https://devblogs.nvidia.com/jetson-nano-ai-computing/
according to the blog post “The system can decode 500 MP/s of H.264/H.265 and encode 250 MP/s of H.264/H.265 video.”
What is the max clock speed?
what does MP/s stand for ?
Hi Ravi, MP/s stands for “megapixels per second”, the maximum aggregate throughput. It is equal to the number of streams * resolution * framerate.
See table 1 from the blog or the module datasheet:
Video Encode: 4Kp30 | (4x) 1080p30 | (2x) 1080p60
Video Decode: 4Kp60 | (2x) 4Kp30 | (8x) 1080p30 | (4x) 1080p60
You can run multiple streams simultaneously up to the maximum aggregate throughput, for example:
If you run ‘sudo tegrastats’, the active NVENC/NVDEC frequencies will show up when the encoder or decoder are being used, respectively.
