in OptiX SDK 7.0.0
in optixPathTracer.cu in __raygen__rg()
“traceRadiance” is called, which can call “optixTrace”
which can lead to : __closesthit__radiance()
there “traceOcclusion” can be called, which can again calls “optixTrace”
So I would assume this is a max depth of 2.
but in line 828 in optixPathTracer.cpp
uint32_t max_trace_depth = 1;
is used as param for optixUtilComputeStackSizes
I would expect:
max_trace_depth = 2;
The docs say “Maximum depth of optixTrace() calls.”
Is this related to each program or to the entire pipeline ?
Thank you.
