Matrix multiply Vector problem using ScalarProd
I want to multiply an NXN matrix with a Vector.As a beginner, I modified the example scalarprodGPU kernel in the CUDA SDK package as follows(the comment has been removed for clarity):
d_C is used to store the result of multiplication.
d_D is used to store the result of transposed matrix of d_A multiplies vector d_B(initialized to be zero).
d_A is the matrix
d_B is the vector
the result shows that d_C is OK but d_D is not correct. Is there any suggestions?
Thanks a lot.
#define IMUL(a, b) __mul24(a, b)
#define ACCUM_N 1024
__global__ void scalarProdGPU(
    float *d_C,
    float *d_A,
    float *d_B,
    float *d_D,
    int vectorN,
    int elementN
    //Accumulators cache
    __shared__ float accumResult[ACCUM_N];
   for(int vec = blockIdx.x; vec < vectorN; vec += gridDim.x){
        int vectorBase = IMUL(elementN, vec);
        int vectorEnd  = vectorBase + elementN;
       for(int iAccum = threadIdx.x; iAccum < ACCUM_N; iAccum += blockDim.x){
            float sum = 0;
           for(int pos = vectorBase + iAccum; pos < vectorEnd; pos += ACCUM_N)
//modified code :
                                      float tmp = d_A[pos] * d_B[pos - vectorBase];
                                      d_D[pos-vectorBase]+=tmp; //add every rows' tmp result
                                       sum += tmp;
           accumResult[iAccum] = sum;
        for(int stride = ACCUM_N / 2; stride > 0; stride >>= 1){
            __syncthreads();
            for(int iAccum = threadIdx.x; iAccum < stride; iAccum += blockDim.x)
                accumResult[iAccum] += accumResult[stride + iAccum];
       if(threadIdx.x == 0) d_C[vec] = accumResult[0];
I find that
d_D[pos-vectorBase] += tmp;
executed only once for every element of d_D but not the VectorN.
But I don’t know why.
