MatrixMul error header error
make -C projects/matrixMul
make: Entering directory /root/ncs/projects/matrixMul' /usr/include/c++/4.3/bits/ios_base.h:410: error: declaration of ‘typedef class std::streampos std::ios_base::streampos’ /usr/include/c++/4.3/bits/postypes.h:207: error: changes meaning of ‘streampos’ from ‘typedef class std::fpos<__mbstate_t> std::streampos’ /usr/include/c++/4.3/bits/ios_base.h:411: error: declaration of ‘typedef std::streamoff std::ios_base::streamoff’ /usr/include/c++/4.3/bits/postypes.h:71: error: changes meaning of ‘streamoff’ from ‘typedef int64_t std::streamoff’ /usr/include/c++/4.3/streambuf:147: note: (if this is not what you intended, make sure the function template has already been declared and add <> after the function name here) make: *** [obj/release/matrixMul.cu.o] Error 255 make: Leaving directory /root/ncs/projects/matrixMul’
how can i fix this error ???
Which Linux distribution are you running?
Which version of CUDA did you install ?
Linux dist: Suse 11.1
CUDA : 2.1
other projects are working fine …
this is where the error comes from
i `ve change in the
ios_base.h:410 typedef class std::streampos std::ios_base::streampos to typedef class std::streampos std::ios_base::streampos_t
ios_base.h:411 typedef class std::streamoff std::ios_base::streamoff to typedef class std::streampos std::ios_base::streamoff_t
now it seems to work
~/ncs/bin/linux/release/matrixMul says Test : PASSED
but i dont know if it was right to change the ios_base.h file External Media
any suggestions ?
adding a
 using namespace std
before the include of the any STL file
works around this.
this is fixed in the 2.2 release
thanks that solved it ! :)
