Hi everyone,
For the MAX-N is quite straightforward to realize that the mode is meant for full clock speeds. The MAX-P mode is however not clear to me. Could you please give me a brief insight about the difference?
Thanks big time.
Hi everyone,
Thanks big time.
I suggest these links, for me was really useful.
https://devblogs.nvidia.com/jetson-tx2-delivers-twice-intelligence-edge/
https://devblogs.nvidia.com/jetpack-doubles-jetson-inference-perf/
Best,
Raffaello
Hi Raffaello,
first of all thank you for your answer.
I have read these blogs but they do not give a definite description of MAX-P.
Thank you anyway.
Hi maycondouglasd,
The MAX-P is for power and performance balance, depends on your use case to do the evaluation to decide if need to use all cores(A57 + Denver), ARM A57 cores or Denver cores in different freq for specific requirements.
Cheers.
Hi kayccc,
In NVIDIA Jetson TX2 Delivers Twice the Intelligence to the Edge | NVIDIA Technical Blog it is stated that:
“Max-P, the other preset platform configuration, enables maximum system performance in less than 15W”.
The max-clocks mode still manages to give better performance than MAX-P under the 15W budget, according to the measurements in the blog post.
This is why the definition of what MAX-P really does is still fuzzy.
I would appreciate a slightly more detailed explanation.
