When a loop in a function that you are trying to compile renders the output:
Loop not parallelized: may not be beneficial
What is it basing its criteria for that response on? It seems a little arbitrary to me.
Also, is there a pgcc command to tell the pgcc compiler to not parallelize a loop if the intensity is below a certain value: say 5.00?
Any help appreciated. Thanks in advance.
Newport_j
