile.csv)
Omniverse Server: ListCache miss! omniverse://10.0.1.170/Projects/AxelsLab/MaterialTest/3dsMaxtoCreate/CSVMethod/
Omniverse Server: << {"command":"subscribe_list","id":5,"path":{"branch":"","path":"/Projects/AxelsLab/MaterialTest/3dsMaxtoCreate/CSVMethod/"}}
Omniverse Server: << {"command":"list2","id":6,"path":"/Projects/AxelsLab/MaterialTest/3dsMaxtoCreate/CSVMethod/"}
Omniverse Server: >> {"status":"LATEST","id":5}
Omniverse Server: >> {"status":"OK","ts":{"omni_server_out_ts":1638954116753891},"entries":[{"path":"/Projects/AxelsLab/MaterialTest/3dsMaxtoCreate/CSVMethod/CSVMethod.usd","branch":"default","etag":"95328","acl":["admin","write","read"],"created_timestamp":1636712609,"modified_timestamp":1636712609,"path_type":"asset","size":59163,"empty":true,"mounted":false,"created_by":"asanne","modified_by":"asanne","hash_type":"sha-256-flat","hash_value":"3000a0ceed2116ce53f92a7fb90c7da50b57f56e4e94880467d71dd2199b6559","hash_bsize":1048576,"checkpointed":true,"transaction_id":113471},{"path":"/Projects/AxelsLab/MaterialTest/3dsMaxtoCreate/CSVMethod/MaterialMappingFile.csv","branch":"default","etag":"95319","acl":["admin","write","read"],"created_timestamp":1636720658,"modified_timestamp":1636720658,"path_type":"asset","size":0,"empty":false,"mounted":false,"created_by":"asanne","modified_by":"asanne","hash_type":"sha-256-flat","hash_value":"e3b0c44298fc1c149afbf4c8996fb92427ae41e4649b934ca495991b7852b855","hash_bsize":1048576,"transaction_id":113473},{"path":"/Projects/AxelsLab/MaterialTest/3dsMaxtoCreate/CSVMethod/Material__25.mdl","branch":"default","etag":"95320","acl":["admin","write","read"],"created_timestamp":1636712607,"modified_timestamp":1636712607,"path_type":"asset","size":2492,"empty":true,"mounted":false,"created_by":"asanne","modified_by":"asanne","hash_type":"sha-256-flat","hash_value":"60095101eceddf3502e2088106819f147b7b6dbcfe060265cf11ef0352433311","hash_bsize":1048576,"transaction_id":113462},{"path":"/Projects/AxelsLab/MaterialTest/3dsMaxtoCreate/CSVMethod/Material__26.mdl","branch":"default","etag":"95321","acl":["admin","write","read"],"created_timestamp":1636712607,"modified_timestamp":1636712607,"path_type":"asset","size":2183,"empty":true,"mounted":false,"created_by":"asanne","modified_by":"asanne","hash_type":"sha-256-flat","hash_value":"8e947698dd2c7a9a26069f5bc199ec6f865d07fac957cd55cacdebf5a826c714","hash_bsize":1048576,"transaction_id":113463},{"path":"/Projects/AxelsLab/MaterialTest/3dsMaxtoCreate/CSVMethod/Material__27.mdl","branch":"default","etag":"95322","acl":["admin","write","read"],"created_timestamp":1636712607,"modified_timestamp":1636712607,"path_type":"asset","size":2181,"empty":true,"mounted":false,"created_by":"asanne","modified_by":"asanne","hash_type":"sha-256-flat","hash_value":"3b8a662b55af47bbd4b21aa8206709b922c4a05710556f6fcfa6c289483e74aa","hash_bsize":1048576,"transaction_id":113464},{"path":"/Projects/AxelsLab/MaterialTest/3dsMaxtoCreate/CSVMethod/Material__28.mdl","branch":"default","etag":"95323","acl":["admin","write","read"],"created_timestamp":1636712607,"modified_timestamp":1636712607,"path_type":"asset","size":2185,"empty":true,"mounted":false,"created_by":"asanne","modified_by":"asanne","hash_type":"sha-256-flat","hash_value":"661e1256eda2f273e570b9aec9ef6e683a102c84a0e2895a717aa2b7ee009886","hash_bsize":1048576,"transaction_id":113465},{"path":"/Projects/AxelsLab/MaterialTest/3dsMaxtoCreate/CSVMethod/templates/","branch":"default","acl":["admin","write","read"],"created_timestamp":1636712609,"modified_timestamp":1636712609,"path_type":"folder","empty":false,"mounted":false,"created_by":"asanne","modified_by":"asanne"}],"id":6}
Omniverse Server: >> {"status":"DONE","ts":{"omni_server_out_ts":1638954116753998},"id":6}
Omniverse Server: Request 6: stat(omniverse://10.0.1.170/Projects/AxelsLab/MaterialTest/3dsMaxtoCreate/CSVMethod/MaterialMappingFile.csv) returned Ok
Omniverse Server: Request 6:             0B live MaterialMappingFile.csv
Omniverse Server: << {"command":"ping","id":3,"ts":{"omni_client_out_ts":13271783243249368}}
Omniverse Server: >> {"status":"OK","ts":{"omni_client_out_ts":13271783243249368,"omni_server_in_ts":1638954118180327,"omni_c2s_lat":18435111244584482575,"omni_server_out_ts":1638954118180446},"username":"asanne","token":"2DLR4TZSYRXVLUE1","connection_id":"XETGGYNT2LDSVO2V","max_chunk_size":134217728,"version":"111.2+master.gitlab.2967503.31857538","id":3}
Omniverse Server: << {"command":"ping","id":4,"ts":{"omni_client_out_ts":13271783244732847}}
Omniverse Server: >> {"status":"OK","ts":{"omni_client_out_ts":13271783244732847,"omni_server_in_ts":1638954119663956,"omni_c2s_lat":18435111244584482725,"omni_server_out_ts":1638954119664083},"username":"asanne","token":"2DLR4TZSYRXVLUE1","connection_id":"XETGGYNT2LDSVO2V","max_chunk_size":134217728,"version":"111.2+master.gitlab.2967503.31857538","id":4}
Omniverse Server: << {"command":"ping","id":5,"ts":{"omni_client_out_ts":13271783246258054}}
Omniverse Server: >> {"status":"OK","ts":{"omni_client_out_ts":13271783246258054,"omni_server_in_ts":1638954121188937,"omni_c2s_lat":18435111244584482499,"omni_server_out_ts":1638954121189042},"username":"asanne","token":"2DLR4TZSYRXVLUE1","connection_id":"XETGGYNT2LDSVO2V","max_chunk_size":134217728,"version":"111.2+master.gitlab.2967503.31857538","id":5}
Omniverse Server: << {"command":"ping","id":6,"ts":{"omni_client_out_ts":13271783247736799}}
Omniverse Server: >> {"status":"OK","ts":{"omni_client_out_ts":13271783247736799,"omni_server_in_ts":1638954122673138,"omni_c2s_lat":18435111244584487955,"omni_server_out_ts":1638954122673251},"username":"asanne","token":"2DLR4TZSYRXVLUE1","connection_id":"XETGGYNT2LDSVO2V","max_chunk_size":134217728,"version":"111.2+master.gitlab.2967503.31857538","id":6}
Omniverse Server: << {"command":"ping","id":7,"ts":{"omni_client_out_ts":13271783249623934}}
Omniverse Server: >> {"status":"OK","ts":{"omni_client_out_ts":13271783249623934,"omni_server_in_ts":1638954124554872,"omni_c2s_lat":18435111244584482554,"omni_server_out_ts":1638954124555013},"username":"asanne","token":"2DLR4TZSYRXVLUE1","connection_id":"XETGGYNT2LDSVO2V","max_chunk_size":134217728,"version":"111.2+master.gitlab.2967503.31857538","id":7}
Omniverse Server: << {"command":"ping","id":8,"ts":{"omni_client_out_ts":13271783252264029}}
Omniverse Server: >> {"status":"OK","ts":{"omni_client_out_ts":13271783252264029,"omni_server_in_ts":1638954127194691,"omni_c2s_lat":18435111244584482278,"omni_server_out_ts":1638954127194771},"username":"asanne","token":"2DLR4TZSYRXVLUE1","connection_id":"XETGGYNT2LDSVO2V","max_chunk_size":134217728,"version":"111.2+master.gitlab.2967503.31857538","id":8}
Omniverse Server: Request 9: list(omniverse://10.0.1.170/)
Omniverse Server: << {"command":"subscribe_list","id":7,"path":{"branch":"","path":"/"}}
Omniverse Server: << {"command":"list2","id":8,"path":"/"}
Omniverse Server: >> {"status":"LATEST","id":7}
Omniverse Server: >> {"status":"OK","ts":{"omni_server_out_ts":1638954127733274},"entries":[{"path":"/Library/","branch":"default","acl":["write","read"],"created_timestamp":1632751632,"modified_timestamp":1632751632,"path_type":"folder","empty":false,"mounted":false,"created_by":"omniverse","modified_by":"omniverse"},{"path":"/NVIDIA/","branch":"default","acl":["read"],"created_timestamp":1632751632,"modified_timestamp":1632751632,"path_type":"mount","mounted":false,"created_by":"omniverse","modified_by":"omniverse"},{"path":"/Projects/","branch":"default","acl":["write","read"],"created_timestamp":1632751632,"modified_timestamp":1632751632,"path_type":"folder","empty":false,"mounted":false,"created_by":"omniverse","modified_by":"omniverse"},{"path":"/Users/","branch":"default","acl":["read"],"created_timestamp":1632751632,"modified_timestamp":1632751632,"path_type":"folder","empty":false,"mounted":false,"created_by":"omniverse","modified_by":"omniverse"}],"id":8}
Omniverse Server: >> {"status":"DONE","ts":{"omni_server_out_ts":1638954127733345},"id":8}
Omniverse Server: Request 9: list(omniverse://10.0.1.170/) returned Ok with 4 entries
Omniverse Server: Request 9:              folder Library
Omniverse Server: Request 9:  folder mount-point NVIDIA
Omniverse Server: Request 9:              folder Projects
Omniverse Server: Request 9:              folder Users
Omniverse Server: << {"command":"ping","id":9,"ts":{"omni_client_out_ts":13271783255266549}}
Omniverse Server: >> {"status":"OK","ts":{"omni_client_out_ts":13271783255266549,"omni_server_in_ts":1638954130197556,"omni_c2s_lat":18435111244584482623,"omni_server_out_ts":1638954130197673},"username":"asanne","token":"2DLR4TZSYRXVLUE1","connection_id":"XETGGYNT2LDSVO2V","max_chunk_size":134217728,"version":"111.2+master.gitlab.2967503.31857538","id":9}
Omniverse Server: << {"command":"ping","id":10,"ts":{"omni_client_out_ts":13271783258271593}}
Omniverse Server: >> {"status":"OK","ts":{"omni_client_out_ts":13271783258271593,"omni_server_in_ts":1638954133202827,"omni_c2s_lat":18435111244584482850,"omni_server_out_ts":1638954133202918},"username":"asanne","token":"2DLR4TZSYRXVLUE1","connection_id":"XETGGYNT2LDSVO2V","max_chunk_size":134217728,"version":"111.2+master.gitlab.2967503.31857538","id":10}
Omniverse Server: << {"command":"ping","id":11,"ts":{"omni_client_out_ts":13271783261275429}}
Omniverse Server: >> {"status":"OK","ts":{"omni_client_out_ts":13271783261275429,"omni_server_in_ts":1638954136206980,"omni_c2s_lat":18435111244584483167,"omni_server_out_ts":1638954136207101},"username":"asanne","token":"2DLR4TZSYRXVLUE1","connection_id":"XETGGYNT2LDSVO2V","max_chunk_size":134217728,"version":"111.2+master.gitlab.2967503.31857538","id":11}
Omniverse Server: << {"command":"ping","id":12,"ts":{"omni_client_out_ts":13271783265765320}}
Omniverse Server: >> {"status":"OK","ts":{"omni_client_out_ts":13271783265765320,"omni_server_in_ts":1638954140696253,"omni_c2s_lat":18435111244584482549,"omni_server_out_ts":1638954140696343},"username":"asanne","token":"2DLR4TZSYRXVLUE1","connection_id":"XETGGYNT2LDSVO2V","max_chunk_size":134217728,"version":"111.2+master.gitlab.2967503.31857538","id":12}
Omniverse Server: << {"command":"ping","id":13,"ts":{"omni_client_out_ts":13271783269634231}}
Omniverse Server: >> {"status":"OK","ts":{"omni_client_out_ts":13271783269634231,"omni_server_in_ts":1638954144565070,"omni_c2s_lat":18435111244584482455,"omni_server_out_ts":1638954144565221},"username":"asanne","token":"2DLR4TZSYRXVLUE1","connection_id":"XETGGYNT2LDSVO2V","max_chunk_size":134217728,"version":"111.2+master.gitlab.2967503.31857538","id":13}
Omniverse Server: << {"command":"ping","id":14,"ts":{"omni_client_out_ts":13271783274795226}}
Omniverse Server: >> {"status":"OK","ts":{"omni_client_out_ts":13271783274795226,"omni_server_in_ts":1638954149727830,"omni_c2s_lat":18435111244584484220,"omni_server_out_ts":1638954149727919},"username":"asanne","token":"2DLR4TZSYRXVLUE1","connection_id":"XETGGYNT2LDSVO2V","max_chunk_size":134217728,"version":"111.2+master.gitlab.2967503.31857538","id":14}
Omniverse Server: << {"command":"ping","id":15,"ts":{"omni_client_out_ts":13271783279296285}}
Omniverse Server: >> {"status":"OK","ts":{"omni_client_out_ts":13271783279296285,"omni_server_in_ts":1638954154227537,"omni_c2s_lat":18435111244584482868,"omni_server_out_ts":1638954154227634},"username":"asanne","token":"2DLR4TZSYRXVLUE1","connection_id":"XETGGYNT2LDSVO2V","max_chunk_size":134217728,"version":"111.2+master.gitlab.2967503.31857538","id":15}
Omniverse Warning: node 'VRayCam001.Target' has invalid name! Invalid symbols will be replaced with underscore.
Omniverse Warning: node 'PhysCamera001.Target' has invalid name! Invalid symbols will be replaced with underscore.
Omniverse Warning: node 'VRayCam001.Target' is renamed as 'VRayCam001_Target_1'.
Omniverse Warning: node 'PhysCamera001.Target' is renamed as 'PhysCamera001_Target_1'.
Omniverse Server: << {"command":"ping","id":16,"ts":{"omni_client_out_ts":13271783285302741}}
Omniverse Server: >> {"status":"OK","ts":{"omni_client_out_ts":13271783285302741,"omni_server_in_ts":1638954160234195,"omni_c2s_lat":18435111244584483070,"omni_server_out_ts":1638954160234338},"username":"asanne","token":"2DLR4TZSYRXVLUE1","connection_id":"XETGGYNT2LDSVO2V","max_chunk_size":134217728,"version":"111.2+master.gitlab.2967503.31857538","id":16}
Omniverse Server: GetFileAttributesExW(//?/C:/Users/Axel Sanne/Desktop/TEST.usd) returned "The system cannot find the file specified."
Universal Material Map: convert_instance_to_data(Material__25:Physical_Material, "MDL") generated data:
		('umm_target_class', 'OmniPBR.mdl|OmniPBR')
		('diffuse_color_constant', (0, 0, 0))
		('diffuse_texture', ['', 'auto'])
		('reflection_roughness_constant', 0.0)
		('reflection_roughness_texture_influence', 0.0)
		('reflectionroughness_texture', ['', 'auto'])
		('metallic_constant', 0.0)
		('metallic_texture_influence', 0.0)
		('metallic_texture', ['', 'auto'])
		('enable_emission', False)
		('emissive_color', (1, 1, 1))
		('emissive_color_texture', ['', 'auto'])
		('emissive_mask_texture', '')
		('emissive_intensity', 0.0)
		('bump_factor', 0.10000000149011612)
		('normalmap_texture', ['', 'auto'])
		('enable_opacity_texture', True)
		('opacity_constant', 1.0)
		('opacity_texture', ['', 'auto'])
Universal Material Map: convert_instance_to_data(Material__26:Physical_Material, "MDL") generated data:
		('diffuse_color_constant', (0.733813, 0.485445, 0))
		('reflection_roughness_constant', 0.25595328211784363)
		('bump_factor', 0.30000001192092896)
		('opacity_constant', 0.0)
Universal Material Map: convert_instance_to_data(Material__28:Physical_Material, "MDL") generated data:
		('diffuse_color_constant', (0.933, 0.774, 0.374))
		('reflection_roughness_constant', 0.07999999821186066)
		('metallic_constant', 1.0)
Universal Material Map: convert_instance_to_data(Material__27:Physical_Material, "MDL") generated data:
		('diffuse_color_constant', (1, 0.5, 0.5))
		('enable_emission', True)
		('emissive_color', (0, 0, 0))
		('emissive_intensity', 1.0)
Warning: FBX does not support parameter 'ForceNormalsByControlPoint'
Time cost: 5,756095
Omniverse: C:\Users\Axel Sanne\Desktop\TEST.usd is created.
Omniverse Server: << {"command":"ping","id":17,"ts":{"omni_client_out_ts":13271783290548499}}
Omniverse Server: >> {"status":"OK","ts":{"omni_client_out_ts":13271783290548499,"omni_server_in_ts":1638954165480030,"omni_c2s_lat":18435111244584483147,"omni_server_out_ts":1638954165480200},"username":"asanne","token":"2DLR4TZSYRXVLUE1","connection_id":"XETGGYNT2LDSVO2V","max_chunk_size":134217728,"version":"111.2+master.gitlab.2967503.31857538","id":17}
Omniverse Server: << {"command":"ping","id":18,"ts":{"omni_client_out_ts":13271783297530804}}
Omniverse Server: >> {"status":"OK","ts":{"omni_client_out_ts":13271783297530804,"omni_server_in_ts":1638954172462268,"omni_c2s_lat":18435111244584483080,"omni_server_out_ts":1638954172462377},"username":"asanne","token":"2DLR4TZSYRXVLUE1","connection_id":"XETGGYNT2LDSVO2V","max_chunk_size":134217728,"version":"111.2+master.gitlab.2967503.31857538","id":18}
Omniverse Server: << {"command":"ping","id":19,"ts":{"omni_client_out_ts":13271783303537598}}
Appreciate the response, i’ll get this forwarded to the dev team, and we’ll see if we can figure out whats happening. Thanks!
axel.sanne. I tried your sample with a newer set of tools, your tooling versions look a bit old and we’ve made some improvements.
Could you have a try with a newer Max connector(102.3.0) and Create 2021.3.7?
These were my results using newer versions of the tools. All I did was tone down the lights in Create after export. We are working to improve the physical material output when it has transparency.
