Here’s a fully worked example showing inversion of four 3x3 matrices:
$ cat t540.cu
#include <stdio.h>
#include <stdlib.h>
#include <cublas_v2.h>
#define cudacall(call) \
do \
cudaError_t err = (call); \
if(cudaSuccess != err) \
fprintf(stderr,"CUDA Error:\nFile = %s\nLine = %d\nReason = %s\n", __FILE__, __LINE__, cudaGetErrorString(err)); \
cudaDeviceReset(); \
exit(EXIT_FAILURE); \
while (0)
#define cublascall(call) \
do \
cublasStatus_t status = (call); \
if(CUBLAS_STATUS_SUCCESS != status) \
fprintf(stderr,"CUBLAS Error:\nFile = %s\nLine = %d\nCode = %d\n", __FILE__, __LINE__, status); \
while(0)
void invert(float** src, float** dst, int n, int batchSize)
cublasHandle_t handle;
cublascall(cublasCreate_v2(&handle));
int *P, *INFO;
cudacall(cudaMalloc(&P, n * batchSize * sizeof(int)));
cudacall(cudaMalloc(&INFO, batchSize * sizeof(int)));
int lda = n;
float **A = (float **)malloc(batchSize*sizeof(float *));
float **A_d, *A_dflat;
cudacall(cudaMalloc(&A_d,batchSize*sizeof(float *)));
cudacall(cudaMalloc(&A_dflat, n*n*batchSize*sizeof(float)));
A[0] = A_dflat;
for (int i = 1; i < batchSize; i++)
A[i] = A[i-1]+(n*n);
cudacall(cudaMemcpy(A_d,A,batchSize*sizeof(float *),cudaMemcpyHostToDevice));
for (int i = 0; i < batchSize; i++)
cudacall(cudaMemcpy(A_dflat+(i*n*n), src[i], n*n*sizeof(float), cudaMemcpyHostToDevice));
cublascall(cublasSgetrfBatched(handle,n,A_d,lda,P,INFO,batchSize));
int INFOh[batchSize];
cudacall(cudaMemcpy(INFOh,INFO,batchSize*sizeof(int),cudaMemcpyDeviceToHost));
if(INFOh[i] != 0)
fprintf(stderr, "Factorization of matrix %d Failed: Matrix may be singular\n", i);
cudaDeviceReset();
exit(EXIT_FAILURE);
float **C = (float **)malloc(batchSize*sizeof(float *));
float **C_d, *C_dflat;
cudacall(cudaMalloc(&C_d,batchSize*sizeof(float *)));
cudacall(cudaMalloc(&C_dflat, n*n*batchSize*sizeof(float)));
C[0] = C_dflat;
C[i] = C[i-1] + (n*n);
cudacall(cudaMemcpy(C_d,C,batchSize*sizeof(float *),cudaMemcpyHostToDevice));
cublascall(cublasSgetriBatched(handle,n,(const float **)A_d,lda,P,C_d,lda,INFO,batchSize));
if(INFOh[i] != 0)
fprintf(stderr, "Inversion of matrix %d Failed: Matrix may be singular\n", i);
cudaDeviceReset();
exit(EXIT_FAILURE);
cudacall(cudaMemcpy(dst[i], C_dflat + (i*n*n), n*n*sizeof(float), cudaMemcpyDeviceToHost));
cudaFree(A_d); cudaFree(A_dflat); free(A);
cudaFree(C_d); cudaFree(C_dflat); free(C);
cudaFree(P); cudaFree(INFO); cublasDestroy_v2(handle);
void test_invert()
const int n = 3;
const int mybatch = 4;
//Random matrix with full pivots
float full_pivot[n*n] = { 0.5, 3, 4,
1, 3, 10,
4 , 9, 16 };
//Almost same as above matrix with first pivot zero
float zero_pivot[n*n] = { 0, 3, 4,
1, 3, 10,
4 , 9, 16 };
float another_zero_pivot[n*n] = { 0, 3, 4,
1, 5, 6,
9, 8, 2 };
float another_full_pivot[n * n] = { 22, 3, 4,
1, 5, 6,
9, 8, 2 };
float *result_flat = (float *)malloc(mybatch*n*n*sizeof(float));
float **results = (float **)malloc(mybatch*sizeof(float *));
for (int i = 0; i < mybatch; i++)
results[i] = result_flat + (i*n*n);
float **inputs = (float **)malloc(mybatch*sizeof(float *));
inputs[0] = zero_pivot;
inputs[1] = full_pivot;
inputs[2] = another_zero_pivot;
inputs[3] = another_full_pivot;
for (int qq = 0; qq < mybatch; qq++){
fprintf(stdout, "Input %d:\n\n", qq);
for(int i=0; i<n; i++)
for(int j=0; j<n; j++)
fprintf(stdout,"%f\t",inputs[qq][i*n+j]);
fprintf(stdout,"\n");
fprintf(stdout,"\n\n");
invert(inputs, results, n, mybatch);
fprintf(stdout, "Inverse %d:\n\n", qq);
fprintf(stdout,"%f\t",results[qq][i*n+j]);
int main()
test_invert();
return 0;
$ nvcc -arch=sm_20 -o t540 t540.cu -lcublas
$ ./t540
Input 0:
0.000000 3.000000 4.000000
1.000000 3.000000 10.000000
4.000000 9.000000 16.000000
Input 1:
0.500000 3.000000 4.000000
Input 2:
1.000000 5.000000 6.000000
9.000000 8.000000 2.000000
Input 3:
22.000000 3.000000 4.000000
Inverse 0:
-0.700000 -0.200000 0.300000
0.400000 -0.266667 0.066667
-0.050000 0.200000 -0.050000
Inverse 1:
-1.076923 -0.307692 0.461538
0.615385 -0.205128 -0.025641
-0.076923 0.192308 -0.038462
Inverse 2:
-4.750000 3.250000 -0.250000
6.500000 -4.500000 0.500000
-4.625000 3.375000 -0.375000
Inverse 3:
0.045894 -0.031401 0.002415
-0.062802 -0.009662 0.154589
0.044686 0.179952 -0.129227
I checked the results with wolfram alpha:
http://www.wolframalpha.com/widgets/view.jsp?id=35f68681262e42ea89b0834caa51635b
they seem to be correct.
