Does anyone have some sample code that uses the Median Flow calls such as nvxuMedianFlow
Cheers
Youngie…
Cheers
Youngie…
You can find some information in our document:
VisionWorks API
NVIDIA Extension API
Vision Primitives API
Median Flow
nvxuMedianFlow
I have looked at the API but I can’t seem to find any information on how to use it. For instance, what is the difference between the Graph call and the immediate call. Are prev_pts and next_pts simply the values in in the matrix for an image? The output is a 3D vector? A simple example would be nice.
[in] context Specifies the context.
[in] prev_pts Specifies the input previous points list. Only VX_TYPE_KEYPOINT and NVX_TYPE_POINT2F item types are supported.
[in] next_pts Specifies the input next points list. It must have the same item type and number of items as prev_pts.
[in] pts_fb [optional] Specifies the backward points list. It must have the same item type and number of items as prev_pts.
[out] out Specifies the output median flow. It is a one element NVX_TYPE_POINT3F array. x and y fields of the first element represent estimated displacement, z field represents estimated scale change. In case of estimation failure (0,0,−1) is returned.
[in] estimate_scale Specifies whether to estimate scale change.
[in] filter_flow_by_err Specifies whether to filter out points with a high error value.
[in] error_fb_thresh [optional] Specifies the threshold for forward-backward errors. Pass a nonpositive value to disable forward-backward filtering.
The information is included in our document.
Let us summary here:
1. Graph Mode v.s. immediate Mode
You can find some information here:
[i]>> VisionWorks API
Tutorials
VisionWorks Quick Start (Immediate Mode)
VisionWorks Quick Start (Graph Mode)[/i]
<b>Graph based execution</b>
Primitives are instantiated as graph nodes. The graph is built, verified and optimized ahead-of-time and can be executed multiple times without re-verification at run-time. The graph based execution should be prefered for vision pipelines that are executed multiple times (when processing a video stream for instance), as it will give best performance.
<b>Immediate execution</b>
Primitives are executed directly by calling a function (prefixed with vxu or nvxu) similar to the OpenCV or NPP execution mode. The immediate execution model is useful for one-time processing when the primitive setup overhead is not a big concern. It can also be useful as an intermediate step in application development, like when porting an application that uses OpenCV, for example.
2. prev_pts and next_pts
They are key points, indicating the feature point used for estimating motion.
The structure of key point can be found here:
https://www.khronos.org/registry/OpenVX/specs/1.1/html/d4/dae/group__group__basic__features.html#d6/db0/structvx__keypoint__t
3. output
The variable type is vx_array, which can the following type:
NVX_TYPE_POINT2F A nvx_point2f_t.
NVX_TYPE_POINT3F A nvx_point3f_t.
NVX_TYPE_POINT4F A nvx_point4f_t.
NVX_TYPE_KEYPOINTF A nvx_keypointf_t.
NVX_TYPE_STRUCT_MAX A floating value for comparison between structs and objects.
NVX_TYPE_OBJECT_MAX A floating value used for bound checking the VisionWorks object types
You can the sample located at /usr/share/visionworks/sources/samples/object_tracker_nvxcu/.
Although it is for optical flow, the usage should be similar.
