Question:
How do I query the total number of threads or warps for an SM?
I only see calls to query the total number per thread block.
Workaround:
I can query the compute capability and implement my own lookup.
Is there a better way?
Question:
Workaround:
I’m wondering the same question, there is no solution to get the max num. of threads per SM except the compute capability ?
Thank you,
Best Regards
call cuDeviceGetAttribute with CU_DEVICE_ATTRIBUTE_MAX_THREADS_PER_BLOCK flag
That’s “per block”.
We’re asking “per SM”.
E.g. for the Fermi the first number is 1024, the latter is 1536.
You can use with CU_DEVICE_ATTRIBUTE_MAX_THREADS_PER_MULTIPROCESSOR
In which situation is the max threads per SM relevant? In the program one specifies the number of threads per block. A block is executed on a SM, if there are resources blocks can be assign in the same time to the same SM.
