I want to know if there is a separate one for Linux because I read in the documentation that is different in the older versions. The files in that link are for nvmexopts.BAT, so I guess I need a different .sh file for linux.
If so where can I get a R2008a CUDA plugin for Linux.
Also, I would like someone to breifly explain how to use the plugin.
Do I need to run any script or install anything before running the >>nvmex -f nvexopts.bat … ?
Also which guide should I follow? The README.txt in the plugin library or the documentation (Accelerating Matlab with CUDA using Mex files)?
Hmm, I think I am using the standard matlab plugin from the CUDA website. I don’t think I needed to change anything and am now also using it in 2008b (did not try 2009a preview yet)
personally, I am using the makefile to compile my CUDA code.
