Maximum value of tracker id
Please let me know the maximum value of the tracker id under the following conditions. If the tracker id reach the maximum value, it goes back to 0?
• DeepStream Version: 5.0
• Tracker: NvDCF
• useUniqueID: 0
The maximum value will be the max of unsigned long long. Yes, it goes back to 0 when reach the maximum value.
Thank you for your reply.
Is there case where the tracker id goes back to 0 before reaching its maximum value?
Yes, please check “tracking-id-reset-mode” in Gst-nvtracker — DeepStream 6.2 Release documentation
Can we use “tracking-id-reset-mode” in case of DeepStream 5.0?
Is there any case where the tracker id is reset unexpectedly?
Support for tracking ID reset based on event start from DS 6.0.
https://docs.nvidia.com/metropolis/deepstream/dev-guide/text/DS_plugin_gst-nvtracker.html#id6
