May I ask which file contains the post-processing code for Deepstream? I need to add the output function for detecting orientation in the post-process
**• Hardware Platform (Jetson / GPU) NVIDIA Orin NX
**• DeepStream Version 6.2
**• JetPack Version (valid for Jetson only)5.1.1
**• TensorRT Version 5.1.1
May I ask which file contains the post-processing code for Deepstream? I need to add the output function for detecting orientation in the post-processing file
Not fully understand your use case, seems you can use the detected object metadata (NvDsObjectMeta), to get the bbox and lebel, then you can add your specific logic.
In case your post-processiong is can be done by another model, you can refer sample ‘apps/sample_apps/deepstream-test2’, it uses several SGIE to detect color&make&type on the cars which are detected by PGIE.
