MCU firmware program can not be programmed
My customer’s MCU firmware program cannot be programmed,
What is used is:https://developer.nvidia.com/embedded/nvidia-jetson-agx-xavier-and-jetson-xavier-nx-power-button-supervisor-firmware
Please provide a tutorial on MCU programming firmware to help customers develop better projects?
What are the precautions in the process of programming the firmware?
Any suggestions are helpful, thanks
hello aaron.ge,
I’m not sure I had fully understood your inquiries, don’t there already a README file for the instructions to setup and build the binary from the source code?
could you please share more details of your request,
thanks
Can you provide the procedure to program the firmware on a custom board based on Xavier NX kit. I have used same Part number that was used in the development kit and I had not changed any circuit regarding MCU.
hello ather1496 ,
please open a new forum topic if need further supports, thanks
Ok
I already did it.
hello ather1496,
should be this thread, Topic 173481, right? let’s using this thread for further supports.
thanks
yes
