I’m using Orin NX 16GB and JP5.1.1 and set power mode to 15W
In the nvpmodel.conf, there are just 4 cpus online and 4 cpus offline. But there are all 8 cpus online in Jetson Power GUI.
And if we burn in test the system, the power will over 15W.
Is the “15W” just a name of power mode? It’s not the max power limitation of the power mode?
Ideally when you select the 15W mode, module power is expected to be less than 15W with a typical workload.
Did you run heavy stress on multiple engines (CPU, GPU, DLA, PVA, DEC, ENC, ISP…etc) concurrently?
What test case/application you ran?
