MCNPX error
Hi.
I compiled the MCNPX v250 like below.
Compiling is well done with no error. But some simmulation input files give the error message.
How can i solve the problem?
I’m using the PGI-12.5 vesion.
  •        Copyright Notice for MCNPX             *
  • This program was prepared by the Regents of the *
  • University of California at Los Alamos National *
  • Laboratory (the University) under contract number *
  • W-7405-ENG-36 with the U.S. Department of Energy *
  • (DOE). The University has certain rights in the *
  • program pursuant to the contract and the program *
  • should not be copied or distributed outside your *
  • organization. All rights in the program are *
  • reserved by the DOE and the University. Neither *
  • the U.S. Government nor the University makes any *
  • warranty, express or implied, or assumes any *
  • liability or responsibility for the use of this *
  • software. *
rank 0 in job 2 tachyon3180_40022 caused collective abort of all ranks
exit status of rank 0: killed by signal 9
#!/bin/bash
You may change path to your absolute path. - prefix and MPILIB
export Prefix=“/home/lim/MCNPX_MVAPICH2”
export TARCH=intel
export TSYS=linux
export TFC=mpif90
export TCC=mpicc
TARCH=“$TARCH” TSYS=“$TSYS” TFC=“$TFC” TCC=“$TCC” ./configure --prefix=“$Prefix”
–with-FC=$TFC
–with-CC=$TCC
–with-STATIC
–with-FFLAGS=“-O2 -fPIC -DUNIX=1 -DLINUX=1 -DMPI=1 -DMPIF90=1”
–with-CFLAGS=“-O2 -fPIC -DUNIX=1 -DLINUX=1”
–with-MPILIB=“-L/opt/mvapich2/pgi/lib -lmpich -lmpichf90”
–with-MPIINC=“/opt/mvapich2/pgi/include”
clear
for i in $(find ./ -name ‘Makefile.h’); do
perl -p -i -e “s/rt'/rt/g” $i
done
make
make install
cp -f mcnpx/*.a ${Prefix}/lib
Hi Jong-MyoungLim84242,
Unfortunately, there’s not much to go on here so you’ll need to do a bit more digging.
Can you recreate the failure using a single process? Are there any additional error messages?
  • Mat
Thank you for your reply.
The error message for some input files are below…
time ./mcnpx_run.sh
ibnode01.16401ipath_userinit: assign_context command failed: Network is down
ibnode01.16404ipath_userinit: assign_context command failed: Network is down
ibnode01.16405ipath_userinit: assign_context command failed: Network is down
ibnode01.16406ipath_userinit: assign_context command failed: Network is down
ibnode01.16412ipath_userinit: assign_context command failed: Network is down
ibnode01.16413ipath_userinit: assign_context command failed: Network is down
ibnode01.16401can’t open /dev/ipath, network down (err=26)
psm_ep_open failed with error Could not detect network connectivity
Fatal error in MPI_Init: Internal MPI error!
ibnode01.16404can’t open /dev/ipath, network down (err=26)
ibnode01.16405can’t open /dev/ipath, network down (err=26)
ibnode01.16406can’t open /dev/ipath, network down (err=26)
ibnode01.16412can’t open /dev/ipath, network down (err=26)
ibnode01.16413can’t open /dev/ipath, network down (err=26)
ibnode04.12940ipath_userinit: assign_context command failed: Network is down
ibnode04.12941ipath_userinit: assign_context command failed: Network is down
ibnode04.12942ipath_userinit: assign_context command failed: Network is down
ibnode04.12943ipath_userinit: assign_context command failed: Network is down
ibnode04.12944ipath_userinit: assign_context command failed: Network is down
ibnode04.12945ipath_userinit: assign_context command failed: Network is down
ibnode04.12946ipath_userinit: assign_context command failed: Network is down
ibnode04.12947ipath_userinit: assign_context command failed: Network is down
ibnode04.12948ipath_userinit: assign_context command failed: Network is down
ibnode04.12949ipath_userinit: assign_context command failed: Network is down
ibnode04.12950ipath_userinit: assign_context command failed: Network is down
ibnode04.12951ipath_userinit: assign_context command failed: Network is down
ibnode04.12952ipath_userinit: assign_context command failed: Network is down
ibnode04.12953ipath_userinit: assign_context command failed: Network is down
ibnode04.12954ipath_userinit: assign_context command failed: Network is down
ibnode04.12955ipath_userinit: assign_context command failed: Network is down
ibnode04.12940can’t open /dev/ipath, network down (err=26)
ibnode04.12941can’t open /dev/ipath, network down (err=26)
ibnode04.12942can’t open /dev/ipath, network down (err=26)
ibnode04.12943can’t open /dev/ipath, network down (err=26)
ibnode04.12944can’t open /dev/ipath, network down (err=26)
ibnode04.12945can’t open /dev/ipath, network down (err=26)
ibnode04.12946can’t open /dev/ipath, network down (err=26)
ibnode04.12947can’t open /dev/ipath, network down (err=26)
ibnode04.12948can’t open /dev/ipath, network down (err=26)
ibnode04.12949can’t open /dev/ipath, network down (err=26)
ibnode04.12950can’t open /dev/ipath, network down (err=26)
ibnode04.12951can’t open /dev/ipath, network down (err=26)
ibnode04.12952can’t open /dev/ipath, network down (err=26)
ibnode04.12953can’t open /dev/ipath, network down (err=26)
ibnode04.12954can’t open /dev/ipath, network down (err=26)
ibnode04.12955can’t open /dev/ipath, network down (err=26)
ibnode05.11744ipath_userinit: assign_context command failed: Network is down
ibnode05.11745ipath_userinit: assign_context command failed: Network is down
ibnode05.11746ipath_userinit: assign_context command failed: Network is down
ibnode07.21544ipath_userinit: assign_context command failed: Network is down
ibnode03.11809ipath_userinit: assign_context command failed: Network is down
ibnode05.11747ipath_userinit: assign_context command failed: Network is down
ibnode07.21545ipath_userinit: assign_context command failed: Network is down
ibnode03.11810ipath_userinit: assign_context command failed: Network is down
ibnode05.11748ipath_userinit: assign_context command failed: Network is down
ibnode03.11811ipath_userinit: assign_context command failed: Network is down
ibnode05.11749ipath_userinit: assign_context command failed: Network is down
ibnode02.3366ipath_userinit: assign_context command failed: Network is down
ibnode07.21546ipath_userinit: assign_context command failed: Network is down
ibnode03.11812ipath_userinit: assign_context command failed: Network is down
ibnode05.11750ipath_userinit: assign_context command failed: Network is down
ibnode02.3367ipath_userinit: assign_context command failed: Network is down
ibnode07.21547ipath_userinit: assign_context command failed: Network is down
ibnode03.11813ipath_userinit: assign_context command failed: Network is down
ibnode05.11751ipath_userinit: assign_context command failed: Network is down
ibnode02.3368ipath_userinit: assign_context command failed: Network is down
ibnode07.21548ipath_userinit: assign_context command failed: Network is down
ibnode03.11814ipath_userinit: assign_context command failed: Network is down
ibnode05.11752ipath_userinit: assign_context command failed: Network is down
ibnode07.21549ipath_userinit: assign_context command failed: Network is down
ibnode03.11815ipath_userinit: assign_context command failed: Network is down
ibnode05.11753ipath_userinit: assign_context command failed: Network is down
ibnode02.3369ipath_userinit: assign_context command failed: Network is down
ibnode07.21550ipath_userinit: assign_context command failed: Network is down
ibnode03.11816ipath_userinit: assign_context command failed: Network is down
ibnode05.11754ipath_userinit: assign_context command failed: Network is down
ibnode02.3370ipath_userinit: assign_context command failed: Network is down
ibnode07.21551ipath_userinit: assign_context command failed: Network is down
ibnode03.11818ipath_userinit: assign_context command failed: Network is down
ibnode05.11755ipath_userinit: assign_context command failed: Network is down
ibnode02.3371ipath_userinit: assign_context command failed: Network is down
ibnode07.21552ipath_userinit: assign_context command failed: Network is down
ibnode03.11819ipath_userinit: assign_context command failed: Network is down
ibnode05.11756ipath_userinit: assign_context command failed: Network is down
ibnode02.3372ipath_userinit: assign_context command failed: Network is down
ibnode07.21553ipath_userinit: assign_context command failed: Network is down
ibnode03.11820ipath_userinit: assign_context command failed: Network is down
ibnode05.11757ipath_userinit: assign_context command failed: Network is down
ibnode02.3373ipath_userinit: assign_context command failed: Network is down
ibnode07.21554ipath_userinit: assign_context command failed: Network is down
ibnode03.11821ipath_userinit: assign_context command failed: Network is down
ibnode05.11758ipath_userinit: assign_context command failed: Network is down
ibnode02.3374ipath_userinit: assign_context command failed: Network is down
ibnode07.21555ipath_userinit: assign_context command failed: Network is down
ibnode03.11822ipath_userinit: assign_context command failed: Network is down
ibnode05.11759ipath_userinit: assign_context command failed: Network is down
ibnode02.3375ipath_userinit: assign_context command failed: Network is down
ibnode07.21556ipath_userinit: assign_context command failed: Network is down
ibnode03.11823ipath_userinit: assign_context command failed: Network is down
ibnode05.11744can’t open /dev/ipath, network down (err=26)
ibnode02.3376ipath_userinit: assign_context command failed: Network is down
ibnode07.21557ipath_userinit: assign_context command failed: Network is down
ibnode03.11824ipath_userinit: assign_context command failed: Network is down
ibnode05.11745can’t open /dev/ipath, network down (err=26)
ibnode02.3377ipath_userinit: assign_context command failed: Network is down
ibnode07.21558ipath_userinit: assign_context command failed: Network is down
ibnode03.11809can’t open /dev/ipath, network down (err=26)
ibnode05.11746can’t open /dev/ipath, network down (err=26)
ibnode02.3378ipath_userinit: assign_context command failed: Network is down
ibnode07.21559ipath_userinit: assign_context command failed: Network is down
ibnode03.11810can’t open /dev/ipath, network down (err=26)
ibnode05.11747can’t open /dev/ipath, network down (err=26)
ibnode02.3379ipath_userinit: assign_context command failed: Network is down
ibnode07.21544can’t open /dev/ipath, network down (err=26)
ibnode03.11811can’t open /dev/ipath, network down (err=26)
ibnode05.11748can’t open /dev/ipath, network down (err=26)
ibnode02.3366can’t open /dev/ipath, network down (err=26)
ibnode07.21545can’t open /dev/ipath, network down (err=26)
ibnode03.11812can’t open /dev/ipath, network down (err=26)
ibnode05.11749can’t open /dev/ipath, network down (err=26)
ibnode02.3367can’t open /dev/ipath, network down (err=26)
ibnode07.21546can’t open /dev/ipath, network down (err=26)
ibnode03.11813can’t open /dev/ipath, network down (err=26)
ibnode05.11750can’t open /dev/ipath, network down (err=26)
ibnode02.3368can’t open /dev/ipath, network down (err=26)
ibnode07.21547can’t open /dev/ipath, network down (err=26)
ibnode03.11814can’t open /dev/ipath, network down (err=26)
ibnode05.11751can’t open /dev/ipath, network down (err=26)
ibnode02.3369can’t open /dev/ipath, network down (err=26)
ibnode07.21548can’t open /dev/ipath, network down (err=26)
ibnode03.11815can’t open /dev/ipath, network down (err=26)
ibnode05.11752can’t open /dev/ipath, network down (err=26)
ibnode02.3370can’t open /dev/ipath, network down (err=26)
ibnode07.21549can’t open /dev/ipath, network down (err=26)
ibnode03.11816can’t open /dev/ipath, network down (err=26)
ibnode05.11753can’t open /dev/ipath, network down (err=26)
ibnode02.3371can’t open /dev/ipath, network down (err=26)
ibnode07.21550can’t open /dev/ipath, network down (err=26)
ibnode03.11818can’t open /dev/ipath, network down (err=26)
ibnode05.11754can’t open /dev/ipath, network down (err=26)
ibnode02.3372can’t open /dev/ipath, network down (err=26)
ibnode07.21551can’t open /dev/ipath, network down (err=26)
ibnode03.11819can’t open /dev/ipath, network down (err=26)
ibnode05.11755can’t open /dev/ipath, network down (err=26)
ibnode02.3373can’t open /dev/ipath, network down (err=26)
ibnode07.21552can’t open /dev/ipath, network down (err=26)
ibnode03.11820can’t open /dev/ipath, network down (err=26)
ibnode05.11756can’t open /dev/ipath, network down (err=26)
ibnode02.3374can’t open /dev/ipath, network down (err=26)
ibnode07.21553can’t open /dev/ipath, network down (err=26)
ibnode03.11821can’t open /dev/ipath, network down (err=26)
ibnode05.11757can’t open /dev/ipath, network down (err=26)
ibnode02.3375can’t open /dev/ipath, network down (err=26)
ibnode07.21554can’t open /dev/ipath, network down (err=26)
ibnode03.11822can’t open /dev/ipath, network down (err=26)
ibnode05.11758can’t open /dev/ipath, network down (err=26)
ibnode02.3376can’t open /dev/ipath, network down (err=26)
ibnode07.21555can’t open /dev/ipath, network down (err=26)
ibnode03.11823can’t open /dev/ipath, network down (err=26)
ibnode05.11759can’t open /dev/ipath, network down (err=26)
ibnode02.3377can’t open /dev/ipath, network down (err=26)
ibnode07.21556can’t open /dev/ipath, network down (err=26)
ibnode03.11824can’t open /dev/ipath, network down (err=26)
ibnode02.3378can’t open /dev/ipath, network down (err=26)
ibnode07.21557can’t open /dev/ipath, network down (err=26)
ibnode02.3379can’t open /dev/ipath, network down (err=26)
ibnode07.21558can’t open /dev/ipath, network down (err=26)
ibnode07.21559can’t open /dev/ipath, network down (err=26)
ibnode06.11771ipath_userinit: assign_context command failed: Network is down
ibnode06.11772ipath_userinit: assign_context command failed: Network is down
ibnode06.11773ipath_userinit: assign_context command failed: Network is down
ibnode06.11774ipath_userinit: assign_context command failed: Network is down
ibnode06.11775ipath_userinit: assign_context command failed: Network is down
ibnode06.11776ipath_userinit: assign_context command failed: Network is down
ibnode06.11777ipath_userinit: assign_context command failed: Network is down
ibnode06.11778ipath_userinit: assign_context command failed: Network is down
ibnode06.11779ipath_userinit: assign_context command failed: Network is down
ibnode06.11780ipath_userinit: assign_context command failed: Network is down
ibnode06.11781ipath_userinit: assign_context command failed: Network is down
ibnode06.11782ipath_userinit: assign_context command failed: Network is down
ibnode06.11783ipath_userinit: assign_context command failed: Network is down
ibnode06.11784ipath_userinit: assign_context command failed: Network is down
ibnode06.11785ipath_userinit: assign_context command failed: Network is down
ibnode06.11786ipath_userinit: assign_context command failed: Network is down
ibnode06.11771can’t open /dev/ipath, network down (err=26)
ibnode06.11772can’t open /dev/ipath, network down (err=26)
ibnode06.11773can’t open /dev/ipath, network down (err=26)
ibnode06.11774can’t open /dev/ipath, network down (err=26)
ibnode06.11775can’t open /dev/ipath, network down (err=26)
ibnode06.11776can’t open /dev/ipath, network down (err=26)
ibnode06.11777can’t open /dev/ipath, network down (err=26)
ibnode06.11778can’t open /dev/ipath, network down (err=26)
ibnode06.11779can’t open /dev/ipath, network down (err=26)
ibnode06.11780can’t open /dev/ipath, network down (err=26)
ibnode06.11781can’t open /dev/ipath, network down (err=26)
ibnode06.11782can’t open /dev/ipath, network down (err=26)
ibnode06.11783can’t open /dev/ipath, network down (err=26)
ibnode06.11784can’t open /dev/ipath, network down (err=26)
ibnode06.11785can’t open /dev/ipath, network down (err=26)
ibnode06.11786can’t open /dev/ipath, network down (err=26)
real 0m3.829s
user 0m0.155s
sys 0m2.334s
Do you have local system’s admin you could talk with?
I did a web search for the term “assign_context command failed” and as best as I can tell, it’s a network configuration issue. Though, I’m not an expert in cluster managerment so don’t know for sure.
Sorry that I can’t be of more help here.
  • Mat
