Matlab 2016a crash with nvidia 364.15 but matlab 2015b worked
Matlab crash at start output is below.
   Segmentation violation detected at Sat Apr  9 15:11:39 2016
Configuration:
Crash Decoding : Disabled
Crash Mode : continue (default)
Current Graphics Driver: Unknown hardware
Current Visual : 0x21 (class 4, depth 24)
Default Encoding : UTF-8
GNU C Library : 2.22 stable
Host Name : uefi_super_knut
MATLAB Architecture : glnxa64
MATLAB Root : /usr/local/MATLAB/R2016a
MATLAB Version : 9.0.0.341360 (R2016a)
OpenGL : hardware
Operating System : Linux 4.4.6-301.fc23.x86_64 #1 SMP Wed Mar 30 16:43:58 UTC 2016 x86_64
Processor ID : x86 Family 6 Model 63 Stepping 2, GenuineIntel
Virtual Machine : Java 1.7.0_60-b19 with Oracle Corporation Java HotSpotâ„¢ 64-Bit Server VM mixed mode
Window System : Fedora Project (11803000), display :1
Fault Count: 1
Abnormal termination:
Register State (from fault):
RAX = 00007fedd8f37d10 RBX = 0000000000000000
RCX = 0000000000000001 RDX = 00000000000000a8
RSP = 00007fedd8f37ce0 RBP = 00007fed7803de60
RSI = 00007fedd8f37db8 RDI = 00007fedd8f37d10
R8 = 0000000000000000 R9 = 0000000000000001
R10 = 00007fed784aaf00 R11 = 00007feee8108c60
R12 = 00007fed784ab550 R13 = 00007fed7803de60
R14 = 00007fed7836aec0 R15 = 00007fed78305cc0
RIP = 00007feee8ed55bd EFL = 0000000000010206
CS = 0033 FS = 0000 GS = 0000
Stack Trace (from fault):
[ 0] 0x00007feee8ed55bd /usr/lib64/nvidia/libGL.so.1+00345533
If this problem is reproducible, please submit a Service Request via:
http://www.mathworks.com/support/contact_us/
A technical support engineer might contact you with further information.
Thank you for your help.** This crash report has been saved to disk as /home/knutjbj/matlab_crash_dump.164622-1 **
MATLAB is exiting because of fatal error
Killed
nvidia-bug-report.log.gz (93.1 KB)
It is a duplicate of https://devtalk.nvidia.com/default/topic/926199/linux/361-28-crashes-matlab-r2016a/
