MAX96724 4-lane CSI, 4×1920×1536 YUV422@30 on Jetson Thor (R38.4): 1.5 Gbps too small, 2.0 Gbps times out
Platform: Jetson AGX Thor, L4T R38.4, kernel 6.8.12-tegra.
Topology: 4 cameras, 1920x1536 UYVY @ 30 fps → MAX96717 → coax → one MAX96724 → one 4-lane D-PHY port (port A). The carrier cannot use a second CSI port. All 4 VCs share this 4-lane link.
1.5 Gbps works for 1 or 3 cameras:
- MAX96724 0x0415/0x0418/0x041B/0x041E = 0x2F
- serdes_pix_clk_hz = 375000000
- /dev/video0 captures normally
4 cameras at 30 fps need about 5.66 Gbps of active pixels. 4 lanes × 1.5 Gbps is 6.0 Gbps (~94%). Three cameras (~4.25 Gbps) work; four do not.
2.0 Gbps produces no frames:
- same registers = 0x34
- serdes_pix_clk_hz = 500000000
- MAX96724 deskew: 0x0903/0x0904, 0x0943/0x0944, 0x0983/0x0984, 0x09C3/0x09C4 = 0x81
- 0x08A9/0x08AA left at 0xC8 (PHY copy)
- GMSL link A locked (0x01DC = 0x81)
- RCE log: Lanes 4, MIPI clock 1000000 kHz, Physical rate 2000000 Kbps
- tegra-camrtc-capture-vi: uncorr_err: request timed out after 2500 ms
- v4l2-ctl gets 0 frames. The system does not crash.
deskew_initial_enable = “true” crashes in nvcsi_deskew_setup() inside tegra-camera.ko (NULL pointer). This matches Nvcsi_deskew_setup dump. We reverted that property. We also saw Does NVCSI on Jetson AGX Thor support CSI-2 lane rates above 1.5 Gbps/lane, and how should it be configured?, where 0x0903 = 0x80 still timed out at 2.0/2.5 Gbps.
Questions:
1. On Thor R38.4, what MAX96724 (or MAX96717) register sequence makes the RCE accept a 4-lane D-PHY rate above 1.5 Gbps? Is 0x0903 = 0x80/0x81 enough, or is another initial-deskew length required?
2. Is 2.5 Gbps/lane actually supported on this Thor NVCSI port, or is 1.5 Gbps the practical limit for a single 4-lane brick?
3. If >1.5 Gbps cannot be made to work, is the supported way to run 4×1920×1536 to lower the sensor frame rate (about 20 fps) while staying at 1.5 Gbps?
This forum is exclusively for developers who are part of the NVIDIA DRIVE® AGX SDK Developer Program | NVIDIA Developer . To post in the forum, please use an account associated with your corporate or university email address. This helps us ensure that the forum remains a platform for verified members of the developer program.
