I’m using TX1 with R28.1.
After I set bitclock-master and frame-master for audio codec dai link in dts file.
When aplay xxx.wav. The error will report:
[ 144.774903] tegra210-i2s tegra210-i2s.4: Failed at I2S0_TX sw reset
[ 144.781162] tegra210-i2s tegra210-i2s.4: ASoC: PRE_PMU: I2S1 DAP TX event failed: -22
Then I check the code in tegra210_i2s_alt.c, found that:
static int tegra210_i2s_sw_reset(struct tegra210_i2s *i2s,
int direction, int timeout)
unsigned int sw_reset_reg, sw_reset_mask, sw_reset_en, sw_reset_default;
unsigned int tx_cif_ctrl, rx_cif_ctrl, tx_ctrl, rx_ctrl, ctrl, val;
int wait = timeout;
regmap_read(i2s->regmap, TEGRA210_I2S_AXBAR_TX_CIF_CTRL, &tx_cif_ctrl);
regmap_read(i2s->regmap, TEGRA210_I2S_AXBAR_RX_CIF_CTRL, &rx_cif_ctrl);
regmap_read(i2s->regmap, TEGRA210_I2S_AXBAR_TX_CTRL, &tx_ctrl);
regmap_read(i2s->regmap, TEGRA210_I2S_AXBAR_RX_CTRL, &rx_ctrl);
regmap_read(i2s->regmap, TEGRA210_I2S_CTRL, &ctrl);
if (direction == SNDRV_PCM_STREAM_PLAYBACK) {
sw_reset_reg = TEGRA210_I2S_AXBAR_RX_SOFT_RESET;
sw_reset_mask = TEGRA210_I2S_AXBAR_RX_SOFT_RESET_MASK;
sw_reset_en = TEGRA210_I2S_AXBAR_RX_SOFT_RESET_EN;
sw_reset_default = TEGRA210_I2S_AXBAR_RX_SOFT_RESET_DEFAULT;
} else {
sw_reset_reg = TEGRA210_I2S_AXBAR_TX_SOFT_RESET;
sw_reset_mask = TEGRA210_I2S_AXBAR_TX_SOFT_RESET_MASK;
sw_reset_en = TEGRA210_I2S_AXBAR_TX_SOFT_RESET_EN;
sw_reset_default = TEGRA210_I2S_AXBAR_TX_SOFT_RESET_DEFAULT;
regmap_update_bits(i2s->regmap, sw_reset_reg, sw_reset_mask, sw_reset_en);
But in R24.2:
int wait = timeout;
} else {
So the question is, when have playback stream , TX and RX, which one should be reset?
And which version is Right?
Besides, both of R24.2 and R28.1 has this code:
static const struct snd_soc_dapm_widget tegra210_i2s_widgets = {
SND_SOC_DAPM_AIF_IN(“CIF RX”, NULL, 0, SND_SOC_NOPM,
0, 0),
SND_SOC_DAPM_AIF_OUT(“CIF TX”, NULL, 0, SND_SOC_NOPM,
0, 0),
SND_SOC_DAPM_AIF_IN_E(“DAP RX”, NULL, 0, TEGRA210_I2S_AXBAR_TX_ENABLE,
TEGRA210_I2S_AXBAR_TX_EN_SHIFT, 0,
tegra210_i2s_rx_stop, SND_SOC_DAPM_POST_PMD),
SND_SOC_DAPM_AIF_OUT_E(“DAP TX”, NULL, 0, TEGRA210_I2S_AXBAR_RX_ENABLE,
TEGRA210_I2S_AXBAR_RX_EN_SHIFT, 0,
tegra210_i2s_tx_stop, SND_SOC_DAPM_POST_PMD),
TX and RX should’t be correspond to TX/RX reg?
Anyone from NVidia can confirm that?
