We used to use 8GB module, there was no problem. After changing to 16GB module, the device can boot up normally,
but I got a mc-err issue after running for a period of time. Searching the forums, someone is having similar problems with DLA, but we are not using the DLA feature.
The following is the log of the occurrence of the problem, and I hope someone can help analyze the cause, thank you!
SDK: Tegra186_linux_R32.5.1 + patch: NX-16GB-R32.5.1 -overlay.tbz2
<— dmesg log
[354083.638494] FAN cooling trip_level:0 cur_temp:37900 trip_temps[1]:46000
[355700.918436] FAN rising trip_level:1 cur_temp:46000 trip_temps[2]:60000
[355720.663742] t19x-arm-smmu 12000000.iommu: Unhandled context fault: smmu0, iova=0x5de9e300, fsynr=0x20013, cb=2, sid=20(0x14 - EQOS), pgd=4681fc003, pud=4681fc003, pmd=4681fd003, pte=6000029ba26f47
[355720.665865] mc-err: vpr base=0:c6000000, size=20, ctrl=3, override:(a01a8340, fcee10c1, 1, 0)
[355720.666459] mc-err: (255) csw_eqosw: MC request violates VPR requirements
[355720.666676] mc-err: status = 0x0ff7408f; addr = 0xffffffff00; hi_adr_reg=008
[355720.666958] mc-err: secure: yes, access-type: write
[355720.667165] mc-err: mcerr: unknown intr source intstatus = 0x00000000, intstatus_1 = 0x00000000
[355731.797175] t19x-arm-smmu 12000000.iommu: Unhandled context fault: smmu0, iova=0x5db8e180, fsynr=0x20013, cb=2, sid=20(0x14 - EQOS), pgd=4681fc003, pud=4681fc003, pmd=3b6786003, pte=6000035a128f47
[355731.799360] mc-err: vpr base=0:c6000000, size=20, ctrl=3, override:(a01a8340, fcee10c1, 1, 0)
[355731.800009] mc-err: (255) csw_eqosw: MC request violates VPR requirements
[355731.800438] mc-err: status = 0x0ff7408f; addr = 0xffffffff00; hi_adr_reg=008
[355731.800971] mc-err: secure: yes, access-type: write
[355731.801199] mc-err: mcerr: unknown intr source intstatus = 0x00000000, intstatus_1 = 0x00000000
[355845.398512] FAN cooling trip_level:0 cur_temp:37900 trip_temps[1]:46000
[357523.191328] FAN rising trip_level:1 cur_temp:46000 trip_temps[2]:60000
[357623.756885] t19x-arm-smmu 12000000.iommu: Unhandled context fault: smmu0, iova=0x5dc55180, fsynr=0x20013, cb=2, sid=20(0x14 - EQOS), pgd=4681fc003, pud=4681fc003, pmd=45e0ef003, pte=600003d64c0f47
[357623.758838] mc-err: Too many MC errors; throttling prints
[357678.902173] FAN cooling trip_level:0 cur_temp:37900 trip_temps[1]:46000
[358050.775531] FAN rising trip_level:1 cur_temp:46000 trip_temps[2]:60000
[358199.742154] FAN cooling trip_level:0 cur_temp:37900 trip_temps[1]:46000
[358907.574146] FAN rising trip_level:1 cur_temp:46050 trip_temps[2]:60000
