Jetpack 6.1 and I flashed the Orin Nano using the SDKManager.
I am currently trying to use a 2230 Wifi (based on MT7921) on a Jetson Orin Nano. However, I don’t see the device using lspci, lsusb, nor inxi. I also don’t see it under ifconfig or iwconfig.
I used this command and here is the output zcat /proc/config.gz | egrep ‘MEDIATEK’
CONFIG_ARCH_MEDIATEK=y
# CONFIG_ARM_MEDIATEK_CPUFREQ is not set
CONFIG_ARM_MEDIATEK_CPUFREQ_HW=m
# CONFIG_PCIE_MEDIATEK is not set
# CONFIG_PCIE_MEDIATEK_GEN3 is not set
# CONFIG_SCSI_UFS_MEDIATEK is not set
# CONFIG_NET_VENDOR_MEDIATEK is not set
# CONFIG_DWMAC_MEDIATEK is not set
# CONFIG_MEDIATEK_GE_PHY is not set
CONFIG_WLAN_VENDOR_MEDIATEK=y
# CONFIG_MEDIATEK_WATCHDOG is not set
# CONFIG_VIDEO_MEDIATEK_JPEG is not set
# CONFIG_VIDEO_MEDIATEK_VPU is not set
# CONFIG_VIDEO_MEDIATEK_MDP is not set
CONFIG_DRM_MEDIATEK=m
CONFIG_DRM_MEDIATEK_HDMI=m
# CONFIG_USB_MUSB_MEDIATEK is not set
CONFIG_COMMON_CLK_MEDIATEK=y
# CONFIG_MEDIATEK_MT6577_AUXADC is not set
CONFIG_PWM_MEDIATEK=m
is the reason why the Mediatek wifi can’t be detected is because CONFIG_PCIE_MEDIATEK was commented out? How should I proceed with this?
thanks
