Matrix manipulation, performance problem
My problem is the following :
I have a group of 2D matrix and I want to evaluate the max of each point of the matrix.
All the matrix have the same dimension.
To try to optimise performance, I use a linear representation of data like that:
If i have a matrix with i,j dimension and k matrix
[Data_i_j_k1, Data_i_j_k2 … ] …
I use 256 thread /bloc and i have tested with 1 to 1000 bloc (I don’t understand for the moment how to evaluate the best number block to use …)
My kernel fonction is the following :
__global__ void calculmaxLineaireGPU(int * domaine, int * maxRes2, int dimX, int nbMAT, int nbPoint)
	const unsigned int tidX = threadIdx.x;
	const unsigned int tidY = threadIdx.y; // allways 0, only one dimension used dimension
	const unsigned int bx   = blockIdx.x;
	int indice = tidX + bx *dimX;                // + numTh; // *idBlocX;
	int tmp, val;
	int tab[100]; //  100 Matrix max
	__syncthreads();
	if (indice < nbPoint)
  for (int i = 0; i < nbMAT; i++) {
  	tab[i] = domaine[indice*nbMAT + i];
 __syncthreads();
  tmp = tab[0];
  for (int j = 1; j < nbMAT; j++){
  	tmp = fmaxf(tmp, tab[j]);
  maxRes2[indice] = tmp;
And, I call this kernel with this loop :
CUDA_SAFE_CALL( cudaMalloc( (void**) &gpuData, mem_gpu_ref));
	CUDA_SAFE_CALL( cudaMalloc( (void**) &gpuRes , mem_gpu_R_ref));
	while (colNonCalc > 0)
  if (colNonCalc < nbCol_it){
  	colCalc = colNonCalc;
  	mem_gpu = colCalc * nbMAT * sizeof(int);
  	mem_gpu_R = colCalc * sizeof(int);
  	threads.x = colCalc;
 }else{
  	colCalc = nbCol_it;
  	mem_gpu = mem_gpu_ref;
  	mem_gpu_R = mem_gpu_R_ref;
  CUDA_SAFE_CALL( cudaMemcpy( gpuData, data, mem_gpu, cudaMemcpyHostToDevice) );
 // execute the kernel
  calculmaxLineaireGPU<<<grid, threads>>> (gpuData,gpuRes, nbTh, nbMAT, colCalc);
  // CUT_CHECK_ERROR("Kernel execution failed");
  CUDA_SAFE_CALL( cudaMemcpy( res, gpuRes, mem_gpu_R, cudaMemcpyDeviceToHost) );
  // On deplace le curseur
  colNonCalc -= colCalc;
  data += colCalc*nbMAT;
  res += colCalc;
	CUDA_SAFE_CALL(cudaFree(gpuData));
	CUDA_SAFE_CALL(cudaFree(gpuRes));
This code is functionnal … but its performance are bad … the same with the CPU.
Why it’s wrong in my code (bad memory use, …) ?
I don’t understand why my performance are so bad :(
Thaks a lot
Beleys
