Max96712 timeout 2500ms
 kworker/3:6-283     [003] .......    62.552499: rtcpu_dbg_set_loglevel: tstamp:3324824638 old:0 new:2
 kworker/3:6-283     [003] .......    68.284747: rtcpu_string: tstamp:3505345245 id:0x04010000 str:"VM0 deactivating."
 grab_camera-2368    [002] .......   154.805336: tegra_channel_open: vi-output, ar0234 2-0033
 grab_camera-2368    [002] .......   154.821413: tegra_channel_set_power: ar0234 2-0033 : 0x1
 grab_camera-2368    [002] .......   154.821487: camera_common_s_power: status : 0x1
 grab_camera-2368    [002] .......   154.821510: tegra_channel_set_power: 13e00000.host1x:nvcsi@15a00000- : 0x1
 grab_camera-2368    [002] .......   154.821512: csi_s_power: enable : 0x1
 grab_camera-2368    [002] .......   154.822438: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1300 fmt 10
vi-output, ar02-2369 [002] … 154.831758: vi_task_submit: class_id:48 ch:0 syncpt_id:36 syncpt_thresh:0 pid:2369 tid:2369
vi-output, ar02-2369 [002] … 154.831763: vi_task_submit: class_id:48 ch:0 syncpt_id:36 syncpt_thresh:0 pid:2369 tid:2369
vi-output, ar02-2369 [002] … 154.831765: vi_task_submit: class_id:48 ch:0 syncpt_id:36 syncpt_thresh:0 pid:2369 tid:2369
vi-output, ar02-2369 [002] … 154.831766: vi_task_submit: class_id:48 ch:0 syncpt_id:36 syncpt_thresh:0 pid:2369 tid:2369
grab_camera-2368 [001] … 154.831792: tegra_channel_set_stream: enable : 0x1
grab_camera-2368 [000] … 154.833361: tegra_channel_set_stream: 13e00000.host1x:nvcsi@15a00000- : 0x1
grab_camera-2368 [000] … 154.833365: csi_s_stream: enable : 0x1
grab_camera-2368 [000] … 154.833903: tegra_channel_set_stream: ar0234 2-0033 : 0x1
kworker/3:6-283 [003] … 154.876491: rtcpu_string: tstamp:6210119690 id:0x04010000 str:“VM0 activating.”
kworker/3:6-283 [003] … 154.876494: rtcpu_string: tstamp:6210228523 id:0x04010000 str:"calibration status1 1a294272 status2 2f29c633
kworker/3:6-283 [003] … 154.876501: rtcpu_string: tstamp:6210228969 id:0x04010000 str:"calibration status1 28fa4612 status2 2119d2b5
kworker/3:6-283 [003] … 154.876505: rtcpu_string: tstamp:6210229409 id:0x04010000 str:"calibration status1 3308435 status2 2108701
kworker/3:6-283 [003] … 154.876507: rtcpu_string: tstamp:6210229851 id:0x04010000 str:"calibration status1 2939cef4 status2 28e9c291
kworker/3:6-283 [003] … 154.876510: rtcpu_string: tstamp:6210238431 id:0x04010000 str:“NVCSILP clock rate = 408000000 Hz.
kworker/3:6-283 [003] … 154.876514: rtcpu_string: tstamp:6210339855 id:0x04010000 str:“tegra_nvcsi_stream_set_config(vm0, stream=0, csi”
kworker/3:6-283 [003] … 154.876515: rtcpu_string: tstamp:6210339961 id:0x04010000 str:”=0)
kworker/3:6-283 [003] … 154.876519: rtcpu_string: tstamp:6210340333 id:0x04010000 str:“MIPI clock = 600000 kHz, tHS-SETTLE = 0, tCLK-SE”
kworker/3:6-283 [003] … 154.876519: rtcpu_string: tstamp:6210340438 id:0x04010000 str:“TTLE = 0
kworker/3:6-283 [003] … 154.876523: rtcpu_string: tstamp:6210340648 id:0x04010000 str:”===== NVCSI Stream Configuration =====
kworker/3:6-283 [003] … 154.876525: rtcpu_string: tstamp:6210340896 id:0x04010000 str:"stream_id: PP 0, csi_port: PORT A
kworker/3:6-283 [003] … 154.876528: rtcpu_string: tstamp:6210341135 id:0x04010000 str:"Brick: PHY 0, Mode: D-PHY
kworker/3:6-283 [003] … 154.876531: rtcpu_string: tstamp:6210341421 id:0x04010000 str:"Partition: CIL A, LP bypass: Enabled, Lanes: 4
kworker/3:6-283 [003] … 154.876534: rtcpu_string: tstamp:6210341603 id:0x04010000 str:"Clock information:
kworker/3:6-283 [003] … 154.876537: rtcpu_string: tstamp:6210341905 id:0x04010000 str:"MIPI clock rate: 600.00 MHz
kworker/3:6-283 [003] … 154.876540: rtcpu_string: tstamp:6210342147 id:0x04010000 str:“T_HS settle: 0, T_CLK settle: 0
kworker/3:6-283 [003] … 154.876542: rtcpu_string: tstamp:6210342373 id:0x04010000 str:”======================================
kworker/3:6-283 [003] … 154.876545: rtcpu_string: tstamp:6210344129 id:0x04010000 str:"tegra_nvcsi_stream_open(vm0, stream=0, csi=0)
kworker/3:6-283 [003] … 154.876548: rtcpu_string: tstamp:6210344758 id:0x04010000 str:“nvcsi_reset_data_lanes: NVCSI_PHY_0_NVCSI_CIL_A_”
kworker/3:6-283 [003] … 154.876549: rtcpu_string: tstamp:6210344861 id:0x04010000 str:"SW_RESET_0 = 00000003
kworker/3:6-283 [003] … 154.876552: rtcpu_string: tstamp:6210345219 id:0x04010000 str:“nvcsi_reset_data_lanes: NVCSI_PHY_0_NVCSI_CIL_B_”
kworker/3:6-283 [003] … 154.876553: rtcpu_string: tstamp:6210345323 id:0x04010000 str:"SW_RESET_0 = 00000003
kworker/3:6-283 [003] … 154.876556: rtcpu_string: tstamp:6210345978 id:0x04010000 str:“nvcsi_reset_lane_merger: NVCSI_PHY_0_LM_SW_RESET”
kworker/3:6-283 [003] … 154.876557: rtcpu_string: tstamp:6210346080 id:0x04010000 str:“0 = 00000001
kworker/3:6-283 [003] … 154.876560: rtcpu_string: tstamp:6210352102 id:0x04010000 str:“nvcsi_reset_lane_merger: NVCSI_PHY_0_LM_SW_RESET”
kworker/3:6-283 [003] … 154.876560: rtcpu_string: tstamp:6210352204 id:0x04010000 str:“0 = 00000000
kworker/3:6-283 [003] … 154.876563: rtcpu_string: tstamp:6210352765 id:0x04010000 str:"nvcsi_calc_ths_settle ths_settle 55
kworker/3:6-283 [003] … 154.876566: rtcpu_string: tstamp:6210353030 id:0x04010000 str:"nvcsi_calc_ths_settle ths_settle 55
kworker/3:6-283 [003] … 154.876569: rtcpu_string: tstamp:6210353292 id:0x04010000 str:"nvcsi_calc_ths_settle ths_settle 55
kworker/3:6-283 [003] … 154.876572: rtcpu_string: tstamp:6210353548 id:0x04010000 str:"nvcsi_calc_tclk_settle tclk_settle 75
kworker/3:6-283 [003] … 154.876574: rtcpu_string: tstamp:6210353991 id:0x04010000 str:"nvcsi_reset_data_lanes: NVCSI_PHY_0_NVCSI_CIL_A
kworker/3:6-283 [003] … 154.876575: rtcpu_string: tstamp:6210354094 id:0x04010000 str:"SW_RESET_0 = 00000000
kworker/3:6-283 [003] … 154.876578: rtcpu_string: tstamp:6210354449 id:0x04010000 str:"nvcsi_reset_data_lanes: NVCSI_PHY_0_NVCSI_CIL_B
kworker/3:6-283 [003] … 154.876579: rtcpu_string: tstamp:6210354567 id:0x04010000 str:"SW_RESET_0 = 00000000
kworker/3:6-283 [003] … 154.876584: rtcpu_vinotify_event: tstamp:6210617348 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:198729293888 data:0x799d580010000000
kworker/3:6-283 [003] … 154.876585: rtcpu_vinotify_event: tstamp:6210617488 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:198729300320 data:0x0000000031000001
kworker/3:6-283 [003] … 154.876586: rtcpu_vinotify_event: tstamp:6210617645 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:198729303328 data:0x0000000007020001
kworker/3:6-283 [003] … 154.876587: rtcpu_vinotify_event: tstamp:6210617780 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:198729350464 data:0x799d550010000000
kworker/3:6-283 [003] … 154.876587: rtcpu_vinotify_event: tstamp:6210617933 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:198729356960 data:0x0000000031000002
kworker/3:6-283 [003] … 155.160511: rtcpu_vinotify_error: tstamp:6219060735 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:199009917280 data:0x00000000000003c9
kworker/3:6-283 [003] … 155.160514: rtcpu_vinotify_event: tstamp:6219068392 cch:-1 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:199007633824 data:0x0000000000000010
kworker/3:6-283 [003] … 155.160515: rtcpu_vinotify_event: tstamp:6219068545 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:199009917280 data:0x00000000000003c9
kworker/3:6-283 [003] … 155.160516: rtcpu_vinotify_event: tstamp:6220082540 cch:-1 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:199034666464 data:0x0000000000000020
kworker/3:6-283 [003] … 155.160517: rtcpu_vinotify_event: tstamp:6220082698 cch:-1 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:199040966240 data:0x0000000000000010
kworker/3:6-283 [003] … 155.160517: rtcpu_vinotify_error: tstamp:6220102373 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:199043249696 data:0x00000000000003c9
kworker/3:6-283 [003] … 155.160519: rtcpu_vinotify_event: tstamp:6220420549 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:199043249696 data:0x00000000000003c9
kworker/3:6-283 [003] … 155.216676: rtcpu_vinotify_event: tstamp:6221096598 cch:-1 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:199067998784 data:0x0000000000000020
kworker/3:6-283 [003] … 155.216680: rtcpu_vinotify_event: tstamp:6221096732 cch:-1 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:199074298560 data:0x0000000000000010
kworker/3:6-283 [003] … 155.216682: rtcpu_vinotify_error: tstamp:6221144004 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:199076581984 data:0x00000000000003c9
kworker/3:6-283 [003] … 155.216683: rtcpu_vinotify_event: tstamp:6221434621 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:199076581984 data:0x00000000000003c9
kworker/3:6-283 [003] … 155.216685: rtcpu_vinotify_event: tstamp:6222110801 cch:-1 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:199101331296 data:0x0000000000000020
kworker/3:6-283 [003] … 155.216686: rtcpu_vinotify_error: tstamp:6222185634 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:199109914496 data:0x00000000000003c9
kworker/3:6-283 [003] … 155.216686: rtcpu_vinotify_event: tstamp:6222186111 cch:-1 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:199107631072 data:0x0000000000000010
kworker/3:6-283 [003] … 155.216687: rtcpu_vinotify_event: tstamp:6222186245 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:199109914496 data:0x00000000000003c9
kworker/3:6-283 [003] … 155.272687: rtcpu_vinotify_event: tstamp:6222989725 cch:-1 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:199134663584 data:0x0000000000000020
kworker/3:6-283 [003] … 155.272692: rtcpu_vinotify_error: tstamp:6223227283 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:199143246816 data:0x00000000000003c9
kworker/3:6-283 [003] … 155.272693: rtcpu_vinotify_event: tstamp:6223327740 cch:-1 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:199140963360 data:0x0000000000000010
kworker/3:6-283 [003] … 155.272694: rtcpu_vinotify_event: tstamp:6223327893 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:199143246816 data:0x00000000000003c9
kworker/3:6-283 [003] … 155.272694: rtcpu_vinotify_event: tstamp:6224003773 cch:-1 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:199167996032 data:0x0000000000000020
kworker/3:6-283 [003] … 155.328511: rtcpu_vinotify_error: tstamp:6224268924 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:199176579328 data:0x00000000000003c9
kworker/3:6-283 [003] … 155.328514: rtcpu_vinotify_event: tstamp:6224341816 cch:-1 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:199174295840 data:0x0000000000000010
kworker/3:6-283 [003] … 155.328515: rtcpu_vinotify_event: tstamp:6224341954 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:199176579328 data:0x00000000000003c9
kworker/3:6-283 [003] … 155.328516: rtcpu_vinotify_error: tstamp:6225310551 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:199209911616 data:0x00000000000003c9
kworker/3:6-283 [003] … 155.328517: rtcpu_vinotify_event: tstamp:6225356027 cch:-1 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:199201328384 data:0x0000000000000020
kworker/3:6-283 [003] … 155.328518: rtcpu_vinotify_event: tstamp:6225356161 cch:-1 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:199207628128 data:0x0000000000000010
kworker/3:6-283 [003] … 155.328518: rtcpu_vinotify_event: tstamp:6225356314 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:199209911616 data:0x00000000000003c9
kworker/3:6-283 [003] … 155.384498: rtcpu_vinotify_error: tstamp:6226352198 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:199243244064 data:0x00000000000003c9
kworker/3:6-283 [003] … 155.384501: rtcpu_vinotify_event: tstamp:6226370121 cch:-1 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:199234660704 data:0x0000000000000020
kworker/3:6-283 [003] … 155.384501: rtcpu_vinotify_event: tstamp:6226370272 cch:-1 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:199240960576 data:0x0000000000000010
kworker/3:6-283 [003] … 155.384502: rtcpu_vinotify_event: tstamp:6226370416 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:199243244064 data:0x00000000000003c9
kworker/3:6-283 [003] … 155.384503: rtcpu_vinotify_event: tstamp:6227384269 cch:-1 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:199267993152 data:0x0000000000000020
kworker/3:6-283 [003] … 155.384504: rtcpu_vinotify_event: tstamp:6227384402 cch:-1 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:199274292928 data:0x0000000000000010
kworker/3:6-283 [003] … 155.384505: rtcpu_vinotify_error: tstamp:6227393829 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:199276576384 data:0x00000000000003c9
kworker/3:6-283 [003] … 155.440674: rtcpu_vinotify_event: tstamp:6227722274 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:199276576384 data:0x00000000000003c9
kworker/3:6-283 [003] … 155.440678: rtcpu_vinotify_event: tstamp:6228167169 cch:-1 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:199301325472 data:0x0000000000000020
kworker/3:6-283 [003] … 155.440680: rtcpu_vinotify_error: tstamp:6228435467 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:199309908736 data:0x00000000000003c9
kworker/3:6-283 [003] … 155.440680: rtcpu_vinotify_event: tstamp:6228499803 cch:-1 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:199307625280 data:0x0000000000000010
kworker/3:6-283 [003] … 155.440681: rtcpu_vinotify_event: tstamp:6228499935 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:199309908736 data:0x00000000000003c9
kworker/3:6-283 [003] … 155.496686: rtcpu_vinotify_error: tstamp:6229477105 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:199343241184 data:0x00000000000003c9
kworker/3:6-283 [003] … 155.496691: rtcpu_vinotify_event: tstamp:6229513877 cch:-1 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:199334657984 data:0x0000000000000020
kworker/3:6-283 [003] … 155.496692: rtcpu_vinotify_event: tstamp:6229514008 cch:-1 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:199340957760 data:0x0000000000000010
kworker/3:6-283 [003] … 155.496693: rtcpu_vinotify_event: tstamp:6229514157 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:199343241184 data:0x00000000000003c9
kworker/3:6-283 [003] … 155.496694: rtcpu_vinotify_error: tstamp:6230518741 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:199376573504 data:0x00000000000003c9
kworker/3:6-283 [003] … 155.496695: rtcpu_vinotify_event: tstamp:6230528111 cch:-1 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:199367990272 data:0x0000000000000020
kworker/3:6-283 [003] … 155.496696: rtcpu_vinotify_event: tstamp:6230528261 cch:-1 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:199374290048 data:0x0000000000000010
kworker/3:6-283 [003] … 155.496697: rtcpu_vinotify_event: tstamp:6230528395 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:199376573504 data:0x00000000000003c9
kworker/3:6-283 [003] … 155.552687: rtcpu_vinotify_event: tstamp:6231542238 cch:-1 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:199401322784 data:0x0000000000000020
kworker/3:6-283 [003] … 155.552690: rtcpu_vinotify_event: tstamp:6231542373 cch:-1 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:199407622528 data:0x0000000000000010
kworker/3:6-283 [003] … 155.552693: rtcpu_vinotify_error: tstamp:6231560381 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:199409905984 data:0x00000000000003c9
kworker/3:6-283 [003] … 155.552693: rtcpu_vinotify_event: tstamp:6231880254 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:199409905984 data:0x00000000000003c9
kworker/3:6-283 [003] … 155.552694: rtcpu_vinotify_event: tstamp:6232556325 cch:-1 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:199434655104 data:0x0000000000000020
kworker/3:6-283 [003] … 155.552695: rtcpu_vinotify_event: tstamp:6232556478 cch:-1 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:199440954848 data:0x0000000000000010
kworker/3:6-283 [003] … 155.552695: rtcpu_vinotify_error: tstamp:6232602016 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:199443238304 data:0x00000000000003c9
kworker/3:6-283 [003] … 155.608685: rtcpu_vinotify_event: tstamp:6232894332 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:199443238304 data:0x00000000000003c9
kworker/3:6-283 [003] … 155.608689: rtcpu_vinotify_event: tstamp:6233570516 cch:-1 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:199467987520 data:0x0000000000000020
kworker/3:6-283 [003] … 155.608690: rtcpu_vinotify_event: tstamp:6233572228 cch:-1 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:199474287328 data:0x0000000000000010
kworker/3:6-283 [003] … 155.608693: rtcpu_vinotify_error: tstamp:6233643655 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:199476570784 data:0x00000000000003c9
kworker/3:6-283 [003] … 155.608693: rtcpu_vinotify_event: tstamp:6233908454 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:199476570784 data:0x00000000000003c9
kworker/3:6-283 [003] … 155.664678: rtcpu_vinotify_event: tstamp:6234584641 cch:-1 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:199501319872 data:0x0000000000000020
kworker/3:6-283 [003] … 155.664683: rtcpu_vinotify_error: tstamp:6234685294 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:199509903104 data:0x00000000000003c9
kworker/3:6-283 [003] … 155.664684: rtcpu_vinotify_event: tstamp:6234922683 cch:-1 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:199507619616 data:0x0000000000000010
kworker/3:6-283 [003] … 155.664685: rtcpu_vinotify_event: tstamp:6234922815 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:199509903104 data:0x00000000000003c9
kworker/3:6-283 [003] … 155.664686: rtcpu_vinotify_event: tstamp:6235598720 cch:-1 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:199534652192 data:0x0000000000000020
kworker/3:6-283 [003] … 155.664687: rtcpu_vinotify_error: tstamp:6235726928 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:199543235552 data:0x00000000000003c9
kworker/3:6-283 [003] … 155.664688: rtcpu_vinotify_event: tstamp:6235936762 cch:-1 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:199540952096 data:0x0000000000000010
kworker/3:6-283 [003] … 155.664689: rtcpu_vinotify_event: tstamp:6235936914 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:199543235552 data:0x00000000000003c9
kworker/3:6-283 [003] … 155.720687: rtcpu_vinotify_event: tstamp:6236612802 cch:-1 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:199567984672 data:0x0000000000000020
kworker/3:6-283 [003] … 155.720692: rtcpu_vinotify_error: tstamp:6236768562 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:199576567872 data:0x00000000000003c9
kworker/3:6-283 [003] … 155.720693: rtcpu_vinotify_event: tstamp:6236950840 cch:-1 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:199574284448 data:0x0000000000000010
kworker/3:6-283 [003] … 155.720694: rtcpu_vinotify_event: tstamp:6236950975 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:199576567872 data:0x00000000000003c9
kworker/3:6-283 [003] … 155.720695: rtcpu_vinotify_event: tstamp:6237627028 cch:-1 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:199601316960 data:0x0000000000000020
kworker/3:6-283 [003] … 155.720696: rtcpu_vinotify_error: tstamp:6237810202 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:199609900224 data:0x00000000000003c9
kworker/3:6-283 [003] … 155.720697: rtcpu_vinotify_event: tstamp:6237965071 cch:-1 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:199607616800 data:0x0000000000000010
kworker/3:6-283 [003] … 155.720698: rtcpu_vinotify_event: tstamp:6237965224 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:199609900224 data:0x00000000000003c9
kworker/3:6-283 [003] … 155.776681: rtcpu_vinotify_event: tstamp:6238641102 cch:-1 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:199634649472 data:0x0000000000000020
kworker/3:6-283 [003] … 155.776686: rtcpu_vinotify_error: tstamp:6238851823 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:199643232704 data:0x00000000000003c9
kworker/3:6-283 [003] … 155.776687: rtcpu_vinotify_event: tstamp:6238852313 cch:-1 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:199640949248 data:0x0000000000000010
kworker/3:6-283 [003] … 155.776688: rtcpu_vinotify_event: tstamp:6238852448 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:199643232704 data:0x00000000000003c9
kworker/3:6-283 [003] … 155.776691: rtcpu_vinotify_event: tstamp:6239655219 cch:-1 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:199667981792 data:0x0000000000000020
kworker/3:6-283 [003] … 155.832684: rtcpu_vinotify_error: tstamp:6239893475 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:199676564992 data:0x00000000000003c9
kworker/3:6-283 [003] … 155.832688: rtcpu_vinotify_event: tstamp:6239993257 cch:-1 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:199674281568 data:0x0000000000000010
kworker/3:6-283 [003] … 155.832689: rtcpu_vinotify_event: tstamp:6239993410 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:199676564992 data:0x00000000000003c9
kworker/3:6-283 [003] … 155.832691: rtcpu_vinotify_event: tstamp:6240669441 cch:-1 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:199701314272 data:0x0000000000000020
kworker/3:6-283 [003] … 155.832692: rtcpu_vinotify_error: tstamp:6240935115 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:199709897504 data:0x00000000000003c9
kworker/3:6-283 [003] … 155.832693: rtcpu_vinotify_event: tstamp:6241007484 cch:-1 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:199707614016 data:0x0000000000000010
kworker/3:6-283 [003] … 155.832694: rtcpu_vinotify_event: tstamp:6241007618 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:199709897504 data:0x00000000000003c9
kworker/3:6-283 [003] … 155.888514: rtcpu_vinotify_error: tstamp:6241976748 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:199743229792 data:0x00000000000003c9
kworker/3:6-283 [003] … 155.888518: rtcpu_vinotify_event: tstamp:6242021561 cch:-1 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:199734646592 data:0x0000000000000020
kworker/3:6-283 [003] … 155.888519: rtcpu_vinotify_event: tstamp:6242021704 cch:-1 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:199740946336 data:0x0000000000000010
kworker/3:6-283 [003] … 155.888520: rtcpu_vinotify_event: tstamp:6242021854 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:199743229792 data:0x00000000000003c9
kworker/3:6-283 [003] … 155.888521: rtcpu_vinotify_error: tstamp:6243018392 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:199776562272 data:0x00000000000003c9
kworker/3:6-283 [003] … 155.888522: rtcpu_vinotify_event: tstamp:6243035644 cch:-1 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:199767979040 data:0x0000000000000020
kworker/3:6-283 [003] … 155.888523: rtcpu_vinotify_event: tstamp:6243035796 cch:-1 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:199774278848 data:0x0000000000000010
kworker/3:6-283 [003] … 155.888523: rtcpu_vinotify_event: tstamp:6243035927 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:199776562272 data:0x00000000000003c9
kworker/3:6-283 [003] … 155.944489: rtcpu_vinotify_event: tstamp:6244049799 cch:-1 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:199801311360 data:0x0000000000000020
kworker/3:6-283 [003] … 155.944490: rtcpu_vinotify_event: tstamp:6244049933 cch:-1 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:199807611136 data:0x0000000000000010
kworker/3:6-283 [003] … 155.944490: rtcpu_vinotify_error: tstamp:6244060025 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:199809894592 data:0x00000000000003c9
kworker/3:6-283 [003] … 155.944491: rtcpu_vinotify_event: tstamp:6244387953 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:199809894592 data:0x00000000000003c9
kworker/3:6-283 [003] … 155.944491: rtcpu_vinotify_event: tstamp:6244833401 cch:-1 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:199834643712 data:0x0000000000000020
kworker/3:6-283 [003] … 156.000496: rtcpu_vinotify_error: tstamp:6245101655 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:199843227040 data:0x00000000000003c9
kworker/3:6-283 [003] … 156.000499: rtcpu_vinotify_event: tstamp:6245165307 cch:-1 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:199840943584 data:0x0000000000000010
kworker/3:6-283 [003] … 156.000500: rtcpu_vinotify_event: tstamp:6245165442 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:199843227040 data:0x00000000000003c9
kworker/3:6-283 [003] … 156.000501: rtcpu_vinotify_error: tstamp:6246143297 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:199876559392 data:0x00000000000003c9
kworker/3:6-283 [003] … 156.000501: rtcpu_vinotify_event: tstamp:6246179553 cch:-1 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:199867976192 data:0x0000000000000020
kworker/3:6-283 [003] … 156.000502: rtcpu_vinotify_event: tstamp:6246179686 cch:-1 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:199874275968 data:0x0000000000000010
kworker/3:6-283 [003] … 156.000502: rtcpu_vinotify_event: tstamp:6246179837 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:199876559392 data:0x00000000000003c9
kworker/3:6-283 [003] … 156.056495: rtcpu_vinotify_error: tstamp:6247184934 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:199909891744 data:0x00000000000003c9
kworker/3:6-283 [003] … 156.056497: rtcpu_vinotify_event: tstamp:6247193628 cch:-1 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:199901308480 data:0x0000000000000020
kworker/3:6-283 [003] … 156.056498: rtcpu_vinotify_event: tstamp:6247193790 cch:-1 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:199907608256 data:0x0000000000000010
kworker/3:6-283 [003] … 156.056498: rtcpu_vinotify_event: tstamp:6247193925 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:199909891744 data:0x00000000000003c9
kworker/3:6-283 [003] … 156.056499: rtcpu_vinotify_event: tstamp:6248207781 cch:-1 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:199934640992 data:0x0000000000000020
kworker/3:6-283 [003] … 156.056500: rtcpu_vinotify_event: tstamp:6248207919 cch:-1 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:199940940736 data:0x0000000000000010
kworker/3:6-283 [003] … 156.056500: rtcpu_vinotify_error: tstamp:6248226570 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:199943224224 data:0x00000000000003c9
kworker/3:6-283 [003] … 156.056501: rtcpu_vinotify_event: tstamp:6248545788 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:199943224224 data:0x00000000000003c9
kworker/3:6-283 [003] … 156.112680: rtcpu_vinotify_event: tstamp:6249221862 cch:-1 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:199967973280 data:0x0000000000000020
kworker/3:6-283 [003] … 156.112684: rtcpu_vinotify_event: tstamp:6249222015 cch:-1 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:199974273024 data:0x0000000000000010
kworker/3:6-283 [003] … 156.112686: rtcpu_vinotify_error: tstamp:6249268209 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:199976556512 data:0x00000000000003c9
kworker/3:6-283 [003] … 156.112686: rtcpu_vinotify_event: tstamp:6249560017 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:199976556512 data:0x00000000000003c9
kworker/3:6-283 [003] … 156.112687: rtcpu_vinotify_event: tstamp:6250236052 cch:-1 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:200001305760 data:0x0000000000000020
kworker/3:6-283 [003] … 156.112688: rtcpu_vinotify_event: tstamp:6250238419 cch:-1 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:200007605536 data:0x0000000000000010
kworker/3:6-283 [003] … 156.112689: rtcpu_vinotify_error: tstamp:6250309848 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:200009888992 data:0x00000000000003c9
kworker/3:6-283 [003] … 156.168686: rtcpu_vinotify_event: tstamp:6250574125 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:200009888992 data:0x00000000000003c9
kworker/3:6-283 [003] … 156.168690: rtcpu_vinotify_event: tstamp:6251250154 cch:-1 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:200034638080 data:0x0000000000000020
kworker/3:6-283 [003] … 156.168692: rtcpu_vinotify_error: tstamp:6251351487 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:200043221280 data:0x00000000000003c9
kworker/3:6-283 [003] … 156.168694: rtcpu_vinotify_event: tstamp:6251588200 cch:-1 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:200040937856 data:0x0000000000000010
kworker/3:6-283 [003] … 156.168695: rtcpu_vinotify_event: tstamp:6251588334 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:200043221280 data:0x00000000000003c9
kworker/3:6-283 [003] … 156.224689: rtcpu_vinotify_event: tstamp:6252264234 cch:-1 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:200067970528 data:0x0000000000000020
kworker/3:6-283 [003] … 156.224693: rtcpu_vinotify_error: tstamp:6252393125 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:200076553792 data:0x00000000000003c9
kworker/3:6-283 [003] … 156.224694: rtcpu_vinotify_event: tstamp:6252602286 cch:-1 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:200074270368 data:0x0000000000000010
kworker/3:6-283 [003] … 156.224695: rtcpu_vinotify_event: tstamp:6252602436 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:200076553792 data:0x00000000000003c9
kworker/3:6-283 [003] … 156.224696: rtcpu_vinotify_event: tstamp:6253278475 cch:-1 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:200101302880 data:0x0000000000000020
kworker/3:6-283 [003] … 156.224697: rtcpu_vinotify_error: tstamp:6253434758 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:200109886112 data:0x00000000000003c9
kworker/3:6-283 [003] … 156.224697: rtcpu_vinotify_event: tstamp:6253616517 cch:-1 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:200107602656 data:0x0000000000000010
kworker/3:6-283 [003] … 156.224698: rtcpu_vinotify_event: tstamp:6253616649 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:200109886112 data:0x00000000000003c9
kworker/3:6-283 [003] … 156.280679: rtcpu_vinotify_event: tstamp:6254292561 cch:-1 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:200134635232 data:0x0000000000000020
kworker/3:6-283 [003] … 156.280684: rtcpu_vinotify_error: tstamp:6254476399 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:200143218560 data:0x00000000000003c9
kworker/3:6-283 [003] … 156.280685: rtcpu_vinotify_event: tstamp:6254630607 cch:-1 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:200140935104 data:0x0000000000000010
kworker/3:6-283 [003] … 156.280685: rtcpu_vinotify_event: tstamp:6254630761 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:200143218560 data:0x00000000000003c9
kworker/3:6-283 [003] … 156.280686: rtcpu_vinotify_event: tstamp:6255306792 cch:-1 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:200167967680 data:0x0000000000000020
kworker/3:6-283 [003] … 156.280687: rtcpu_vinotify_error: tstamp:6255518019 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:200176550912 data:0x00000000000003c9
kworker/3:6-283 [003] … 156.280688: rtcpu_vinotify_event: tstamp:6255518510 cch:-1 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:200174267424 data:0x0000000000000010
kworker/3:6-283 [003] … 156.280688: rtcpu_vinotify_event: tstamp:6255518657 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:200176550912 data:0x00000000000003c9
kworker/3:6-283 [003] … 156.336514: rtcpu_vinotify_event: tstamp:6256320882 cch:-1 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:200201300000 data:0x0000000000000020
kworker/3:6-283 [003] … 156.336518: rtcpu_vinotify_error: tstamp:6256559664 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:200209883232 data:0x00000000000003c9
kworker/3:6-283 [003] … 156.336519: rtcpu_vinotify_event: tstamp:6256658921 cch:-1 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:200207599776 data:0x0000000000000010
kworker/3:6-283 [003] … 156.336520: rtcpu_vinotify_event: tstamp:6256659074 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:200209883232 data:0x00000000000003c9
kworker/3:6-283 [003] … 156.392501: rtcpu_vinotify_event: tstamp:6257334978 cch:-1 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:200234632480 data:0x0000000000000020
kworker/3:6-283 [003] … 156.392503: rtcpu_vinotify_error: tstamp:6257601307 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:200243215712 data:0x00000000000003c9
kworker/3:6-283 [003] … 156.392504: rtcpu_vinotify_event: tstamp:6257673060 cch:-1 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:200240932256 data:0x0000000000000010
kworker/3:6-283 [003] … 156.392505: rtcpu_vinotify_event: tstamp:6257673196 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:200243215712 data:0x00000000000003c9
kworker/3:6-283 [003] … 156.392505: rtcpu_vinotify_error: tstamp:6258642942 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:200276548000 data:0x00000000000003c9
kworker/3:6-283 [003] … 156.392506: rtcpu_vinotify_event: tstamp:6258687093 cch:-1 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:200267964768 data:0x0000000000000020
kworker/3:6-283 [003] … 156.392507: rtcpu_vinotify_event: tstamp:6258687225 cch:-1 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:200274264544 data:0x0000000000000010
kworker/3:6-283 [003] … 156.392507: rtcpu_vinotify_event: tstamp:6258687374 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:200276548000 data:0x00000000000003c9
kworker/3:6-283 [003] … 156.448684: rtcpu_vinotify_error: tstamp:6259684585 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:200309880512 data:0x00000000000003c9
kworker/3:6-283 [003] … 156.448689: rtcpu_vinotify_event: tstamp:6259701320 cch:-1 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:200301297280 data:0x0000000000000020
kworker/3:6-283 [003] … 156.448690: rtcpu_vinotify_event: tstamp:6259701469 cch:-1 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:200307597056 data:0x0000000000000010
kworker/3:6-283 [003] … 156.448690: rtcpu_vinotify_event: tstamp:6259701600 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:200309880512 data:0x00000000000003c9
kworker/3:6-283 [003] … 156.448692: rtcpu_vinotify_event: tstamp:6260715472 cch:-1 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:200334629600 data:0x0000000000000020
kworker/3:6-283 [003] … 156.448692: rtcpu_vinotify_event: tstamp:6260715606 cch:-1 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:200340929376 data:0x0000000000000010
kworker/3:6-283 [003] … 156.448693: rtcpu_vinotify_error: tstamp:6260726216 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:200343212800 data:0x00000000000003c9
kworker/3:6-283 [003] … 156.504686: rtcpu_vinotify_event: tstamp:6261053483 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:200343212800 data:0x00000000000003c9
kworker/3:6-283 [003] … 156.504690: rtcpu_vinotify_event: tstamp:6261499563 cch:-1 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:200367962048 data:0x0000000000000020
kworker/3:6-283 [003] … 156.504693: rtcpu_vinotify_error: tstamp:6261767862 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:200376545312 data:0x00000000000003c9
kworker/3:6-283 [003] … 156.504694: rtcpu_vinotify_event: tstamp:6261831008 cch:-1 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:200374261856 data:0x0000000000000010
kworker/3:6-283 [003] … 156.504694: rtcpu_vinotify_event: tstamp:6261831142 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:200376545312 data:0x00000000000003c9
kworker/3:6-283 [003] … 156.560683: rtcpu_vinotify_error: tstamp:6262809497 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:200409877632 data:0x00000000000003c9
kworker/3:6-283 [003] … 156.560688: rtcpu_vinotify_event: tstamp:6262845084 cch:-1 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:200401294400 data:0x0000000000000020
kworker/3:6-283 [003] … 156.560688: rtcpu_vinotify_event: tstamp:6262845219 cch:-1 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:200407594144 data:0x0000000000000010
kworker/3:6-283 [003] … 156.560689: rtcpu_vinotify_event: tstamp:6262845376 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:200409877632 data:0x00000000000003c9
kworker/3:6-283 [003] … 156.560690: rtcpu_vinotify_error: tstamp:6263851133 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:200443210080 data:0x00000000000003c9
kworker/3:6-283 [003] … 156.560691: rtcpu_vinotify_event: tstamp:6263859162 cch:-1 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:200434626720 data:0x0000000000000020
kworker/3:6-283 [003] … 156.560691: rtcpu_vinotify_event: tstamp:6263859315 cch:-1 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:200440926624 data:0x0000000000000010
kworker/3:6-283 [003] … 156.560692: rtcpu_vinotify_event: tstamp:6263859453 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:200443210080 data:0x00000000000003c9
kworker/3:6-283 [003] … 156.616685: rtcpu_vinotify_event: tstamp:6264873305 cch:-1 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:200467959200 data:0x0000000000000020
kworker/3:6-283 [003] … 156.616689: rtcpu_vinotify_event: tstamp:6264873440 cch:-1 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:200474258976 data:0x0000000000000010
kworker/3:6-283 [003] … 156.616691: rtcpu_vinotify_error: tstamp:6264892767 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:200476542400 data:0x00000000000003c9
kworker/3:6-283 [003] … 156.616692: rtcpu_vinotify_event: tstamp:6265211464 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:200476542400 data:0x00000000000003c9
kworker/3:6-283 [003] … 156.616694: rtcpu_vinotify_event: tstamp:6265887538 cch:-1 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:200501291488 data:0x0000000000000020
kworker/3:6-283 [003] … 156.616694: rtcpu_vinotify_event: tstamp:6265887689 cch:-1 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:200507591296 data:0x0000000000000010
kworker/3:6-283 [003] … 156.616695: rtcpu_vinotify_error: tstamp:6265934405 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:200509874752 data:0x00000000000003c9
kworker/3:6-283 [003] … 156.672686: rtcpu_vinotify_event: tstamp:6266225552 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:200509874752 data:0x00000000000003c9
kworker/3:6-283 [003] … 156.672690: rtcpu_vinotify_event: tstamp:6266901587 cch:-1 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:200534624000 data:0x0000000000000020
kworker/3:6-283 [003] … 156.672691: rtcpu_vinotify_event: tstamp:6266904612 cch:-1 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:200540923776 data:0x0000000000000010
kworker/3:6-283 [003] … 156.672693: rtcpu_vinotify_error: tstamp:6266976043 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:200543207232 data:0x00000000000003c9
kworker/3:6-283 [003] … 156.672694: rtcpu_vinotify_event: tstamp:6267239690 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:200543207232 data:0x00000000000003c9
kworker/3:6-283 [003] … 156.728685: rtcpu_vinotify_event: tstamp:6267915705 cch:-1 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:200567956320 data:0x0000000000000020
kworker/3:6-283 [003] … 156.728691: rtcpu_vinotify_error: tstamp:6268017680 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:200576539520 data:0x00000000000003c9
kworker/3:6-283 [003] … 156.728692: rtcpu_vinotify_event: tstamp:6268253745 cch:-1 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:200574256096 data:0x0000000000000010
kworker/3:6-283 [003] … 156.728693: rtcpu_vinotify_event: tstamp:6268253878 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:200576539520 data:0x00000000000003c9
kworker/3:6-283 [003] … 156.728693: rtcpu_vinotify_event: tstamp:6268929930 cch:-1 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:200601288832 data:0x0000000000000020
kworker/3:6-283 [003] … 156.728695: rtcpu_vinotify_error: tstamp:6269059323 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:200609872032 data:0x00000000000003c9
kworker/3:6-283 [003] … 156.728696: rtcpu_vinotify_event: tstamp:6269267977 cch:-1 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:200607588576 data:0x0000000000000010
kworker/3:6-283 [003] … 156.728697: rtcpu_vinotify_event: tstamp:6269268130 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:200609872032 data:0x00000000000003c9
kworker/3:6-283 [003] … 156.784682: rtcpu_vinotify_event: tstamp:6269944000 cch:-1 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:200634621120 data:0x0000000000000020
kworker/3:6-283 [003] … 156.784687: rtcpu_vinotify_error: tstamp:6270100954 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:200643204352 data:0x00000000000003c9
kworker/3:6-283 [003] … 156.784688: rtcpu_vinotify_event: tstamp:6270282044 cch:-1 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:200640920864 data:0x0000000000000010
kworker/3:6-283 [003] … 156.784689: rtcpu_vinotify_event: tstamp:6270282181 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:200643204352 data:0x00000000000003c9
kworker/3:6-283 [003] … 156.784690: rtcpu_vinotify_event: tstamp:6270958108 cch:-1 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:200667953568 data:0x0000000000000020
kworker/3:6-283 [003] … 156.784691: rtcpu_vinotify_error: tstamp:6271142593 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:200676536832 data:0x00000000000003c9
kworker/3:6-283 [003] … 156.784691: rtcpu_vinotify_event: tstamp:6271296123 cch:-1 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:200674253376 data:0x0000000000000010
kworker/3:6-283 [003] … 156.784693: rtcpu_vinotify_event: tstamp:6271296329 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:200676536832 data:0x00000000000003c9
kworker/3:6-283 [003] … 156.840686: rtcpu_vinotify_event: tstamp:6271972317 cch:-1 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:200701285920 data:0x0000000000000020
kworker/3:6-283 [003] … 156.840691: rtcpu_vinotify_error: tstamp:6272184213 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:200709869152 data:0x00000000000003c9
kworker/3:6-283 [003] … 156.840692: rtcpu_vinotify_event: tstamp:6272184703 cch:-1 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:200707585696 data:0x0000000000000010
kworker/3:6-283 [003] … 156.840693: rtcpu_vinotify_event: tstamp:6272184838 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:200709869152 data:0x00000000000003c9
kworker/3:6-283 [003] … 156.840694: rtcpu_vinotify_event: tstamp:6272986432 cch:-1 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:200734618272 data:0x0000000000000020
kworker/3:6-283 [003] … 156.896513: rtcpu_vinotify_error: tstamp:6273225870 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:200743201600 data:0x00000000000003c9
kworker/3:6-283 [003] … 156.896517: rtcpu_vinotify_event: tstamp:6273324459 cch:-1 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:200740918144 data:0x0000000000000010
kworker/3:6-283 [003] … 156.896518: rtcpu_vinotify_event: tstamp:6273324612 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:200743201600 data:0x00000000000003c9
kworker/3:6-283 [003] … 156.896519: rtcpu_vinotify_event: tstamp:6274000495 cch:-1 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:200767950720 data:0x0000000000000020
kworker/3:6-283 [003] … 156.896520: rtcpu_vinotify_error: tstamp:6274267508 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:200776533952 data:0x00000000000003c9
kworker/3:6-283 [003] … 156.896521: rtcpu_vinotify_event: tstamp:6274338540 cch:-1 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:200774250496 data:0x0000000000000010
kworker/3:6-283 [003] … 156.896521: rtcpu_vinotify_event: tstamp:6274338683 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:200776533952 data:0x00000000000003c9
kworker/3:6-283 [003] … 156.952688: rtcpu_vinotify_error: tstamp:6275309140 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:200809866304 data:0x00000000000003c9
kworker/3:6-283 [003] … 156.952692: rtcpu_vinotify_event: tstamp:6275352776 cch:-1 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:200801283040 data:0x0000000000000020
kworker/3:6-283 [003] … 156.952693: rtcpu_vinotify_event: tstamp:6275352910 cch:-1 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:200807582848 data:0x0000000000000010
kworker/3:6-283 [003] … 156.952694: rtcpu_vinotify_event: tstamp:6275353060 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:200809866304 data:0x00000000000003c9
kworker/3:6-283 [003] … 156.952694: rtcpu_vinotify_error: tstamp:6276350779 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:200843198752 data:0x00000000000003c9
kworker/3:6-283 [003] … 156.952695: rtcpu_vinotify_event: tstamp:6276366852 cch:-1 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:200834615552 data:0x0000000000000020
kworker/3:6-283 [003] … 156.952696: rtcpu_vinotify_event: tstamp:6276367002 cch:-1 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:200840915296 data:0x0000000000000010
kworker/3:6-283 [003] … 156.952697: rtcpu_vinotify_event: tstamp:6276367143 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:200843198752 data:0x00000000000003c9
kworker/3:6-283 [003] … 157.008676: rtcpu_vinotify_event: tstamp:6277381004 cch:-1 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:200867947840 data:0x0000000000000020
kworker/3:6-283 [003] … 157.008680: rtcpu_vinotify_event: tstamp:6277381137 cch:-1 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:200874247616 data:0x0000000000000010
kworker/3:6-283 [003] … 157.008682: rtcpu_vinotify_error: tstamp:6277392413 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:200876531072 data:0x00000000000003c9
kworker/3:6-283 [003] … 157.008683: rtcpu_vinotify_event: tstamp:6277719013 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:200876531072 data:0x00000000000003c9
kworker/3:6-283 [003] … 157.008684: rtcpu_vinotify_event: tstamp:6278165760 cch:-1 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:200901280352 data:0x0000000000000020
kworker/3:6-283 [003] … 157.064684: rtcpu_vinotify_error: tstamp:6278434055 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:200909863552 data:0x00000000000003c9
kworker/3:6-283 [003] … 157.064689: rtcpu_vinotify_event: tstamp:6278496533 cch:-1 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:200907580128 data:0x0000000000000010
kworker/3:6-283 [003] … 157.064691: rtcpu_vinotify_event: tstamp:6278496668 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:200909863552 data:0x00000000000003c9
kworker/3:6-283 [003] … 157.064692: rtcpu_vinotify_error: tstamp:6279475690 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:200943195872 data:0x00000000000003c9
kworker/3:6-283 [003] … 157.064693: rtcpu_vinotify_event: tstamp:6279510611 cch:-1 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:200934612640 data:0x0000000000000020
kworker/3:6-283 [003] … 157.064694: rtcpu_vinotify_event: tstamp:6279510744 cch:-1 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:200940912416 data:0x0000000000000010
kworker/3:6-283 [003] … 157.064695: rtcpu_vinotify_event: tstamp:6279510896 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:200943195872 data:0x00000000000003c9
kworker/3:6-283 [003] … 157.120686: rtcpu_vinotify_error: tstamp:6280517330 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:200976528384 data:0x00000000000003c9
kworker/3:6-283 [003] … 157.120691: rtcpu_vinotify_event: tstamp:6280524842 cch:-1 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:200967945088 data:0x0000000000000020
kworker/3:6-283 [003] … 157.120692: rtcpu_vinotify_event: tstamp:6280524994 cch:-1 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:200974244928 data:0x0000000000000010
kworker/3:6-283 [003] … 157.120692: rtcpu_vinotify_event: tstamp:6280525130 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:200976528384 data:0x00000000000003c9
kworker/3:6-283 [003] … 157.120694: rtcpu_vinotify_event: tstamp:6281538992 cch:-1 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:201001277472 data:0x0000000000000020
kworker/3:6-283 [003] … 157.120694: rtcpu_vinotify_event: tstamp:6281539130 cch:-1 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:201007577216 data:0x0000000000000010
kworker/3:6-283 [003] … 157.120695: rtcpu_vinotify_error: tstamp:6281558964 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:201009860704 data:0x00000000000003c9
kworker/3:6-283 [003] … 157.176488: rtcpu_vinotify_event: tstamp:6281876996 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:201009860704 data:0x00000000000003c9
kworker/3:6-283 [003] … 157.176490: rtcpu_vinotify_event: tstamp:6282553071 cch:-1 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:201034609792 data:0x0000000000000020
kworker/3:6-283 [003] … 157.176490: rtcpu_vinotify_event: tstamp:6282553222 cch:-1 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:201040909664 data:0x0000000000000010
kworker/3:6-283 [003] … 157.176491: rtcpu_vinotify_error: tstamp:6282600608 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:201043193152 data:0x00000000000003c9
kworker/3:6-283 [003] … 157.176492: rtcpu_vinotify_event: tstamp:6282891075 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:201043193152 data:0x00000000000003c9
kworker/3:6-283 [003] … 157.232680: rtcpu_vinotify_event: tstamp:6283567256 cch:-1 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:201067942272 data:0x0000000000000020
kworker/3:6-283 [003] … 157.232684: rtcpu_vinotify_event: tstamp:6283570809 cch:-1 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:201074242048 data:0x0000000000000010
kworker/3:6-283 [003] … 157.232686: rtcpu_vinotify_error: tstamp:6283642239 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:201076525472 data:0x00000000000003c9
kworker/3:6-283 [003] … 157.232687: rtcpu_vinotify_event: tstamp:6283905187 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:201076525472 data:0x00000000000003c9
kworker/3:6-283 [003] … 157.232688: rtcpu_vinotify_event: tstamp:6284581373 cch:-1 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:201101274560 data:0x0000000000000020
kworker/3:6-283 [003] … 157.232689: rtcpu_vinotify_error: tstamp:6284683873 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:201109857824 data:0x00000000000003c9
kworker/3:6-283 [003] … 157.232689: rtcpu_vinotify_event: tstamp:6284919413 cch:-1 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:201107574400 data:0x0000000000000010
kworker/3:6-283 [003] … 157.232690: rtcpu_vinotify_event: tstamp:6284919546 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:201109857824 data:0x00000000000003c9
kworker/3:6-283 [003] … 157.288684: rtcpu_vinotify_event: tstamp:6285595455 cch:-1 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:201134607072 data:0x0000000000000020
kworker/3:6-283 [003] … 157.288689: rtcpu_vinotify_error: tstamp:6285725515 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:201143190304 data:0x00000000000003c9
kworker/3:6-283 [003] … 157.288690: rtcpu_vinotify_event: tstamp:6285933497 cch:-1 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:201140906848 data:0x0000000000000010
kworker/3:6-283 [003] … 157.288691: rtcpu_vinotify_event: tstamp:6285933650 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:201143190304 data:0x00000000000003c9
kworker/3:6-283 [003] … 157.288692: rtcpu_vinotify_event: tstamp:6286609686 cch:-1 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:201167939392 data:0x0000000000000020
kworker/3:6-283 [003] … 157.288693: rtcpu_vinotify_error: tstamp:6286767151 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:201176522624 data:0x00000000000003c9
kworker/3:6-283 [003] … 157.288694: rtcpu_vinotify_event: tstamp:6286947715 cch:-1 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:201174239168 data:0x0000000000000010
kworker/3:6-283 [003] … 157.288695: rtcpu_vinotify_event: tstamp:6286947850 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:201176522624 data:0x00000000000003c9
kworker/3:6-283 [003] … 157.344510: rtcpu_vinotify_event: tstamp:6287623741 cch:-1 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:201201271904 data:0x0000000000000020
kworker/3:6-283 [003] … 157.344514: rtcpu_vinotify_error: tstamp:6287808782 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:201209855136 data:0x00000000000003c9
kworker/3:6-283 [003] … 157.344514: rtcpu_vinotify_event: tstamp:6287961796 cch:-1 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:201207571648 data:0x0000000000000010
kworker/3:6-283 [003] … 157.344515: rtcpu_vinotify_event: tstamp:6287961952 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:201209855136 data:0x00000000000003c9
kworker/3:6-283 [003] … 157.344516: rtcpu_vinotify_event: tstamp:6288637832 cch:-1 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:201234604224 data:0x0000000000000020
kworker/3:6-283 [003] … 157.400499: rtcpu_vinotify_error: tstamp:6288850411 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:201243187424 data:0x00000000000003c9
kworker/3:6-283 [003] … 157.400501: rtcpu_vinotify_event: tstamp:6288850905 cch:-1 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:201240903936 data:0x0000000000000010
kworker/3:6-283 [003] … 157.400502: rtcpu_vinotify_event: tstamp:6288851037 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:201243187424 data:0x00000000000003c9
kworker/3:6-283 [003] … 157.400503: rtcpu_vinotify_event: tstamp:6289651953 cch:-1 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:201267936672 data:0x0000000000000020
kworker/3:6-283 [003] … 157.400503: rtcpu_vinotify_error: tstamp:6289892064 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:201276519904 data:0x00000000000003c9
kworker/3:6-283 [003] … 157.400504: rtcpu_vinotify_event: tstamp:6289989991 cch:-1 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:201274236480 data:0x0000000000000010
kworker/3:6-283 [003] … 157.400504: rtcpu_vinotify_event: tstamp:6289990141 cch:-1 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:201276519904 data:0x00000000000003c9
vi-output, ar02-2370 [002] … 157.405473: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1300 fmt 10
kworker/3:6-283 [003] … 157.456505: rtcpu_vinotify_event: tstamp:6290666176 cch:-1 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:201301268992 data:0x0000000000000020
grab_camera-2368 [001] … 157.789256: tegra_channel_close: vi-output, ar0234 2-0033
grab_camera-2368 [001] … 157.789473: tegra_channel_set_stream: enable : 0x0
grab_camera-2368 [001] … 157.789474: tegra_channel_set_stream: ar0234 2-0033 : 0x0
grab_camera-2368 [001] … 157.896509: tegra_channel_set_stream: 13e00000.host1x:nvcsi@15a00000- : 0x0
grab_camera-2368 [001] … 157.896514: csi_s_stream: enable : 0x0
grab_camera-2368 [000] … 157.899289: tegra_channel_set_power: ar0234 2-0033 : 0x0
grab_camera-2368 [000] … 157.899297: camera_common_s_power: status : 0x0
grab_camera-2368 [000] … 157.899318: tegra_channel_set_power: 13e00000.host1x:nvcsi@15a00000- : 0x0
grab_camera-2368 [000] … 157.899320: csi_s_power: enable : 0x0
kworker/3:6-283 [003] … 164.124711: rtcpu_string: tstamp:6499687841 id:0x04010000 str:“VM0 deactivating.”
CHANSEL_NOMATCH could be incorrect virtual channel ID in PH or incorrect embedded_data_height in device tree.
