I’m using the Partnet data set, where each part of the object has to be loaded in separately, and I’ve been trying to randomise the colours/materials per sub object.
For instance, I might want all the parts of a drawer to be the same colour. To do this, I’ve basically needed to create callbacks of varying name and so I’ve had to use monkey patching. (If there’s a better way, please do say. This is a recipie for many bugs!).
The core of the code I’ve got is basically
def randomiseColoursMaterialsByCategory(self, materials):
num_colour_series = len(MAPPING_LABELS) + 1;
colour_rand_series = [];
for i in range(num_colour_series):
appending = [];
for j in range(self.num_iterations):
appending.append((random.uniform(0,255), random.uniform(0,255), random.uniform(0,255)));
colour_rand_series.append(appending);
keys = list(MAPPING_LABELS.keys());
keys.append(NOT_IN_MAPPING_LABEL);
for i in range(len(keys)):
func_name = "randomise_item_set_colours_{0}_{1}".format(str(self.uid), str(i));
# self.internal_func_store.append(randomise_sub_obj_colour);
print(keys[i]);
print(type(keys[i]));
evaluating = (
"def {0}():" +
"\n\tfurniture_items = rep.get.prims(semantics=[( FURNITURE_PART, LABEL )]);" +
"\n\twith furniture_items:" +
"\n\t\trep.randomizer.materials(materials); "
"\n\t\trep.randomizer.color(rep.distribution.sequence(colour_rand_series[i])); " +
"\n\treturn furniture_items.node;" +
# "\nprint(\"Func name:\", func_name);" +
"\nrep.randomizer.register({0});" +
"\nself.callbacks.append( lambda : rep.randomizer.{0}() );" +
"\nself.internal_func_store.append({0});").format(func_name);
# print(evaluating);
exec(
evaluating,
{"rep":rep, "self":self, "materials":materials,
"FURNITURE_PART":FURNITURE_PART, "LABEL": MAPPING_LABELS[keys[i]] + "_" + str(self.uid),
"colour_rand_series":colour_rand_series, "i":i});
When running this, all the arguments go in correctly, but I then get the error
2022-11-23 10:33:15 [554,635ms] [Error] [omni.graph.core.plugin] Assertion raised in compute - list index out of range
File "/home/matthewmunks/.local/share/ov/pkg/deps/775e081cef5fe932262e6117bb022b51/extscache/omni.replicator.core-1.4.4+lx64.r.cp37/omni/replicator/core/ogn/python/_impl/nodes/OgnSampleOmniPBR.py", line 152, in compute
mat_params.diffuse = tuple(diffuse_samples[idx])
This happens even if I randomise the materials in a separate callback function.
However it does not happen when not using the monkey-patch solution and I just randomise all the colours and materials.
EDIT:
A closed form example would be
import random;
num_iterations = 5;
with rep.new_layer():
materials = rep.create.material_omnipbr(diffuse=rep.distribution.uniform((0,0,0), (1,1,1)), count=30);
camera = rep.create.camera(
position=(50,50,50),
look_at=(0,0,0),
look_at_up_axis=(0,1,0));
render_product = rep.create.render_product(camera, (640,480));
def create_sphere_lights(num):
lights = rep.create.light(light_type="Sphere", temperature=rep.distribution.normal(6500,500), intensity=rep.distribution.normal(5000,1000), position=rep.distribution.uniform((0,0,0),(50,50,50)), scale=rep.distribution.uniform(50,100), count=num);
return lights.node;
rep.randomizer.register(create_sphere_lights);
# Overall setup. Lots of objects of multiple different clases being created.
cones = rep.create.cone(count=100, position=rep.distribution.uniform((-100,-100,-100),(100,100,100)), scale=rep.distribution.uniform(1,5), semantics=[("class","cone")]);
cubes = rep.create.cone(count=100, position=rep.distribution.uniform((-100,-100,-100),(100,100,100)),scale=rep.distribution.uniform(1,5),semantics=[("class","cube")]);
CLASSES_OF_INTEREST = ["cone", "cube"];
callbacks = [];
num_colour_series = len(CLASSES_OF_INTEREST);
appending = [];
for j in range(num_iterations):
for i in range(len(CLASSES_OF_INTEREST)):
func_name = "randomise_item_set_colours_{0}".format(str(i));
evaluating = (
"def {0}():" +
"\n\tfurniture_items = rep.get.prims(semantics=[( \"class\", LABEL )]);" +
"\ncallbacks.append( lambda : rep.randomizer.{0}() );").format(func_name);
exec(
evaluating,
{"rep":rep, "materials":materials,
"LABEL": CLASSES_OF_INTEREST[i],
"colour_rand_series":colour_rand_series, "i":i,
"callbacks":callbacks});
with rep.trigger.on_frame(num_frames=num_iterations):
rep.randomizer.create_sphere_lights(1);
for callback in callbacks:
callback();
# rep.randomizer.move_camera();
writer = rep.WriterRegistry.get('BasicWriter');
writer.initialize(output_dir="~/_output", rgb=True, bounding_box_2d_tight=True);
writer.attach([render_product]);
rep.orchestrator.run();
