MDL SDK 2026.0.2: Beckmann Smith absorbs every sample and returns non-finite evaluation at exact normal incidence
I reproduced an exact-normal Beckmann Smith issue with the official Windows MDL SDK 2026.0.2 (391700.2276), using the native JIT directly. This reproduction does not use Blender or Iray scene export.
Material: IOR 1.5, white tint, roughness_u = 0.35 * 0.35 (also tested 0.7 * 0.7), multiscatter_tint = color(0), scatter_reflect_transmit, normal and geometry normal (0,0,1), tangent_u (1,0,0), tangent_v (0,1,0). Both current/other-medium IOR orientations were tested. BSDF flags explicitly allow reflection and transmission.
At outgoing incidence exactly 0 degrees, all 32768 deterministic random samples per Smith case return BSDF_EVENT_ABSORB. At 0.1 degrees, the same point-sampling setup returns valid nonabsorbed events. The behavior reproduces both with the bare Smith BSDF and with a zero-thickness thin-film wrapper.
Fixed-direction BSDF evaluation at exact-normal outgoing incidence produces non-finite output for all 96 Smith cases tested (reflection/transmission, incoming angles 1/10/45 degrees, both azimuth signs and both IOR directions). In the same harness the 96 exact-normal V-cavities controls are finite. The V-cavities controls are not proposed as a physically equivalent replacement.
Explicit fast_math on/off both reproduce the all-absorb sampling behavior. The full point results and source are in the attached reproduction bundle. The sources instantiate and compile the material with create_compiled_material(), translate_material_df(“surface.scattering”), then call execute_bsdf_init/sample/evaluate. No image rendering is involved in this SDK reproduction.
Separately, native Iray Server 2025.0.13 (387700.6169) GPU renders reproduce black at exactly normal incidence for this material. I have not established that its private BSDF implementation is identical to the public SDK source.
Is this a known issue? Is there a supported correction or a newer SDK/worker build that fixes the exact-normal case without perturbing the surface normal or changing the physical distribution?
Official release: Release MDL SDK 2026.0.2 (391700.2276): 24 Aug 2026 · NVIDIA/MDL-SDK · GitHub
Riproduzione_Beckmann_per_NVIDIA_v042.zip (24.3 KB)
Thanks for reporting the issue. It was not known yet and we will address it with the next release.
The exact normal incidence is a numerical corner case where NaN arises. This will be explicitly handled.
