Dear @bogdan0kg3v ,
Could you provide the logs of nvmimg_cap?
Hi @SivaRamaKrishnaNV @VickNV,
Apologies for delayed reply. We had some issues with running above command and had to re-flash the board. Here’s the output:
nvidia@rc-0004a:~/drive-t186ref-linux/samples/nvmedia/img_cap$ ./nvmimg_cap -cf ~/REE/nVidia_drivers/2836469_aac6ce059e_release_pkg_5.1.6.1-20200411/release_pkg_5.1.6.1-20200411/nvmedia/ipp_raw/ddpx-a.conf -c SF3324-CSI-AB -v 2 --aggregate 4
nvmedia: Using params set: SF3324-CSI-AB for capture
nvmedia isc: GetCameraPowerControlLevel: 936: Camera power control library: NVCCP
Max96712 Rev 2 detected!
nvmedia: ERROR: WriteArray: MAX96712: error: wri2c 0x0C 0x08
nvmedia: ERROR: SetupConfigLink: Failed to enable packet based control channel
nvmedia: ERROR: Init: Failed to setup config link
nvmedia: ERROR: CaptureInit: Failed to initialize ISC devices
nvmedia: ERROR: CaptureInit: Failed to initialize Capture
nvmedia: ERROR: main: Failed to Initialize Capture
nvmedia: CaptureSuspend: done
nvmedia: CaptureFini: CaptureFini done
Hope this helps in nail down the problem.
Let us know if you need anything else from our side,
B.
Dear @bogdan0kg3v,
Could you share the below commands output in Aurix shell
Shell>version
Shell>showvoltages
Shell>loadboardconfig
Shell>cimrom get sku
Hello, these are the outputs for the respective device:
shell> version
Info: Executing cmd: version, argc: 0, args:
SW Version: DRIVE-V5.1.6-E3550-EB-Aurix-With3LSS-ForHyperion-StepA-3.05.04
Compilation date: Jun 25 2019, 14:25:36
Command Executed
shell> showvoltages
Info: Executing cmd: showvoltages, argc: 0, args:
Error: Unknown command
Invalid Command
shell> show voltages
Info: Executing cmd: show, argc: 1, args: voltages
Invalid Command
shell> showvoltages
Invalid Command
shell> loadboardconfig
Info: Executing cmd: loadboardconfig, argc: 0, args:
Invalid Command
shell> cimrom get sku
Info: Executing cmd: cimrom, argc: 2, args: get sku
Get SKU is : 699-63553-0000-300
Command Executed
Dear @bogdan0kg3v,
Some of the command failed due to EB firmware. Could you attach the complete logs for below command
On Xavier A, camera ports A:
./nvmimg_cap -cf ddpx-a.conf -c SF3325-CSI-A -v 2 --aggregate 1
./nvmimg_cap -cf ddpx-a.conf -c SF3325-CSI-A -v 2 --aggregate 4
./nvmimg_cap -cf ddpx-a.conf -c SF3325-CSI-AB -v 2 --aggregate 1
./nvmimg_cap -cf ddpx-a.conf -c SF3325-CSI-AB -v 2 --aggregate 4
./nvmimg_cap -cf ddpx-a.conf -c SF3325-TRIO-AB -v 2 --aggregate 1
./nvmimg_cap -cf ddpx-a.conf -c SF3325-TRIO-AB -v 2 --aggregate 4
On Xavier B, camera ports A:
./nvmimg_cap -cf ddpx-b.conf -c SF3325-CSI-A -v 2 --aggregate 1
./nvmimg_cap -cf ddpx-b.conf -c SF3325-CSI-A -v 2 --aggregate 4
./nvmimg_cap -cf ddpx-b.conf -c SF3325-CSI-AB -v 2 --aggregate 1
./nvmimg_cap -cf ddpx-b.conf -c SF3325-CSI-AB -v 2 --aggregate 4
./nvmimg_cap -cf ddpx-b.conf -c SF3325-TRIO-AB -v 2 --aggregate 1
./nvmimg_cap -cf ddpx-b.conf -c SF3325-TRIO-AB -v 2 --aggregate 4
nvidia@rc-0004a:~/drive-t186ref-linux/samples/nvmedia/img_cap$ ./nvmimg_cap -cf ddpx-a.conf -c SF3325-CSI-A -v 2 --aggregate 1
nvmedia: Using params set: SF3325-CSI-A for capture
nvidia@rc-0004a:~/drive-t186ref-linux/samples/nvmedia/img_cap$ ./nvmimg_cap -cf ddpx-a.conf -c SF3325-CSI-A -v 2 --aggregate 4
nvmedia: ERROR: SetupConfigLink: Failed to set aggregator defaults, err = 121(Remote I/O error)
nvidia@rc-0004a:~/drive-t186ref-linux/samples/nvmedia/img_cap$ ./nvmimg_cap -cf ddpx-a.conf -c SF3325-CSI-AB -v 2 --aggregate 1
nvmedia: Using params set: SF3325-CSI-AB for capture
nvidia@rc-0004a:~/drive-t186ref-linux/samples/nvmedia/img_cap$ ./nvmimg_cap -cf ddpx-a.conf -c SF3325-CSI-AB -v 2 --aggregate 4
nvidia@rc-0004a:~/drive-t186ref-linux/samples/nvmedia/img_cap$ ./nvmimg_cap -cf ddpx-a.conf -c SF3325-TRIO-AB -v 2 --aggregate 1
nvmedia: Using params set: SF3325-TRIO-AB for capture
nvidia@rc-0004a:~/drive-t186ref-linux/samples/nvmedia/img_cap$ ./nvmimg_cap -cf ddpx-a.conf -c SF3325-TRIO-AB -v 2 --aggregate 4
nvidia@rc-0004b:~/drive-t186ref-linux/samples/nvmedia/img_cap$ ./nvmimg_cap -cf ddpx-b.conf -c SF3325-CSI-A -v 2 --aggregate 1
nvidia@rc-0004b:~/drive-t186ref-linux/samples/nvmedia/img_cap$ ./nvmimg_cap -cf ddpx-b.conf -c SF3325-CSI-A -v 2 --aggregate 4
nvidia@rc-0004b:~/drive-t186ref-linux/samples/nvmedia/img_cap$ ./nvmimg_cap -cf ddpx-b.conf -c SF3325-CSI-AB -v 2 --aggregate 1
nvidia@rc-0004b:~/drive-t186ref-linux/samples/nvmedia/img_cap$ ./nvmimg_cap -cf ddpx-b.conf -c SF3325-CSI-AB -v 2 --aggregate 4
nvidia@rc-0004b:~/drive-t186ref-linux/samples/nvmedia/img_cap$ ./nvmimg_cap -cf ddpx-b.conf -c SF3325-TRIO-AB -v 2 --aggregate 1
nvidia@rc-0004b:~/drive-t186ref-linux/samples/nvmedia/img_cap$ ./nvmimg_cap -cf ddpx-b.conf -c SF3325-TRIO-AB -v 2 --aggregate 4
Dear @bogdan0kg3v ,
Could you confirm if you have used SF3325 camera module when running above commands?
Oh sorry, there was a miscommunication on our end. Here are the proper logs:
MAX96712: Enable periodic AEQ on Link 0
MAX96705: Pre-emphasis set to 0xaa
Sensor AR0231 RCCB Rev7 detected!
Type "h" for a list of options
-nvmedia: _CaptureThreadFunc: VC:0 FPS=0 delta=637354538
nvmedia: _CaptureThreadFunc: VC:0 FPS=29 delta=3000110
nvmedia: _CaptureThreadFunc: VC:0 FPS=29 delta=3000118
nvmedia: _CaptureThreadFunc: VC:0 FPS=29 delta=3000101
^Cnvmedia: DisplaySuspend: done
nvmedia: CompositeSuspend: done
nvmedia: _SaveThreadFunc: Save thread exited
nvmedia: SaveSuspend: done
nvmedia: _ErrHandlerThreadFunc: Error Handler thread exited
nvmedia: ErrHandlerSuspend: done
nvmedia: _CmdHandlerThreadFunc: Command Handler thread exited
nvmedia: _CaptureThreadFunc: Capture thread exited
nvmedia: CmdHandlerFini: CmdHandlerFini done
nvmedia: DisplayFini: done
nvmedia: CompositeFini: done
nvmedia: SaveFini: done
nvmedia: ErrHandlerFini: done
MAX96712: Enable periodic AEQ on Link 1
MAX96712: Enable periodic AEQ on Link 2
MAX96712: Enable periodic AEQ on Link 3
-nvmedia: _CaptureThreadFunc: VC:1 FPS=0 delta=653988433
nvmedia: _CaptureThreadFunc: VC:0 FPS=0 delta=653988453
nvmedia: _CaptureThreadFunc: VC:3 FPS=0 delta=654021812
nvmedia: _CaptureThreadFunc: VC:2 FPS=0 delta=654021839
nvmedia: _CaptureThreadFunc: VC:0 FPS=29 delta=3000072
nvmedia: _CaptureThreadFunc: VC:1 FPS=29 delta=3000094
nvmedia: _CaptureThreadFunc: VC:3 FPS=29 delta=3000034
nvmedia: _CaptureThreadFunc: VC:2 FPS=29 delta=3000017
nvmedia: _CaptureThreadFunc: VC:1 FPS=30 delta=3033223
nvmedia: _CaptureThreadFunc: VC:0 FPS=30 delta=3033238
nvmedia: _CaptureThreadFunc: VC:3 FPS=30 delta=3033180
nvmedia: _CaptureThreadFunc: VC:2 FPS=30 delta=3033176
-nvmedia: _CaptureThreadFunc: VC:0 FPS=0 delta=666287545
nvmedia: _CaptureThreadFunc: VC:0 FPS=30 delta=3033197
nvmedia: _CaptureThreadFunc: VC:0 FPS=29 delta=3000002
nvmedia: _CaptureThreadFunc: VC:0 FPS=29 delta=3000039
^Cnvmedia: ERROR: CmdHandlerProcessRuntimeCommand: Invalid run time command
nvmedia: ERROR: ExecuteNextCommand: Failed to process run time command
-nvmedia: _CaptureThreadFunc: VC:3 FPS=0 delta=682921042
nvmedia: _CaptureThreadFunc: VC:2 FPS=0 delta=682921054
nvmedia: _CaptureThreadFunc: VC:0 FPS=0 delta=682921068
nvmedia: _CaptureThreadFunc: VC:1 FPS=0 delta=682921060
nvmedia: _CaptureThreadFunc: VC:3 FPS=29 delta=3000068
nvmedia: _CaptureThreadFunc: VC:2 FPS=29 delta=3000067
nvmedia: _CaptureThreadFunc: VC:1 FPS=29 delta=3000067
nvmedia: _CaptureThreadFunc: VC:0 FPS=29 delta=3000068
nvmedia: _CaptureThreadFunc: VC:3 FPS=29 delta=3000077
nvmedia: _CaptureThreadFunc: VC:2 FPS=29 delta=3000072
nvmedia: _CaptureThreadFunc: VC:1 FPS=29 delta=3000075
nvmedia: _CaptureThreadFunc: VC:0 FPS=29 delta=3000076
-nvmedia: _CaptureThreadFunc: VC:0 FPS=0 delta=697121311
nvmedia: _CaptureThreadFunc: VC:0 FPS=29 delta=3000040
nvmedia: _CaptureThreadFunc: VC:0 FPS=29 delta=3000111
nvmedia: _CaptureThreadFunc: VC:0 FPS=29 delta=3000063
-nvmedia: _CaptureThreadFunc: VC:0 FPS=0 delta=714388574
nvmedia: _CaptureThreadFunc: VC:3 FPS=0 delta=714388559
nvmedia: _CaptureThreadFunc: VC:2 FPS=0 delta=714388568
nvmedia: _CaptureThreadFunc: VC:1 FPS=0 delta=714388575
nvmedia: _CaptureThreadFunc: VC:3 FPS=29 delta=3000040
nvmedia: _CaptureThreadFunc: VC:1 FPS=29 delta=3000041
nvmedia: _CaptureThreadFunc: VC:2 FPS=29 delta=3000042
nvmedia: _CaptureThreadFunc: VC:0 FPS=29 delta=3000142
nvmedia: _CaptureThreadFunc: VC:3 FPS=29 delta=3000073
nvmedia: _CaptureThreadFunc: VC:1 FPS=29 delta=3000071
nvmedia: _CaptureThreadFunc: VC:0 FPS=30 delta=3033249
-nvmedia: _CaptureThreadFunc: VC:0 FPS=0 delta=833935150
nvmedia: _CaptureThreadFunc: VC:0 FPS=29 delta=3000018
nvmedia: _CaptureThreadFunc: VC:0 FPS=29 delta=3000046
nvmedia: _CaptureThreadFunc: VC:0 FPS=29 delta=3000057
-nvmedia: _CaptureThreadFunc: VC:2 FPS=0 delta=857702304
nvmedia: _CaptureThreadFunc: VC:0 FPS=0 delta=857702319
nvmedia: _CaptureThreadFunc: VC:1 FPS=0 delta=857702318
nvmedia: _CaptureThreadFunc: VC:3 FPS=0 delta=857702316
nvmedia: _CaptureThreadFunc: VC:3 FPS=29 delta=3000012
nvmedia: _CaptureThreadFunc: VC:2 FPS=29 delta=3000030
nvmedia: _CaptureThreadFunc: VC:1 FPS=29 delta=3000028
nvmedia: _CaptureThreadFunc: VC:0 FPS=29 delta=3000043
nvmedia: _CaptureThreadFunc: VC:3 FPS=29 delta=3000042
nvmedia: _CaptureThreadFunc: VC:1 FPS=29 delta=3000039
nvmedia: _CaptureThreadFunc: VC:0 FPS=29 delta=3000034
-nvmedia: _CaptureThreadFunc: VC:0 FPS=0 delta=870835680
nvmedia: _CaptureThreadFunc: VC:0 FPS=29 delta=3000027
nvmedia: _CaptureThreadFunc: VC:0 FPS=29 delta=3000073
-nvmedia: _CaptureThreadFunc: VC:3 FPS=0 delta=886336100
nvmedia: _CaptureThreadFunc: VC:0 FPS=0 delta=886336125
nvmedia: _CaptureThreadFunc: VC:2 FPS=0 delta=886336123
nvmedia: _CaptureThreadFunc: VC:1 FPS=0 delta=886336121
nvmedia: _CaptureThreadFunc: VC:3 FPS=30 delta=3033273
nvmedia: _CaptureThreadFunc: VC:2 FPS=30 delta=3033260
nvmedia: _CaptureThreadFunc: VC:1 FPS=30 delta=3033268
nvmedia: _CaptureThreadFunc: VC:0 FPS=30 delta=3033271
nvmedia: _CaptureThreadFunc: VC:3 FPS=29 delta=3000038
nvmedia: _CaptureThreadFunc: VC:2 FPS=29 delta=3000037
nvmedia: _CaptureThreadFunc: VC:0 FPS=29 delta=3000035
nvmedia: _CaptureThreadFunc: VC:1 FPS=29 delta=3000044
-nvmedia: _CaptureThreadFunc: VC:0 FPS=0 delta=898869457
nvmedia: _CaptureThreadFunc: VC:0 FPS=29 delta=3000025
nvmedia: _CaptureThreadFunc: VC:0 FPS=29 delta=3000037
nvmedia: _CaptureThreadFunc: VC:0 FPS=29 delta=3000011
-nvmedia: _CaptureThreadFunc: VC:3 FPS=0 delta=915669826
nvmedia: _CaptureThreadFunc: VC:0 FPS=0 delta=915669855
nvmedia: _CaptureThreadFunc: VC:2 FPS=0 delta=915669843
nvmedia: _CaptureThreadFunc: VC:1 FPS=0 delta=915669851
nvmedia: _CaptureThreadFunc: VC:3 FPS=29 delta=3000035
nvmedia: _CaptureThreadFunc: VC:1 FPS=29 delta=3000046
nvmedia: _CaptureThreadFunc: VC:2 FPS=29 delta=3000048
nvmedia: _CaptureThreadFunc: VC:0 FPS=29 delta=3000155
nvmedia: _CaptureThreadFunc: VC:3 FPS=29 delta=3000064
nvmedia: _CaptureThreadFunc: VC:2 FPS=29 delta=3000033
nvmedia: _CaptureThreadFunc: VC:1 FPS=29 delta=3000034
nvmedia: _CaptureThreadFunc: VC:0 FPS=30 delta=3033220
Dear @bogdan0kg3v ,
The issue with camera port is not reproduced with SF3325 camera module? The log shows they all passed.
Again my fault. The issue is on Camera Port B not A.
On Xavier A, camera port B:
First four commands work fine. Last two break
nvidia@rc-0004a:~/drive-t186ref-linux/samples/nvmedia/img_cap$ ./nvmimg_cap -cf ddpx-a.conf -c SF3325-TRIO-CD -v 2 --aggregate 1
nvmedia: Using params set: SF3325-TRIO-CD for capture
-nvmedia: WARNING: _CaptureThreadFunc: NvMediaICPGetImageGroup timed out
nvmedia: ERROR: _CaptureThreadFunc: keep failing at NvMediaICPGetImageGroup for 11 times
ReleaseImage: CaptureGet failed with status 3
nvmICPReleaseImageGroup: failed to release image 0 in the group
nvidia@rc-0004a:~/drive-t186ref-linux/samples/nvmedia/img_cap$ ./nvmimg_cap -cf ddpx-a.conf -c SF3325-TRIO-CD -v 2 --aggregate 4
-EngineStatusError (2), Detailed Error Code: 00000001 at StreamId:2 vcId:3 CSIFrameId:0
nvmedia: ERROR: In CSI-Stream:2, CSI-FrameId:0, CSI-VC:3, error Type:VI_FS_TIMEOUT(Frame Start Timeout Error)
nvmedia: ERROR: In CSI-Stream:2, CSI-FrameId:0, CSI-VC:3, error Type:VI_SHORT_FRAME(FE packet arrived before the normal number of pixels has appeared)
nvmedia: _CaptureThreadFunc: VC:3 FPS=0 delta=1197333628
Interesting. on Xavier B everything works as expected:
nvidia@rc-0004b:~/drive-t186ref-linux/samples/nvmedia/img_cap$ ./nvmimg_cap -cf ddpx-b.conf -c SF3325-TRIO-CD -v 2 --aggregate 1
-nvmedia: _CaptureThreadFunc: VC:0 FPS=0 delta=1517884318
nvmedia: _CaptureThreadFunc: VC:0 FPS=30 delta=3033330
nvmedia: _CaptureThreadFunc: VC:0 FPS=29 delta=3000052
nvmedia: _CaptureThreadFunc: VC:0 FPS=29 delta=3000070
nvidia@rc-0004b:~/drive-t186ref-linux/samples/nvmedia/img_cap$ ./nvmimg_cap -cf ddpx-b.conf -c SF3325-TRIO-CD -v 2 --aggregate 4
-nvmedia: _CaptureThreadFunc: VC:3 FPS=0 delta=1535884749
nvmedia: _CaptureThreadFunc: VC:1 FPS=0 delta=1535884769
nvmedia: _CaptureThreadFunc: VC:0 FPS=0 delta=1535884775
nvmedia: _CaptureThreadFunc: VC:2 FPS=0 delta=1535884776
nvmedia: _CaptureThreadFunc: VC:3 FPS=30 delta=3033278
nvmedia: _CaptureThreadFunc: VC:2 FPS=30 delta=3033274
nvmedia: _CaptureThreadFunc: VC:1 FPS=30 delta=3033301
nvmedia: _CaptureThreadFunc: VC:0 FPS=30 delta=3033303
nvmedia: _CaptureThreadFunc: VC:3 FPS=29 delta=3000084
nvmedia: _CaptureThreadFunc: VC:2 FPS=29 delta=3000073
nvmedia: _CaptureThreadFunc: VC:1 FPS=29 delta=3000061
nvmedia: _CaptureThreadFunc: VC:0 FPS=29 delta=3000060
Dear @richard5,
Could you double confirm if these are logs corresponding to SF3325 camera connection on port B in both Tegra A and Tegra B. So that I escalate the issue again with updated logs.
Yes I confirm that these are the logs that appear when running.
and
Four SF3325 cameras are attached to port B.
Dear @richard5 ,
Is the issue persists even after re-installation? If not tried, could you check re-installing and share the logs?
That is what we did last week. This is a completely fresh system.
