Hello, I would like to program a parallel data communication using the GPIO. So, I need to handle 16 bits in parallel using the GPIO outputs.
Currently I am using the following code to set 0/1 to the GPIO. However, it adresses a single GPIO on each function.
https://developer.ridgerun.com/wiki/index.php/Gpio-int-test.c
My questions to know if it’s feasible or not are:
- What is the maximum frequency that I can expect to get for the GPIO outputs?
I need at least 150MHz. Possible? If not, any other option through the other available connections to reach it? - Is there any method to adress the port (multiple GPIOs) instead going one by one?
Thank you.
