Issue Description
I am trying to bring up the MCP2518FD SPI-to-CAN transceiver on the Orin platform. Currently, the device has been successfully enumerated, and the CAN node has also appeared normally. However, I cannot send or receive external CAN messages using cansend
or candump
. How can I troubleshoot this issue?
this is my dts file
clocks {
clk40m: mcp2518fd_osc {
#clock-cells = <0>;
compatible = "fixed-clock";
clock-frequency = <40000000>;
clock-accuracy = <100>;
can@0 {
compatible = "microchip,mcp2518fd";
status = "okay";
reg = <0x0>;
spi-max-frequency = <10000000>;
clocks = <&clk40m>;
interrupt-parent = <&gpio>;
interrupts = <TEGRA234_MAIN_GPIO(R, 0) IRQ_TYPE_LEVEL_LOW>;
vdd-supply = <&vdd_5v0_sys>;
xceiver-supply = <&vdd_5v0_sys>;
controller-data {
nvidia,enable-hw-based-cs;
nvidia,cs-setup-clk-count = <0x1e>;
nvidia,cs-hold-clk-count = <0x1e>;
nvidia,rx-clk-tap-delay = <0x1f>;
nvidia,tx-clk-tap-delay = <0x0>;
can@1 {
status = "disabled";
reg = <0x1>;
clocks = <&clk40m>;
interrupts = <TEGRA234_MAIN_GPIO(N, 1) IRQ_TYPE_LEVEL_LOW>;
controller-data {
Error String
< Please provide just the error messages here >
Logs
[ 167.332351] irq: IRQ290: trimming hierarchy from :bus@0:pmc@c360000
[ 167.333478] spi_master spi0: will run message pump with realtime priority
[ 167.342897] mcp251xfd spi0.0 can2: MCP2518FD rev0.0 (-RX_INT -MAB_NO_WARN +CRC_REG +CRC_RX +CRC_TX +ECC -HD c:40.00MHz m:10.00MHz r:10.00MHz e:0.00MHz) successfully initialized.
[ 167.343143] irq: IRQ291: trimming hierarchy from :bus@0:pmc@c360000
[ 167.353255] mcp251xfd spi0.1 can3: MCP2518FD rev0.0 (-RX_INT -MAB_NO_WARN +CRC_REG +CRC_RX +CRC_TX +ECC -HD c:40.00MHz m:10.00MHz r:10.00MHz e:0.00MHz) successfully initialized.
[ 188.972040] mttcan c310000.mttcan can0: Bitrate set
[ 188.974872] mttcan c320000.mttcan can1: Bitrate set
[ 189.000566] mttcan_controller_config: ctrlmode 0
[ 189.000592] mttcan c310000.mttcan can0: Bitrate set
[ 189.000722] IPv6: ADDRCONF(NETDEV_CHANGE): can0: link becomes ready
[ 189.002446] mttcan_controller_config: ctrlmode 0
[ 189.002466] mttcan c320000.mttcan can1: Bitrate set
[ 190.015814] IPv6: ADDRCONF(NETDEV_CHANGE): can1: link becomes ready
[ 190.015887] IPv6: ADDRCONF(NETDEV_CHANGE): can2: link becomes ready
[ 190.016051] IPv6: ADDRCONF(NETDEV_CHANGE): can3: link becomes ready
[ 215.588398] can: controller area network core
the default can0 and can1 are working well ,i use Jetpack 6.0(rev 2) version , change the dts file and insmod the mcp2518fd.ko to test
has any tips to help ?
I have searched all the forums on this topic, but the issue remains unresolved.
