@Greg
I saw your post here. You said that by considering limitations, for 2 warp schedulers per SM, the max IPC is 1.5. So, do you know the same number for 3080? As I said, the max IPC should be 68 * 4 * 1=272. However, if I assume that 4 scheduler issue up to 3 warp instructions, it will be 68 * 4 * 0.75=204.
Can you clarify that?
