Matrix by vector multiplication
Hello, i newbie in CUDA. My multiplication is not correct. I can’t find cause (spent several hours)
__global__ void multMatrixByVector(float *Matrix, float *Vector, float *resultedVector, int n)
	int x = threadIdx.x + blockDim.x * blockIdx.x;
	float sum = 0.0f;
	for(int i = 0; i < n; i++)
		sum += Matrix[x * n + i] * Vector [i];
	resultedVector[x]= sum;
and kernel:
dim3 grid(n/BLOCK_SIZE,1,1);
	dim3 blocks(BLOCK_SIZE,1,1);
	multMatrixByVector<<<grid, blocks>>>(dA, dB, dY, n);
Example:
Matrix:
0 0 0 0 0 0 0 0
1 1 1 1 1 1 1 1
2 2 2 2 2 2 2 2
3 3 3 3 3 3 3 3
4 4 4 4 4 4 4 4
5 5 5 5 5 5 5 5
6 6 6 6 6 6 6 6
7 7 7 7 7 7 7 7
Vector:
3 3 3 3 3 3 3 3
Result:
12 60 108 156 84 0 0 0 <- wrong :(
Always check returned error codes. Apparently you are launching the kernel with 0 blocks, so it does nothing.
Thanks, I’ll remember that. :) But the launch of the kernel does not return cudaError_t
I checked. It’s ok :)
And program works correct if number of blocks - 1, but if more - rubbish in result
my bad :(((
filling matrix:
		for(int j = 0; j < n; j++)
			hA[i * BLOCK_SIZE + j] = i;
			cout << hA[i * BLOCK_SIZE + j] << " ";
		cout << endl;
BLOCK_SIZE need replace by n
not carefully written ((
