Mdx-deepstream container cannot see GPUs
• Hardware dual L4 AMD64 system with
96 Gbyte RAM
I am following the setup instructions for the metropolis microservices for multicamera tracking.
(Quickstart Setup — mdx-docs 2.1 documentation)
I have confirmed that
docker run --rm --gpus all nvidia/cuda:12.2.0-base-ubuntu20.04 nvidia-smi
works.
When I bring up the other containers for the multicamera tracking, i.e. run
docker compose -f foundational/mdx-foundational.yml -f mtmc-app/mdx-mtmc-app.yml --profile e2e up -d --pull always --build --force-recreate
it brings up all containers, except for mdx-deepstream.
The docker log for the mdx-deepstream is attached:
mdx-deepstream-log.txt (3.5 KB)
It would appear the container cannot see the GPUs?
I have no idea why, since docker run --rm --gpus all nvidia/cuda:12.2.0-base-ubuntu20.04 nvidia-smi does run (albeit only after setting no-cgroups = false in /etc/nvidia-container-runtime/config.toml).
Seems that it is a topic for metropolis microservices. You can ask in its forum https://forums.developer.nvidia.com/c/accelerated-computing/intelligent-video-analytics/mm-ea/500 for further checking. Thanks.
