hi
my hardware configuration is sensor -->> MAX9271 ->> MAX9288 -->> TX2i.
current i can see HS, VS, PCLKIN, DIN in MAX9271’s pins. but MAX9288 has no csi data signal output.
can you tell me suggestion?
thank you
hi
thank you
I would suggest to get help with vendor to confirm the configure.
hi, now i can get output waveform from deseriallize.
i think i have to check CSI status in jetson module. i checked CSI register in Parker_TRM_DP07821001p.pdf but it has total 893 registers.
could you tell me how to check if VNCSI received data, what error …etc
thank you
Have a reference to this
