Ok, currently im trying to implement an area-search-Blockmatcher using cuda.
Im trying to find blocks from an reference image in a defined search areas in another image.
the core idea is to iterate over the different blocks to find using the gridindex, and iterate over the different possible block (in the search area) using the blockindex. then let every thread compare to blocks and write back the result to shared mem.
cause of bigger search areas i decided to build 4 different kernels for each direction(-x/y, x/y, -x/-y, x/-y). So i can use the threadindex with different signs to displace in the search area.
My problem is now that these 4 kernel have noticeable different execution times. Maybe im doing something completly wrong or just miss something. so here is my code:
The blockmatch kernel upper-right, for other directions i just changed the signs befor threadIdx
__global__ void blockmatchur (
int *blkOrigins,
int blockSize,
int dspl,
int4 *results
int tx = threadIdx.x;
int ty = threadIdx.y;
int bx = blockIdx.x;
int by = blockIdx.y;
int curPosInGrid = by*gridDim.x + bx;
int curPosInBlock = ty*blockDim.x + ty;
int posX = blkOrigins[curPosInGrid];
int posY = blkOrigins[curPosInGrid+1];
__shared__ int4 values[256];
values[curPosInBlock] = make_int4(matchblock3(blockSize, posX, posY, tx, ty), posX+tx, posY+ty, 0);
__syncthreads();
the comparator
__device__ int matchblock3(
int blockSize,
int posX,
int posY,
int dsplX,
int dsplY
int sum = 0;
int psX = posX + tx;
int pX = posX + dsplX;
int pY = posY + dsplY;
// iterate over block
for (int y = 0; y < blockSize; y++){
for (int x = 0; x < blockSize; x++){
sum += (tex2D(img, pY + y, pX + x )^2 -
tex2D(imgRef, posY + y , psX + x)^2);
return sum;
And i call it like this
dim3 threads( dspl, dspl );
dim3 grid(20, 15);
blockmatchur<<< grid, threads >>>(org_Data, blockW, dspl, res_Data);
the code is currently not tuned as to good memory access.
