Measuring running time
Hi, I’m new to CUDA and I want to measure how much time a kernel function requires to run. I have this simple programs which takes as input an array and multiply each element MULVALUE times, where MULVALUE is a constant. The kernel call is the following
// i want to mesaure time between this point
squareArray <<< blockNumber, blockSize >>>(a_device, LENGTH);
// and this point
a_device is a float array and LENGTH is the array length
the kernel definition is the following
#define MULVALUE	3
#ifndef _SQUARE_KERNEL_H_
#define _SQUARE_KERNEL_H_
__global__ void squareArray(float *a, int length)
  int idx = blockIdx.x * blockDim.x + threadIdx.x;
  if (idx < length)
	  for (int i = 0; i < MULVALUE; i++)
	a[idx] = a[idx] * a[idx];
__global__ void empty()
#endif // #ifndef _SQUARE_KERNEL_H_
How can I do that?
You should use cuda events if you want to measure the time spent by the GPU to execute your kernel.
Try something like
cudaEvent_t start, stop;
	float time;
	cudaEventCreate(&start);
	cudaEventCreate(&stop);
	cudaEventRecord(start, 0);
	hereYourKernel<<<...>>>(...);
	cudaEventRecord(stop, 0);
	cudaEventSynchronize(stop); //Block until the event is actually recorded
	cudaEventElapsedTime(&time, start, stop);
	printf("Done in %f ms.\n", time);
Regards,
Daniele
