MCU Console: Unknown command: show_fanrpm
show_fanrpm is documented in Using the MCU Console
But I got it’s an unknown command:
And here are my env: DRIVE OS 6.0.4 / Linux / p3710-10-s05, 940-63710-0010-D00 / SDKM 1.8.3.10426 / Ubuntu 20.04.5
Dear @Keelung,
Could you share the version command output
Hi @SivaRamaKrishnaNV ,
Here it is:
Shell>version
DDPX Aurix Serial Console
P3710-TS5
with TLF35584 B/C-Step
UPDATE SW Version  1.47.04
DRIVE-v6.x.x-P3710-NV-Aurix-UPDATE-StepB-1.47.4
TC397 Step BD
Dear @Keelung,
Have you flashed the target using sdkamanager. If not, could you check flashing using sdkamanager again?
I’ve tried as I remember. But I can try again when I’m back to work.after one week. It’s our national holiday from now on.
@Keelung show_fanrpm works well on my system flashed with SDK Manager and below is my version information. FYR.
NvShell>version
Info: Executing cmd: version, argc: 0, args:
DRIVE-V6.0.4-P3710-AFW-Aurix-StepB-5.05.03
Command Executed
Seems to be a version compatibility issue.
Since it’s in bootloop, then how can I upgrade it? Is there a software / script which I can flash TC397 by CAN or Ethernet or other interface?
Please follow DRIVE OS 6.0 Installation Guide for NVIDIA Developers to flash DRIVE OS 6.0.4 Linux SDK and it will update the firmware along the way.
Also, please provide the following info by ticking the boxes:
Software Version
DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.8.3.10426
other
Host Machine Version
other
@VickNV ,
My env: DRIVE OS 6.0.4 / Linux / p3710-10-s05, 940-63710-0010-D00 / SDKM 1.8.3.10426 / Ubuntu 20.04.5
We tried flashing AFW(5.05.03) by JTAG, and seems failure since version 1.47.4 still reported and still in bootloop.
As described in SDK Do not use the Erase button in the memtool, so we did not erase memory. But that because we flashed without erasing memory? Is’t safe to erase? Or once erased then how to recovery from erasing?
Please use SDK Manager to flash the unit and it will update the firmware during the first booting. Thanks.
