What is the Maximum real WIFI throughput data rate of Jetson TX2? around 200Mbps? Thank you
Hi pei-lan_yeh,
We don’t have such data because wifi is easily to be interrupted in different environment.
You may need to take a look at the bcm4354 datasheet.
Hi pei-lan_yeh,
List our test result on R28.1/TX2 for you reference:
STA_TPUT_TCP_DL_11ac5_VHT80_CH161_WPA2AES Throughput(Mb/s▲) 275
STA_TPUT_TCP_UL_11ac5_VHT80_CH161_WPA2AES Throughput(Mb/s▲) 293
STA_TPUT_UDP_DL_11ac5_VHT80_CH161_WPA2AES Throughput(Mb/s▲) 430
STA_TPUT_UDP_UL_11ac5_VHT80_CH161_WPA2AES Throughput(Mb/s▲) 406
Hi, Carolyuu
Thanks, These test results are tested under two antennas 2*2 MIMO condition?
Hi pei-lan_yeh,
Yes, we are tested under two antennas 2*2 MIMO condition.
Hi,Carolyuu
Thanks. One more question.
I think your TPUT_UDP tested under MCS5(64QAM, 2 strams)condition, right?
Could you please also provide TPUT_UDP tested under MCS9 (256QAM, 2 strams)condition data to us for reference? we want to know the Maximum real WIFI throughput data rate.
Thank you
Hi, Carolyuu
These test results are tested under MCS5 or MCS9 condition? Thank you
Hi pei-lan_yeh,
Our tests are conducted in MCS9.
If you want to improve the data rate, disable DVFS and set CPU, emc and GPU clocks to max.
Hi Carolyuu,
Thanks for your support.
one more question, what is the Maximum real WIFI throughput data rate at 2.4GHz on TX2? around 100Mbps?
Thank you
pei-lan_yeh
