dmesg (68.0 KB)
We are using Xavier NX and L4T version R35.3.1, but the device starts with the following error, what could be the cause?
[ 0.296302] thermal_sys: Registered thermal governor 'step_wise'
[ 0.296310] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.296326] thermal_sys: Registered thermal governor 'pid_thermal_gov'
[ 0.297161] OF: /thermal-zones/CPU-therm/cooling-maps/map3: could not find phandle
[ 0.297192] thermal_sys: Add a cooling_device property with at least one device
[ 0.297210] thermal_sys: failed to build thermal zone CPU-therm: -2
[ 0.297344] OF: /thermal-zones/GPU-therm/cooling-maps/map3: could not find phandle
[ 0.297355] thermal_sys: Add a cooling_device property with at least one device
[ 0.297368] thermal_sys: failed to build thermal zone GPU-therm: -2
[ 0.297498] OF: /thermal-zones/AUX-therm/cooling-maps/map3: could not find phandle
[ 0.297508] thermal_sys: Add a cooling_device property with at least one device
[ 0.297521] thermal_sys: failed to build thermal zone AUX-therm: -2
[ 0.297876] OF: /thermal-zones/PMIC-Die/cooling-maps/map3: could not find phandle
[ 0.297890] thermal_sys: Add a cooling_device property with at least one device
[ 0.297904] thermal_sys: failed to build thermal zone PMIC-Die: -2
[ 0.297965] cpuidle: using governor menu
[ 11.607821] max77620-thermal max77620-thermal: Failed to register thermal zone: -517
[ 11.607988] tegra-i2c 31e0000.i2c: deferred probe timeout, ignoring dependency
[ 11.620240] max77620-thermal max77620-thermal: Failed to register thermal zone: -517
[ 11.620590] tegra-i2c 31e0000.i2c: deferred probe timeout, ignoring dependency
[ 11.628817] max77620-thermal max77620-thermal: Failed to register thermal zone: -517
[ 11.629164] tegra-i2c 31e0000.i2c: deferred probe timeout, ignoring dependency
[ 11.663934] max77620-thermal max77620-thermal: Failed to register thermal zone: -517
[ 11.664451] tegra-i2c 31e0000.i2c: deferred probe timeout, ignoring dependency
[ 11.690741] max77620-thermal max77620-thermal: Failed to register thermal zone: -517
[ 11.691111] tegra-i2c 31e0000.i2c: deferred probe timeout, ignoring dependency
[ 11.733107] max77620-thermal max77620-thermal: Failed to register thermal zone: -517
[ 11.778317] tegra-i2c 31e0000.i2c: deferred probe timeout, ignoring dependency
[ 11.791209] 1 fixed-partitions partitions found on MTD device spi6.0
[ 11.791385] Creating 1 MTD partitions on "spi6.0":
[ 11.791513] 0x000000000000-0x000002000000 : "Whole_flash0"
[ 11.805579] max77620-thermal max77620-thermal: Failed to register thermal zone: -517
[ 11.805943] tegra-i2c 31e0000.i2c: deferred probe timeout, ignoring dependency
JTOP also can not see the CPU, GPU and other temperature-related information
